root/Development/ray/src/common/dircode.c
Revision: 2.7
Committed: Fri Jun 27 06:53:21 2003 UTC (22 years, 4 months ago) by greg
CVS Tags: rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.7 static const char RCSid[] = "$Id: dircode.c,v 2.6 2003/06/21 14:48:53 greg Exp $";
3 greg 2.1 #endif
4     /*
5 greg 2.7 * Compute a 4-byte direction code (externals defined in rtmath.h).
6 greg 2.3 *
7     * Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees.
8 greg 2.1 */
9
10 greg 2.7 #include "rtmath.h"
11 greg 2.1
12     #define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */
13     #define FXNEG 01
14     #define FYNEG 02
15     #define FZNEG 04
16     #define F1X 010
17     #define F2Z 020
18     #define F1SFT 5
19     #define F2SFT 18
20     #define FMASK 0x1fff
21
22 greg 2.5 int32
23 greg 2.1 encodedir(dv) /* encode a normalized direction vector */
24     FVECT dv;
25     {
26 greg 2.5 register int32 dc = 0;
27 greg 2.1 int cd[3], cm;
28     register int i;
29
30     for (i = 0; i < 3; i++)
31     if (dv[i] < 0.) {
32 schorsch 2.4 cd[i] = (int)(dv[i] * -DCSCALE);
33 greg 2.1 dc |= FXNEG<<i;
34     } else
35 schorsch 2.4 cd[i] = (int)(dv[i] * DCSCALE);
36 greg 2.6 if (!(cd[0] | cd[1] | cd[2]))
37     return(0); /* zero normal */
38 greg 2.1 if (cd[0] <= cd[1]) {
39     dc |= F1X | cd[0] << F1SFT;
40     cm = cd[1];
41     } else {
42     dc |= cd[1] << F1SFT;
43     cm = cd[0];
44     }
45     if (cd[2] <= cm)
46     dc |= F2Z | cd[2] << F2SFT;
47     else
48     dc |= cm << F2SFT;
49 greg 2.6 if (!dc) /* don't generate 0 code normally */
50 greg 2.2 dc = F1X;
51 greg 2.1 return(dc);
52     }
53
54
55     void
56     decodedir(dv, dc) /* decode a normalized direction vector */
57     register FVECT dv; /* returned */
58 greg 2.5 register int32 dc;
59 greg 2.1 {
60     double d1, d2, der;
61
62 greg 2.6 if (!dc) { /* special code for zero normal */
63     dv[0] = dv[1] = dv[2] = 0.;
64     return;
65     }
66 greg 2.1 d1 = ((dc>>F1SFT & FMASK)+.5)*(1./DCSCALE);
67     d2 = ((dc>>F2SFT & FMASK)+.5)*(1./DCSCALE);
68     der = sqrt(1. - d1*d1 - d2*d2);
69     if (dc & F1X) {
70     dv[0] = d1;
71     if (dc & F2Z) { dv[1] = der; dv[2] = d2; }
72     else { dv[1] = d2; dv[2] = der; }
73     } else {
74     dv[1] = d1;
75     if (dc & F2Z) { dv[0] = der; dv[2] = d2; }
76     else { dv[0] = d2; dv[2] = der; }
77     }
78     if (dc & FXNEG) dv[0] = -dv[0];
79     if (dc & FYNEG) dv[1] = -dv[1];
80     if (dc & FZNEG) dv[2] = -dv[2];
81     }
82
83
84     double
85     dir2diff(dc1, dc2) /* approx. radians^2 between directions */
86 greg 2.5 int32 dc1, dc2;
87 greg 2.1 {
88     FVECT v1, v2;
89
90     decodedir(v1, dc1);
91     decodedir(v2, dc2);
92
93     return(2. - 2.*DOT(v1,v2));
94     }
95
96
97     double
98     fdir2diff(dc1, v2) /* approx. radians^2 between directions */
99 greg 2.5 int32 dc1;
100 greg 2.1 register FVECT v2;
101     {
102     FVECT v1;
103
104     decodedir(v1, dc1);
105
106     return(2. - 2.*DOT(v1,v2));
107     }
