| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: depthcodec.c,v 2.3 2019/07/26 18:52:32 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to encode/decoded 16-bit depths
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include <string.h>
| 12 |
#include <math.h>
| 13 |
#include <ctype.h>
| 14 |
#include "rtio.h"
| 15 |
#include "fvect.h"
| 16 |
#include "depthcodec.h"
| 17 |
| 18 |
| 19 |
#ifndef depth2code
| 20 |
/* Encode depth as 16-bit signed integer */
| 21 |
int
| 22 |
depth2code(double d, double dref)
| 23 |
| 24 |
if (d <= .0)
| 25 |
return -32768;
| 26 |
| 27 |
if (d > dref)
| 28 |
return (int)(32768.001 - 32768.*dref/d) - 1;
| 29 |
| 30 |
return (int)(32767.*d/dref - 32768.);
| 31 |
| 32 |
#endif
| 33 |
| 34 |
| 35 |
#ifndef code2depth
| 36 |
/* Decode depth from 16-bit signed integer */
| 37 |
double
| 38 |
code2depth(int c, double dref)
| 39 |
| 40 |
if (c <= -32768)
| 41 |
return .0;
| 42 |
| 43 |
if (c >= 32767)
| 44 |
return FHUGE;
| 45 |
| 46 |
if (c < 0)
| 47 |
return dref*(32767.5 + c)*(1./32767.);
| 48 |
| 49 |
return dref*32768./(32766.5 - c);
| 50 |
| 51 |
#endif
| 52 |
| 53 |
| 54 |
/* Set codec defaults */
| 55 |
void
| 56 |
set_dc_defaults(DEPTHCODEC *dcp)
| 57 |
| 58 |
memset(dcp, 0, sizeof(DEPTHCODEC));
| 59 |
dcp->finp = stdin;
| 60 |
dcp->inpname = "<stdin>";
| 61 |
dcp->format = 'a';
| 62 |
dcp->swapped = 0;
| 63 |
dcp->refdepth = 1.;
| 64 |
dcp->depth_unit[0] = '1';
| 65 |
dcp->vw = stdview;
| 66 |
dcp->res.rt = PIXSTANDARD;
| 67 |
if (!progname) progname = "depth_codec";
| 68 |
| 69 |
| 70 |
| 71 |
/* process header line */
| 72 |
static int
| 73 |
headline(char *s, void *p)
| 74 |
| 75 |
DEPTHCODEC *dcp = (DEPTHCODEC *)p;
| 76 |
int rv;
| 77 |
| 78 |
if (formatval(dcp->inpfmt, s)) /* don't pass format */
| 79 |
return 0;
| 80 |
| 81 |
if ((rv = isbigendian(s)) >= 0) {
| 82 |
dcp->swapped = (nativebigendian() != rv);
| 83 |
return 0;
| 84 |
| 85 |
/* check for reference depth */
| 86 |
if (!strncmp(s, DEPTHSTR, LDEPTHSTR)) {
| 87 |
char *cp;
| 88 |
strlcpy(dcp->depth_unit, s+LDEPTHSTR, sizeof(dcp->depth_unit));
| 89 |
cp = dcp->depth_unit;
| 90 |
while (*cp) cp++;
| 91 |
while (cp > dcp->depth_unit && isspace(cp[-1])) cp--;
| 92 |
*cp = '\0';
| 93 |
dcp->refdepth = atof(dcp->depth_unit);
| 94 |
if (dcp->refdepth <= .0) {
| 95 |
if (dcp->hdrflags & HF_STDERR) {
| 96 |
fputs(dcp->inpname, stderr);
| 97 |
fputs(": bad reference depth in input header\n",
| 98 |
stderr);
| 99 |
| 100 |
return -1;
| 101 |
| 102 |
} else if (isview(s)) /* get view params */
| 103 |
dcp->gotview += (sscanview(&dcp->vw, s) > 0);
| 104 |
if (dcp->hdrflags & HF_HEADOUT)
| 105 |
fputs(s, stdout); /* copy to standard output */
| 106 |
return 1;
| 107 |
| 108 |
| 109 |
| 110 |
/* Load/copy header */
| 111 |
int
| 112 |
process_dc_header(DEPTHCODEC *dcp, int ac, char *av[])
| 113 |
| 114 |
if (dcp->hdrflags & HF_HEADIN &&
| 115 |
getheader(dcp->finp, headline, dcp) < 0) {
| 116 |
| 117 |
| 118 |
fputs(": bad header\n", stderr);
| 119 |
| 120 |
return 0;
| 121 |
| 122 |
if (dcp->hdrflags & HF_HEADOUT) { /* finish header */
| 123 |
if (!(dcp->hdrflags & HF_HEADIN))
| 124 |
newheader("RADIANCE", stdout);
| 125 |
if (ac > 0)
| 126 |
printargs(ac, av, stdout);
| 127 |
if (dcp->hdrflags & HF_ENCODE) {
| 128 |
fputs(DEPTHSTR, stdout);
| 129 |
fputs(dcp->depth_unit, stdout);
| 130 |
fputc('\n', stdout);
| 131 |
fputformat(DEPTH16FMT, stdout);
| 132 |
} else
| 133 |
switch (dcp->format) {
| 134 |
case 'a':
| 135 |
fputformat("ascii", stdout);
| 136 |
break;
| 137 |
case 'f':
| 138 |
fputendian(stdout);
| 139 |
fputformat("float", stdout);
| 140 |
break;
| 141 |
case 'd':
| 142 |
fputendian(stdout);
| 143 |
fputformat("double", stdout);
| 144 |
break;
| 145 |
| 146 |
| 147 |
| 148 |
/* get/put resolution string */
| 149 |
if (dcp->hdrflags & HF_RESIN && !fgetsresolu(&dcp->res, dcp->finp)) {
| 150 |
| 151 |
| 152 |
fputs(": bad resolution string\n", stderr);
| 153 |
| 154 |
return 0;
| 155 |
| 156 |
if (dcp->hdrflags & HF_RESOUT)
| 157 |
fputsresolu(&dcp->res, stdout);
| 158 |
| 159 |
dcp->dstart = dcp->curpos = ftell(dcp->finp);
| 160 |
return 1;
| 161 |
| 162 |
| 163 |
| 164 |
/* Check that we have what we need to decode depths */
| 165 |
int
| 166 |
check_decode_depths(DEPTHCODEC *dcp)
| 167 |
| 168 |
| 169 |
| 170 |
fputs(progname, stderr);
| 171 |
fputs(": wrong header mode for decode\n", stderr);
| 172 |
| 173 |
return 0;
| 174 |
| 175 |
if (dcp->inpfmt[0] && strcmp(dcp->inpfmt, DEPTH16FMT)) {
| 176 |
| 177 |
| 178 |
fputs(": unexpected input format: ", stderr);
| 179 |
fputs(dcp->inpfmt, stderr);
| 180 |
fputc('\n', stderr);
| 181 |
| 182 |
return 0;
| 183 |
| 184 |
return 1;
| 185 |
| 186 |
| 187 |
| 188 |
/* Check that we have what we need to decode world positions */
| 189 |
int
| 190 |
check_decode_worldpos(DEPTHCODEC *dcp)
| 191 |
| 192 |
char *err;
| 193 |
| 194 |
if (!check_decode_depths(dcp))
| 195 |
return 0;
| 196 |
if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
| 197 |
| 198 |
| 199 |
fputs(": missing map resolution\n", stderr);
| 200 |
| 201 |
return 0;
| 202 |
| 203 |
if (!dcp->gotview) {
| 204 |
| 205 |
| 206 |
fputs(": missing view\n", stderr);
| 207 |
| 208 |
return 0;
| 209 |
| 210 |
if ((err = setview(&dcp->vw)) != NULL) {
| 211 |
| 212 |
| 213 |
fputs(": input view error: ", stderr);
| 214 |
fputs(err, stderr);
| 215 |
| 216 |
| 217 |
return 0;
| 218 |
| 219 |
return 1;
| 220 |
| 221 |
| 222 |
| 223 |
/* Decode next depth pixel */
| 224 |
double
| 225 |
decode_depth_next(DEPTHCODEC *dcp)
| 226 |
| 227 |
int c = getint(2, dcp->finp);
| 228 |
| 229 |
if (c == EOF && feof(dcp->finp))
| 230 |
return -1.;
| 231 |
| 232 |
dcp->curpos += 2;
| 233 |
| 234 |
return code2depth(c, dcp->refdepth);
| 235 |
| 236 |
| 237 |
| 238 |
/* Compute world position from depth */
| 239 |
int
| 240 |
compute_worldpos(FVECT wpos, DEPTHCODEC *dcp, int x, int y, double d)
| 241 |
| 242 |
RREAL loc[2];
| 243 |
FVECT rdir;
| 244 |
| 245 |
pix2loc(loc, &dcp->res, x, y);
| 246 |
| 247 |
if (viewray(wpos, rdir, &dcp->vw, loc[0], loc[1]) < -FTINY) {
| 248 |
VCOPY(wpos, dcp->vw.vp);
| 249 |
return 0;
| 250 |
| 251 |
VSUM(wpos, wpos, rdir, d);
| 252 |
return 1;
| 253 |
| 254 |
| 255 |
| 256 |
/* Decode the next world position */
| 257 |
int
| 258 |
decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp)
| 259 |
| 260 |
const long n = (dcp->curpos - dcp->dstart)>>1;
| 261 |
int x, y;
| 262 |
double d;
| 263 |
| 264 |
d = decode_depth_next(dcp);
| 265 |
if (d < -FTINY)
| 266 |
return -1;
| 267 |
| 268 |
x = scanlen(&dcp->res);
| 269 |
y = n / x;
| 270 |
x = n - (long)y*x;
| 271 |
| 272 |
return compute_worldpos(wpos, dcp, x, y, d);
| 273 |
| 274 |
| 275 |
| 276 |
/* Seek to the indicated pixel position */
| 277 |
int
| 278 |
seek_dc_pix(DEPTHCODEC *dcp, int x, int y)
| 279 |
| 280 |
long seekpos;
| 281 |
| 282 |
| 283 |
| 284 |
| 285 |
fputs(": need map resolution to seek\n", stderr);
| 286 |
| 287 |
return -1;
| 288 |
| 289 |
if ((x < 0) | (y < 0) ||
| 290 |
(x >= scanlen(&dcp->res)) | (y >= numscans(&dcp->res))) {
| 291 |
| 292 |
| 293 |
fputs(": warning - pixel index off map\n", stderr);
| 294 |
| 295 |
return 0;
| 296 |
| 297 |
seekpos = dcp->dstart + 2*((long)y*scanlen(&dcp->res) + x);
| 298 |
| 299 |
if (seekpos != dcp->curpos &&
| 300 |
fseek(dcp->finp, seekpos, SEEK_SET) == EOF) {
| 301 |
| 302 |
| 303 |
fputs(": seek error\n", stderr);
| 304 |
| 305 |
return -1;
| 306 |
| 307 |
dcp->curpos = seekpos;
| 308 |
return 1;
| 309 |
| 310 |
| 311 |
| 312 |
/* Read and decode depth for the given pixel */
| 313 |
double
| 314 |
decode_depth_pix(DEPTHCODEC *dcp, int x, int y)
| 315 |
| 316 |
int rval = seek_dc_pix(dcp, x, y);
| 317 |
| 318 |
if (rval < 0)
| 319 |
return -1.;
| 320 |
if (!rval)
| 321 |
return .0;
| 322 |
| 323 |
return decode_depth_next(dcp);
| 324 |
| 325 |
| 326 |
| 327 |
/* Read and decode the world position at the given pixel */
| 328 |
int
| 329 |
get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y)
| 330 |
| 331 |
double d = decode_depth_pix(dcp, x, y);
| 332 |
| 333 |
if (d < -FTINY)
| 334 |
return -1;
| 335 |
| 336 |
| 337 |
