root/radiance/ray/src/common/disk2square.c
Revision: 3.3
Committed: Thu Jun 9 17:09:39 2011 UTC (14 years ago) by greg
CVS Tags: rad4R2, rad4R1, rad4R2P1
Changes since 3.2: +2 -1 lines
Fixes for Windows and bug fix in bsdf_m.c
# User Rev Content
1 greg 3.2 #ifndef lint
2 greg 3.3 static const char RCSid[] = "$Id: disk2square.c,v 3.2 2011/02/18 18:41:04 greg Exp $";
3 greg 3.2 #endif
4 greg 3.1 /*
5     * Disk2Square.c
6     *
7     * Code by Peter Shirley and Kenneth Chiu
8     *
9     * Associated paper in ~/Documents/Others/Shirley+Chiu_JGT-97.pdf
10     *
11     * Modified interface slightly (G. Ward)
12     */
13
14 greg 3.3 #define _USE_MATH_DEFINES
15 greg 3.1 #include <math.h>
16
17     /*
18     This transforms points on [0,1]^2 to points on unit disk centered at
19     origin. Each "pie-slice" quadrant of square is handled as a seperate
20     case. The bad floating point cases are all handled appropriately.
21     The regions for (a,b) are:
22
23     phi = pi/2
24     -----*-----
25     |\ /|
26     | \ 2 / |
27     | \ / |
28     phi=pi* 3 * 1 *phi = 0
29     | / \ |
30     | / 4 \ |
31     |/ \|
32     -----*-----
33     phi = 3pi/2
34
35     change log:
36     26 feb 2004. bug fix in computation of phi (now this matches the paper,
37     which is correct). thanks to Atilim Cetin for catching this.
38     */
39
40
41     /* Map a [0,1]^2 square to a unit radius disk */
42     void
43     SDsquare2disk(double ds[2], double seedx, double seedy)
44     {
45
46     double phi, r;
47     double a = 2.*seedx - 1; /* (a,b) is now on [-1,1]^2 */
48     double b = 2.*seedy - 1;
49
50     if (a > -b) { /* region 1 or 2 */
51     if (a > b) { /* region 1, also |a| > |b| */
52     r = a;
53     phi = (M_PI/4.) * (b/a);
54     }
55     else { /* region 2, also |b| > |a| */
56     r = b;
57     phi = (M_PI/4.) * (2. - (a/b));
58     }
59     }
60     else { /* region 3 or 4 */
61     if (a < b) { /* region 3, also |a| >= |b|, a != 0 */
62     r = -a;
63     phi = (M_PI/4.) * (4. + (b/a));
64     }
65     else { /* region 4, |b| >= |a|, but a==0 and b==0 could occur. */
66     r = -b;
67     if (b != 0.)
68     phi = (M_PI/4.) * (6. - (a/b));
69     else
70     phi = 0.;
71     }
72     }
73
74     ds[0] = r * cos(phi);
75     ds[1] = r * sin(phi);
76
77     }
78
79     /* Map point on unit disk to a unit square in [0,1]^2 range */
80     void
81     SDdisk2square(double sq[2], double diskx, double disky)
82     {
83     double r = sqrt( diskx*diskx + disky*disky );
84     double phi = atan2( disky, diskx );
85     double a, b;
86
87     if (phi < -M_PI/4) phi += 2*M_PI; /* in range [-pi/4,7pi/4] */
88     if ( phi < M_PI/4) { /* region 1 */
89     a = r;
90     b = phi * a / (M_PI/4);
91     }
92     else if ( phi < 3*M_PI/4 ) { /* region 2 */
93     b = r;
94     a = -(phi - M_PI/2) * b / (M_PI/4);
95     }
96     else if ( phi < 5*M_PI/4 ) { /* region 3 */
97     a = -r;
98     b = (phi - M_PI) * a / (M_PI/4);
99     }
100     else { /* region 4 */
101     b = -r;
102     a = -(phi - 3*M_PI/2) * b / (M_PI/4);
103     }
104
105     sq[0] = (a + 1) * 0.5;
106     sq[1] = (b + 1) * 0.5;
107     }
