root/Development/ray/src/common/dircode.c
Revision: 2.8
Committed: Fri Nov 9 01:35:00 2012 UTC (12 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2
Changes since 2.7: +7 -13 lines
ANSIfication
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.8 static const char RCSid[] = "$Id: dircode.c,v 2.7 2003/06/27 06:53:21 greg Exp $";
3 greg 2.1 #endif
4     /*
5 greg 2.7 * Compute a 4-byte direction code (externals defined in rtmath.h).
6 greg 2.3 *
7     * Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees.
8 greg 2.1 */
9
10 greg 2.7 #include "rtmath.h"
11 greg 2.1
12     #define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */
13     #define FXNEG 01
14     #define FYNEG 02
15     #define FZNEG 04
16     #define F1X 010
17     #define F2Z 020
18     #define F1SFT 5
19     #define F2SFT 18
20     #define FMASK 0x1fff
21
22 greg 2.5 int32
23 greg 2.8 encodedir(FVECT dv) /* encode a normalized direction vector */
24 greg 2.1 {
25 greg 2.8 int32 dc = 0;
26 greg 2.1 int cd[3], cm;
27 greg 2.8 int i;
28 greg 2.1
29     for (i = 0; i < 3; i++)
30     if (dv[i] < 0.) {
31 schorsch 2.4 cd[i] = (int)(dv[i] * -DCSCALE);
32 greg 2.1 dc |= FXNEG<<i;
33     } else
34 schorsch 2.4 cd[i] = (int)(dv[i] * DCSCALE);
35 greg 2.6 if (!(cd[0] | cd[1] | cd[2]))
36     return(0); /* zero normal */
37 greg 2.1 if (cd[0] <= cd[1]) {
38     dc |= F1X | cd[0] << F1SFT;
39     cm = cd[1];
40     } else {
41     dc |= cd[1] << F1SFT;
42     cm = cd[0];
43     }
44     if (cd[2] <= cm)
45     dc |= F2Z | cd[2] << F2SFT;
46     else
47     dc |= cm << F2SFT;
48 greg 2.6 if (!dc) /* don't generate 0 code normally */
49 greg 2.2 dc = F1X;
50 greg 2.1 return(dc);
51     }
52
53
54     void
55 greg 2.8 decodedir(FVECT dv, int32 dc) /* decode a normalized direction vector */
56 greg 2.1 {
57     double d1, d2, der;
58
59 greg 2.6 if (!dc) { /* special code for zero normal */
60     dv[0] = dv[1] = dv[2] = 0.;
61     return;
62     }
63 greg 2.1 d1 = ((dc>>F1SFT & FMASK)+.5)*(1./DCSCALE);
64     d2 = ((dc>>F2SFT & FMASK)+.5)*(1./DCSCALE);
65     der = sqrt(1. - d1*d1 - d2*d2);
66     if (dc & F1X) {
67     dv[0] = d1;
68     if (dc & F2Z) { dv[1] = der; dv[2] = d2; }
69     else { dv[1] = d2; dv[2] = der; }
70     } else {
71     dv[1] = d1;
72     if (dc & F2Z) { dv[0] = der; dv[2] = d2; }
73     else { dv[0] = d2; dv[2] = der; }
74     }
75     if (dc & FXNEG) dv[0] = -dv[0];
76     if (dc & FYNEG) dv[1] = -dv[1];
77     if (dc & FZNEG) dv[2] = -dv[2];
78     }
79
80
81     double
82 greg 2.8 dir2diff(int32 dc1, int32 dc2) /* approx. radians^2 between directions */
83 greg 2.1 {
84     FVECT v1, v2;
85
86     decodedir(v1, dc1);
87     decodedir(v2, dc2);
88
89     return(2. - 2.*DOT(v1,v2));
90     }
91
92
93     double
94 greg 2.8 fdir2diff(int32 dc1, FVECT v2) /* approx. radians^2 between directions */
95 greg 2.1 {
96     FVECT v1;
97
98     decodedir(v1, dc1);
99
100     return(2. - 2.*DOT(v1,v2));
101     }
