root/radiance/ray/src/common/dircode.c
Revision: 2.13
Committed: Tue Apr 7 18:20:52 2020 UTC (4 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Corrected constant that was causing bad encodings for diagonals
2 static const char RCSid[] = "$Id: dircode.c,v 2.12 2020/03/06 19:05:19 greg Exp $";
5 * Compute a 4-byte direction code (externals defined in rtmath.h).
6 *
7 * Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees.
8 */
9
10 #include "rtmath.h"
11
12 #define DCSCALE 11584.5 /* ((1<<13)-.5)*sqrt(2) */
13 #define FXNEG 01
14 #define FYNEG 02
15 #define FZNEG 04
16 #define F1X 010
17 #define F2Z 020
18 #define F1SFT 5
19 #define F2SFT 18
20 #define FMASK 0x1fff
21
22 int32
23 encodedir(FVECT dv) /* encode a normalized direction vector */
24 {
25 int32 dc = 0;
26 int cd[3], cm;
27 int i;
28
29 for (i = 0; i < 3; i++)
30 if (dv[i] < 0.) {
31 cd[i] = (int)(dv[i] * -DCSCALE + .5);
32 dc |= FXNEG<<i;
33 } else
34 cd[i] = (int)(dv[i] * DCSCALE + .5);
35 if (!(cd[0] | cd[1] | cd[2]))
36 return(0); /* zero normal */
37 if (cd[0] <= cd[1]) {
38 dc |= F1X | cd[0] << F1SFT;
39 cm = cd[1];
40 } else {
41 dc |= cd[1] << F1SFT;
42 cm = cd[0];
43 }
44 if (cd[2] <= cm)
45 dc |= F2Z | cd[2] << F2SFT;
46 else
47 dc |= cm << F2SFT;
48 if (!dc) /* don't generate 0 code normally */
49 dc = F1X;
50 return(dc);
51 }
52
53 #if 0 /* original version for reference */
54
55 void
56 decodedir(FVECT dv, int32 dc) /* decode a normalized direction vector */
57 {
58 double d1, d2, der;
59
60 if (!dc) { /* special code for zero normal */
61 dv[0] = dv[1] = dv[2] = 0.;
62 return;
63 }
64 d1 = (dc>>F1SFT & FMASK)*(1./DCSCALE);
65 d2 = (dc>>F2SFT & FMASK)*(1./DCSCALE);
66 der = sqrt(1. - d1*d1 - d2*d2);
67 if (dc & F1X) {
68 dv[0] = d1;
69 if (dc & F2Z) { dv[1] = der; dv[2] = d2; }
70 else { dv[1] = d2; dv[2] = der; }
71 } else {
72 dv[1] = d1;
73 if (dc & F2Z) { dv[0] = der; dv[2] = d2; }
74 else { dv[0] = d2; dv[2] = der; }
75 }
76 if (dc & FXNEG) dv[0] = -dv[0];
77 if (dc & FYNEG) dv[1] = -dv[1];
78 if (dc & FZNEG) dv[2] = -dv[2];
79 }
80
81 #else
82
83 void
84 decodedir(FVECT dv, int32 dc) /* decode a normalized direction vector */
85 {
86 static const short itab[4][3] = {
87 {1,0,2},{0,1,2},{1,2,0},{0,2,1}
88 };
89 static const RREAL neg[2] = {1., -1.};
90 const int ndx = ((dc & F2Z) != 0)<<1 | ((dc & F1X) != 0);
91 double d1, d2, der;
92
93 if (!dc) { /* special code for zero normal */
94 dv[0] = dv[1] = dv[2] = 0.;
95 return;
96 }
97 d1 = (dc>>F1SFT & FMASK)*(1./DCSCALE);
98 d2 = (dc>>F2SFT & FMASK)*(1./DCSCALE);
99 der = sqrt(1. - d1*d1 - d2*d2);
100 dv[itab[ndx][0]] = d1;
101 dv[itab[ndx][1]] = d2;
102 dv[itab[ndx][2]] = der;
103 dv[0] *= neg[(dc&FXNEG)!=0];
104 dv[1] *= neg[(dc&FYNEG)!=0];
105 dv[2] *= neg[(dc&FZNEG)!=0];
106 }
107
108 #endif
109
110 double
111 dir2diff(int32 dc1, int32 dc2) /* approx. radians^2 between directions */
112 {
113 FVECT v1, v2;
114
115 if (dc1 == dc2)
116 return 0.;
117
118 decodedir(v1, dc1);
119 decodedir(v2, dc2);
120
121 return(2. - 2.*DOT(v1,v2));
122 }
123
124 double
125 fdir2diff(int32 dc1, FVECT v2) /* approx. radians^2 between directions */
126 {
127 FVECT v1;
128
129 decodedir(v1, dc1);
130
131 return(2. - 2.*DOT(v1,v2));
132 }
