| 1 |
/* RCSid $Id: depthcodec.h,v 2.2 2019/07/26 17:04:12 greg Exp $ */
| 2 |
| 3 |
* Definitions and declarations for 16-bit depth encode/decode
| 4 |
| 5 |
* Include after stdio.h and fvect.h
| 6 |
* Includes view.h
| 7 |
| 8 |
| 9 |
#ifndef _RAD_DEPTHCODEC_H_
| 10 |
#define _RAD_DEPTHCODEC_H_
| 11 |
| 12 |
#include "view.h"
| 13 |
| 14 |
#ifdef __cplusplus
| 15 |
extern "C" {
| 16 |
#endif
| 17 |
| 18 |
#define DEPTHSTR "REFDEPTH="
| 19 |
#define LDEPTHSTR 9
| 20 |
#define DEPTH16FMT "16-bit_encoded_depth"
| 21 |
| 22 |
#define HF_HEADIN 0x1 /* expect input header */
| 23 |
#define HF_HEADOUT 0x2 /* write header to stdout */
| 24 |
#define HF_RESIN 0x4 /* expect resolution string */
| 25 |
#define HF_RESOUT 0x8 /* write resolution to stdout */
| 26 |
#define HF_STDERR 0x10 /* report errors to stderr */
| 27 |
#define HF_ALL 0x1f /* all flags above */
| 28 |
#define HF_ENCODE 0x20 /* we are encoding */
| 29 |
| 30 |
/* Structure for encoding/decoding depths and world points */
| 31 |
typedef struct {
| 32 |
FILE *finp; /* input stream */
| 33 |
const char *inpname; /* input name */
| 34 |
int format; /* decoded format */
| 35 |
long dstart; /* start of data */
| 36 |
long curpos; /* current input position */
| 37 |
double refdepth; /* reference depth */
| 38 |
char depth_unit[32]; /* string including units */
| 39 |
int hdrflags; /* header i/o flags */
| 40 |
char inpfmt[MAXFMTLEN]; /* format from header */
| 41 |
VIEW vw; /* input view parameters */
| 42 |
int gotview; /* got input view? */
| 43 |
RESOLU res; /* input resolution */
| 44 |
} DEPTHCODEC;
| 45 |
| 46 |
/* Encode depth as 16-bit signed integer */
| 47 |
#if 1
| 48 |
#define depth2code(d, dref) \
| 49 |
( (d) > (dref) ? (int)(32768.001 - 32768.*(dref)/(d))-1 : \
| 50 |
(d) > .0 ? (int)(32767.*(d)/(dref) - 32768.) : -32768 )
| 51 |
#else
| 52 |
extern int depth2code(double d, double dref);
| 53 |
#endif
| 54 |
| 55 |
/* Decode depth from 16-bit signed integer */
| 56 |
#if 1
| 57 |
#define code2depth(c, dref) \
| 58 |
( (c) <= -32768 ? .0 : (c) >= 32767 ? FHUGE : \
| 59 |
(c) < 0 ? (dref)*(32767.5 + (c))*(1./32767.) : \
| 60 |
(dref)*32768./(32766.5 - (c)) )
| 61 |
#else
| 62 |
extern double code2depth(int c, double dref);
| 63 |
#endif
| 64 |
| 65 |
/* Set codec defaults */
| 66 |
extern void set_dc_defaults(DEPTHCODEC *dcp);
| 67 |
| 68 |
/* Load/copy header */
| 69 |
extern int process_dc_header(DEPTHCODEC *dcp, int ac, char *av[]);
| 70 |
| 71 |
/* Check that we have what we need to decode depths */
| 72 |
extern int check_decode_depths(DEPTHCODEC *dcp);
| 73 |
| 74 |
/* Decode next depth pixel from input */
| 75 |
extern double decode_depth_next(DEPTHCODEC *dcp);
| 76 |
| 77 |
/* Seek to the indicated pixel position */
| 78 |
extern int seek_dc_pix(DEPTHCODEC *dcp, int x, int y);
| 79 |
| 80 |
/* Read and decode depth for the given pixel */
| 81 |
extern double decode_depth_pix(DEPTHCODEC *dcp, int x, int y);
| 82 |
| 83 |
/* Check that we have what we need to decode world positions */
| 84 |
extern int check_decode_worldpos(DEPTHCODEC *dcp);
| 85 |
| 86 |
/* Compute world position from pixel position and depth */
| 87 |
extern int compute_worldpos(FVECT wpos, DEPTHCODEC *dcp,
| 88 |
int x, int y, double d);
| 89 |
| 90 |
/* Decode the next world position from input */
| 91 |
int decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp);
| 92 |
| 93 |
/* Decode depth and compute world position for the given pixel */
| 94 |
extern int get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y);
| 95 |
| 96 |
extern char *progname; /* global argv[0] (set by main) */
| 97 |
| 98 |
#ifdef __cplusplus
| 99 |
| 100 |
#endif
| 101 |
#endif /* _RAD_DEPTHCODEC_H_ */
