root/Development/ray/src/common/dircode.c
Revision: 2.7
Committed: Fri Jun 27 06:53:21 2003 UTC (22 years, 5 months ago) by greg
CVS Tags: rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
2 static const char RCSid[] = "$Id: dircode.c,v 2.6 2003/06/21 14:48:53 greg Exp $";
5 * Compute a 4-byte direction code (externals defined in rtmath.h).
6 *
7 * Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees.
8 */
9
10 #include "rtmath.h"
11
12 #define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */
13 #define FXNEG 01
14 #define FYNEG 02
15 #define FZNEG 04
16 #define F1X 010
17 #define F2Z 020
18 #define F1SFT 5
19 #define F2SFT 18
20 #define FMASK 0x1fff
21
22 int32
23 encodedir(dv) /* encode a normalized direction vector */
24 FVECT dv;
25 {
26 register int32 dc = 0;
27 int cd[3], cm;
28 register int i;
29
30 for (i = 0; i < 3; i++)
31 if (dv[i] < 0.) {
32 cd[i] = (int)(dv[i] * -DCSCALE);
33 dc |= FXNEG<<i;
34 } else
35 cd[i] = (int)(dv[i] * DCSCALE);
36 if (!(cd[0] | cd[1] | cd[2]))
37 return(0); /* zero normal */
38 if (cd[0] <= cd[1]) {
39 dc |= F1X | cd[0] << F1SFT;
40 cm = cd[1];
41 } else {
42 dc |= cd[1] << F1SFT;
43 cm = cd[0];
44 }
45 if (cd[2] <= cm)
46 dc |= F2Z | cd[2] << F2SFT;
47 else
48 dc |= cm << F2SFT;
49 if (!dc) /* don't generate 0 code normally */
50 dc = F1X;
51 return(dc);
52 }
53
54
55 void
56 decodedir(dv, dc) /* decode a normalized direction vector */
57 register FVECT dv; /* returned */
58 register int32 dc;
59 {
60 double d1, d2, der;
61
62 if (!dc) { /* special code for zero normal */
63 dv[0] = dv[1] = dv[2] = 0.;
64 return;
65 }
66 d1 = ((dc>>F1SFT & FMASK)+.5)*(1./DCSCALE);
67 d2 = ((dc>>F2SFT & FMASK)+.5)*(1./DCSCALE);
68 der = sqrt(1. - d1*d1 - d2*d2);
69 if (dc & F1X) {
70 dv[0] = d1;
71 if (dc & F2Z) { dv[1] = der; dv[2] = d2; }
72 else { dv[1] = d2; dv[2] = der; }
73 } else {
74 dv[1] = d1;
75 if (dc & F2Z) { dv[0] = der; dv[2] = d2; }
76 else { dv[0] = d2; dv[2] = der; }
77 }
78 if (dc & FXNEG) dv[0] = -dv[0];
79 if (dc & FYNEG) dv[1] = -dv[1];
80 if (dc & FZNEG) dv[2] = -dv[2];
81 }
82
83
84 double
85 dir2diff(dc1, dc2) /* approx. radians^2 between directions */
86 int32 dc1, dc2;
87 {
88 FVECT v1, v2;
89
90 decodedir(v1, dc1);
91 decodedir(v2, dc2);
92
93 return(2. - 2.*DOT(v1,v2));
94 }
95
96
97 double
98 fdir2diff(dc1, v2) /* approx. radians^2 between directions */
99 int32 dc1;
100 register FVECT v2;
101 {
102 FVECT v1;
103
104 decodedir(v1, dc1);
105
106 return(2. - 2.*DOT(v1,v2));
107 }
