1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: dircode.c,v 2.5 2003/06/20 00:25:49 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Compute a 4-byte direction code (int32 type defined in standard.h). |
6 |
7 |
* Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees. |
8 |
9 |
10 |
#include "standard.h" |
11 |
12 |
#define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */ |
13 |
#define FXNEG 01 |
14 |
#define FYNEG 02 |
15 |
#define FZNEG 04 |
16 |
#define F1X 010 |
17 |
#define F2Z 020 |
18 |
#define F1SFT 5 |
19 |
#define F2SFT 18 |
20 |
#define FMASK 0x1fff |
21 |
22 |
int32 |
23 |
encodedir(dv) /* encode a normalized direction vector */ |
24 |
FVECT dv; |
25 |
26 |
register int32 dc = 0; |
27 |
int cd[3], cm; |
28 |
register int i; |
29 |
30 |
for (i = 0; i < 3; i++) |
31 |
if (dv[i] < 0.) { |
32 |
cd[i] = (int)(dv[i] * -DCSCALE); |
33 |
dc |= FXNEG<<i; |
34 |
} else |
35 |
cd[i] = (int)(dv[i] * DCSCALE); |
36 |
if (!(cd[0] | cd[1] | cd[2])) |
37 |
return(0); /* zero normal */ |
38 |
if (cd[0] <= cd[1]) { |
39 |
dc |= F1X | cd[0] << F1SFT; |
40 |
cm = cd[1]; |
41 |
} else { |
42 |
dc |= cd[1] << F1SFT; |
43 |
cm = cd[0]; |
44 |
45 |
if (cd[2] <= cm) |
46 |
dc |= F2Z | cd[2] << F2SFT; |
47 |
else |
48 |
dc |= cm << F2SFT; |
49 |
if (!dc) /* don't generate 0 code normally */ |
50 |
dc = F1X; |
51 |
return(dc); |
52 |
53 |
54 |
55 |
void |
56 |
decodedir(dv, dc) /* decode a normalized direction vector */ |
57 |
register FVECT dv; /* returned */ |
58 |
register int32 dc; |
59 |
60 |
double d1, d2, der; |
61 |
62 |
if (!dc) { /* special code for zero normal */ |
63 |
dv[0] = dv[1] = dv[2] = 0.; |
64 |
return; |
65 |
66 |
d1 = ((dc>>F1SFT & FMASK)+.5)*(1./DCSCALE); |
67 |
d2 = ((dc>>F2SFT & FMASK)+.5)*(1./DCSCALE); |
68 |
der = sqrt(1. - d1*d1 - d2*d2); |
69 |
if (dc & F1X) { |
70 |
dv[0] = d1; |
71 |
if (dc & F2Z) { dv[1] = der; dv[2] = d2; } |
72 |
else { dv[1] = d2; dv[2] = der; } |
73 |
} else { |
74 |
dv[1] = d1; |
75 |
if (dc & F2Z) { dv[0] = der; dv[2] = d2; } |
76 |
else { dv[0] = d2; dv[2] = der; } |
77 |
78 |
if (dc & FXNEG) dv[0] = -dv[0]; |
79 |
if (dc & FYNEG) dv[1] = -dv[1]; |
80 |
if (dc & FZNEG) dv[2] = -dv[2]; |
81 |
82 |
83 |
84 |
double |
85 |
dir2diff(dc1, dc2) /* approx. radians^2 between directions */ |
86 |
int32 dc1, dc2; |
87 |
88 |
FVECT v1, v2; |
89 |
90 |
decodedir(v1, dc1); |
91 |
decodedir(v2, dc2); |
92 |
93 |
return(2. - 2.*DOT(v1,v2)); |
94 |
95 |
96 |
97 |
double |
98 |
fdir2diff(dc1, v2) /* approx. radians^2 between directions */ |
99 |
int32 dc1; |
100 |
register FVECT v2; |
101 |
102 |
FVECT v1; |
103 |
104 |
105 |
106 |
107 |
