root/Development/ray/src/common/dircode.c
Tue Apr 7 18:20:52 2020 UTC (5 years, 7 months ago) by greg
CVS Tags: HEAD, rad5R3, rad5R4, rad6R0
Diff to previous 2.12
Corrected constant that was causing bad encodings for diagonals
Fri Mar 6 19:05:19 2020 UTC (5 years, 8 months ago) by greg
Forgot to fix original (unused) code
Wed Mar 4 02:55:43 2020 UTC (5 years, 8 months ago) by greg
Changes since 2.10: +6 -6 lines
Made encodings for X, Y, and Z-plane normals exact
Tue Aug 27 23:51:23 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.9: +4 -1 lines
Added special case optimization
Tue May 14 17:21:50 2019 UTC (6 years, 6 months ago) by greg
Changes since 2.8: +30 -2 lines
Eliminated conditional branching from decoding routine
Fri Nov 9 01:35:00 2012 UTC (13 years ago) by greg
Changes since 2.7: +7 -13 lines
ANSIfication
Fri Jun 27 06:53:21 2003 UTC (22 years, 4 months ago) by greg
Sat Jun 21 14:48:53 2003 UTC (22 years, 5 months ago) by greg
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Fri Jun 20 00:25:49 2003 UTC (22 years, 5 months ago) by greg
Sat Jun 7 12:50:20 2003 UTC (22 years, 5 months ago) by schorsch
Wed Mar 12 04:59:04 2003 UTC (22 years, 8 months ago) by greg
Tue Mar 4 19:02:47 2003 UTC (22 years, 8 months ago) by greg
Changed encodedir() so it never generates 0
Tue Mar 4 05:49:21 2003 UTC (22 years, 8 months ago) by greg
Diff to selected 2.12
