root/radiance/ray/src/common/dircode.c
Fri Nov 9 01:35:00 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.7: +7 -13 lines
ANSIfication
Sat Jun 21 14:48:53 2003 UTC (20 years, 11 months ago) by greg
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Wed Mar 12 04:59:04 2003 UTC (21 years, 3 months ago) by greg
Tue Mar 4 19:02:47 2003 UTC (21 years, 3 months ago) by greg
Changed encodedir() so it never generates 0
Tue Mar 4 05:49:21 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 2.8
