root/radiance/ray/src/common/depthcodec.h
Sat Jan 25 05:35:34 2020 UTC (5 years, 3 months ago) by greg
Improvement on previous fix
Sat Jan 25 02:36:25 2020 UTC (5 years, 3 months ago) by greg
Correction to depth code near reference
Thu Nov 7 23:20:28 2019 UTC (5 years, 5 months ago) by greg
Changes since 2.4: +6 -4 lines
Wed Aug 14 21:00:14 2019 UTC (5 years, 8 months ago) by greg
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Fri Jul 26 18:52:32 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.2: +12 -1 lines
Made macro for code2depth() and made both it and depth2code() macros optional
Fri Jul 26 17:04:12 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.1: +8 -7 lines
Diff to previous 2.1
Added control for stderr output
Fri Jul 26 16:18:06 2019 UTC (5 years, 9 months ago) by greg
