root/radiance/ray/src/common/depthcodec.h
Revision: 2.8
Committed: Tue Jun 3 21:31:51 2025 UTC (3 days, 7 hours ago) by greg
Changes since 2.7: +1 -3 lines
# User Rev Content
1 greg 2.8 /* RCSid $Id: depthcodec.h,v 2.7 2020/01/25 05:35:34 greg Exp $ */
2 greg 2.1 /*
3     * Definitions and declarations for 16-bit depth encode/decode
4     *
5 greg 2.5 * Include after rtio.h and fvect.h
6 greg 2.1 * Includes view.h
7     */
8
9     #ifndef _RAD_DEPTHCODEC_H_
10     #define _RAD_DEPTHCODEC_H_
11
12     #include "view.h"
13
14     #ifdef __cplusplus
15     extern "C" {
16     #endif
17
18     #define DEPTHSTR "REFDEPTH="
19     #define LDEPTHSTR 9
20     #define DEPTH16FMT "16-bit_encoded_depth"
21
22 greg 2.2 #define HF_HEADIN 0x1 /* expect input header */
23     #define HF_HEADOUT 0x2 /* write header to stdout */
24     #define HF_RESIN 0x4 /* expect resolution string */
25     #define HF_RESOUT 0x8 /* write resolution to stdout */
26     #define HF_STDERR 0x10 /* report errors to stderr */
27     #define HF_ALL 0x1f /* all flags above */
28     #define HF_ENCODE 0x20 /* we are encoding */
29 greg 2.1
30     /* Structure for encoding/decoding depths and world points */
31     typedef struct {
32     FILE *finp; /* input stream */
33     const char *inpname; /* input name */
34 greg 2.4 short format; /* decoded format */
35     short swapped; /* byte-swapped input */
36 greg 2.5 short last_dc; /* last depth-code read */
37     short use_last; /* use last depth-code next */
38 greg 2.1 long dstart; /* start of data */
39     long curpos; /* current input position */
40     double refdepth; /* reference depth */
41     char depth_unit[32]; /* string including units */
42 greg 2.5 short hdrflags; /* header i/o flags */
43 greg 2.1 char inpfmt[MAXFMTLEN]; /* format from header */
44 greg 2.5 short gotview; /* got input view? */
45 greg 2.1 VIEW vw; /* input view parameters */
46     RESOLU res; /* input resolution */
47     } DEPTHCODEC;
48
49     /* Encode depth as 16-bit signed integer */
50 greg 2.3 #if 1
51 greg 2.1 #define depth2code(d, dref) \
52     ( (d) > (dref) ? (int)(32768.001 - 32768.*(dref)/(d))-1 : \
53 greg 2.7 (d) > .0 ? (int)(32767.*(d)/(dref) - 32768.999) : -32768 )
54 greg 2.3 #else
55     extern int depth2code(double d, double dref);
56     #endif
57 greg 2.1
58     /* Decode depth from 16-bit signed integer */
59 greg 2.3 #if 1
60     #define code2depth(c, dref) \
61     ( (c) <= -32768 ? .0 : (c) >= 32767 ? FHUGE : \
62 greg 2.6 (c) < -1 ? (dref)*(32768.5 + (c))*(1./32767.) : \
63 greg 2.3 (dref)*32768./(32766.5 - (c)) )
64     #else
65 greg 2.1 extern double code2depth(int c, double dref);
66 greg 2.3 #endif
67 greg 2.1
68     /* Set codec defaults */
69     extern void set_dc_defaults(DEPTHCODEC *dcp);
70
71     /* Load/copy header */
72     extern int process_dc_header(DEPTHCODEC *dcp, int ac, char *av[]);
73
74     /* Check that we have what we need to decode depths */
75     extern int check_decode_depths(DEPTHCODEC *dcp);
76
77     /* Decode next depth pixel from input */
78     extern double decode_depth_next(DEPTHCODEC *dcp);
79
80     /* Seek to the indicated pixel position */
81     extern int seek_dc_pix(DEPTHCODEC *dcp, int x, int y);
82
83     /* Read and decode depth for the given pixel */
84     extern double decode_depth_pix(DEPTHCODEC *dcp, int x, int y);
85
86     /* Check that we have what we need to decode world positions */
87     extern int check_decode_worldpos(DEPTHCODEC *dcp);
88
89     /* Compute world position from pixel position and depth */
90     extern int compute_worldpos(FVECT wpos, DEPTHCODEC *dcp,
91     int x, int y, double d);
92
93     /* Decode the next world position from input */
94     int decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp);
95
96     /* Decode depth and compute world position for the given pixel */
97     extern int get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y);
98
99     #ifdef __cplusplus
100     }
101     #endif
102     #endif /* _RAD_DEPTHCODEC_H_ */
