root/radiance/ray/src/common/disk2square.c
Revision: 3.1
Committed: Fri Feb 18 00:40:25 2011 UTC (13 years, 4 months ago) by greg
1 /*
2 * Disk2Square.c
3 *
4 * Code by Peter Shirley and Kenneth Chiu
5 *
6 * Associated paper in ~/Documents/Others/Shirley+Chiu_JGT-97.pdf
7 *
8 * Modified interface slightly (G. Ward)
9 */
10
11 #include <math.h>
12
13 /*
14 This transforms points on [0,1]^2 to points on unit disk centered at
15 origin. Each "pie-slice" quadrant of square is handled as a seperate
16 case. The bad floating point cases are all handled appropriately.
17 The regions for (a,b) are:
18
19 phi = pi/2
20 -----*-----
21 |\ /|
22 | \ 2 / |
23 | \ / |
24 phi=pi* 3 * 1 *phi = 0
25 | / \ |
26 | / 4 \ |
27 |/ \|
28 -----*-----
29 phi = 3pi/2
30
31 change log:
32 26 feb 2004. bug fix in computation of phi (now this matches the paper,
33 which is correct). thanks to Atilim Cetin for catching this.
34 */
35
36
37 /* Map a [0,1]^2 square to a unit radius disk */
38 void
39 SDsquare2disk(double ds[2], double seedx, double seedy)
40 {
41
42 double phi, r;
43 double a = 2.*seedx - 1; /* (a,b) is now on [-1,1]^2 */
44 double b = 2.*seedy - 1;
45
46 if (a > -b) { /* region 1 or 2 */
47 if (a > b) { /* region 1, also |a| > |b| */
48 r = a;
49 phi = (M_PI/4.) * (b/a);
50 }
51 else { /* region 2, also |b| > |a| */
52 r = b;
53 phi = (M_PI/4.) * (2. - (a/b));
54 }
55 }
56 else { /* region 3 or 4 */
57 if (a < b) { /* region 3, also |a| >= |b|, a != 0 */
58 r = -a;
59 phi = (M_PI/4.) * (4. + (b/a));
60 }
61 else { /* region 4, |b| >= |a|, but a==0 and b==0 could occur. */
62 r = -b;
63 if (b != 0.)
64 phi = (M_PI/4.) * (6. - (a/b));
65 else
66 phi = 0.;
67 }
68 }
69
70 ds[0] = r * cos(phi);
71 ds[1] = r * sin(phi);
72
73 }
74
75 /* Map point on unit disk to a unit square in [0,1]^2 range */
76 void
77 SDdisk2square(double sq[2], double diskx, double disky)
78 {
79 double r = sqrt( diskx*diskx + disky*disky );
80 double phi = atan2( disky, diskx );
81 double a, b;
82
83 if (phi < -M_PI/4) phi += 2*M_PI; /* in range [-pi/4,7pi/4] */
84 if ( phi < M_PI/4) { /* region 1 */
85 a = r;
86 b = phi * a / (M_PI/4);
87 }
88 else if ( phi < 3*M_PI/4 ) { /* region 2 */
89 b = r;
90 a = -(phi - M_PI/2) * b / (M_PI/4);
91 }
92 else if ( phi < 5*M_PI/4 ) { /* region 3 */
93 a = -r;
94 b = (phi - M_PI) * a / (M_PI/4);
95 }
96 else { /* region 4 */
97 b = -r;
98 a = -(phi - 3*M_PI/2) * b / (M_PI/4);
99 }
100
101 sq[0] = (a + 1) * 0.5;
102 sq[1] = (b + 1) * 0.5;
103 }
