root/radiance/ray/src/common/depthcodec.c
Revision: 2.9
Committed: Wed Feb 12 01:11:39 2020 UTC (5 years, 4 months ago) by greg
Removed redundant output of REFDEPTH= in header during encode
2 static const char RCSid[] = "$Id: depthcodec.c,v 2.8 2020/01/25 05:35:34 greg Exp $";
5 * Routines to encode/decoded 16-bit depths
6 */
7
8 #include "copyright.h"
9
10 #include <stdlib.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include "rtio.h"
14 #include "fvect.h"
15 #include "depthcodec.h"
16
17
18 #ifndef depth2code
19 /* Encode depth as 16-bit signed integer */
20 int
21 depth2code(double d, double dref)
22 {
23 if (d <= .0)
24 return -32768;
25
26 if (d > dref)
27 return (int)(32768.001 - 32768.*dref/d) - 1;
28
29 return (int)(32767.*d/dref - 32768.999);
30 }
31 #endif
32
33
34 #ifndef code2depth
35 /* Decode depth from 16-bit signed integer */
36 double
37 code2depth(int c, double dref)
38 {
39 if (c <= -32768)
40 return .0;
41
42 if (c >= 32767)
43 return FHUGE;
44
45 if (c >= -1)
46 return dref*32768./(32766.5 - c);
47
48 return dref*(32768.5 + c)*(1./32767.);
49 }
50 #endif
51
52
53 /* Set codec defaults */
54 void
55 set_dc_defaults(DEPTHCODEC *dcp)
56 {
57 memset(dcp, 0, sizeof(DEPTHCODEC));
58 dcp->finp = stdin;
59 dcp->inpname = "<stdin>";
60 dcp->format = 'a';
61 dcp->refdepth = 1.;
62 dcp->depth_unit[0] = '1';
63 dcp->vw = stdview;
64 dcp->res.rt = PIXSTANDARD;
65 if (!progname) progname = "depth_codec";
66 }
67
68
69 /* process header line */
70 static int
71 headline(char *s, void *p)
72 {
73 DEPTHCODEC *dcp = (DEPTHCODEC *)p;
74 int rv;
75
76 if (formatval(dcp->inpfmt, s)) /* don't pass format */
77 return 0;
78
79 if ((rv = isbigendian(s)) >= 0) {
80 dcp->swapped = (nativebigendian() != rv);
81 return 0;
82 }
83 /* check for reference depth */
84 if (!strncmp(s, DEPTHSTR, LDEPTHSTR)) {
85 char *cp;
86 strlcpy(dcp->depth_unit, s+LDEPTHSTR, sizeof(dcp->depth_unit));
87 cp = dcp->depth_unit;
88 while (*cp) cp++;
89 while (cp > dcp->depth_unit && isspace(cp[-1])) cp--;
90 *cp = '\0';
91 dcp->refdepth = atof(dcp->depth_unit);
92 if (dcp->refdepth <= .0) {
93 if (dcp->hdrflags & HF_STDERR) {
94 fputs(dcp->inpname, stderr);
95 fputs(": bad reference depth in input header\n",
96 stderr);
97 }
98 return -1;
99 }
100 if (dcp->hdrflags & HF_ENCODE)
101 return 0; /* will add this later */
102 } else if (!strncmp(s, "SAMP360=", 8))
103 dcp->gotview--;
104 else if (isview(s)) /* get view params */
105 dcp->gotview += (sscanview(&dcp->vw, s) > 0);
106 if (dcp->hdrflags & HF_HEADOUT)
107 fputs(s, stdout); /* copy to standard output */
108 return 1;
109 }
110
111
112 /* Load/copy header */
113 int
114 process_dc_header(DEPTHCODEC *dcp, int ac, char *av[])
115 {
116 if (dcp->hdrflags & HF_HEADIN &&
117 getheader(dcp->finp, headline, dcp) < 0) {
118 if (dcp->hdrflags & HF_STDERR) {
119 fputs(dcp->inpname, stderr);
120 fputs(": bad header\n", stderr);
121 }
122 return 0;
123 }
124 dcp->gotview *= (dcp->gotview > 0);
125 if (dcp->hdrflags & HF_HEADOUT) { /* finish header */
126 if (!(dcp->hdrflags & HF_HEADIN))
127 newheader("RADIANCE", stdout);
128 if (ac > 0)
129 printargs(ac, av, stdout);
130 if (dcp->hdrflags & HF_ENCODE) {
131 fputs(DEPTHSTR, stdout);
132 fputs(dcp->depth_unit, stdout);
133 fputc('\n', stdout);
134 fputformat(DEPTH16FMT, stdout);
135 } else
136 switch (dcp->format) {
137 case 'a':
138 fputformat("ascii", stdout);
139 break;
140 case 'f':
141 fputendian(stdout);
142 fputformat("float", stdout);
143 break;
144 case 'd':
145 fputendian(stdout);
146 fputformat("double", stdout);
147 break;
148 }
149 fputc('\n', stdout);
150 }
151 /* get/put resolution string */
152 if (dcp->hdrflags & HF_RESIN && !fgetsresolu(&dcp->res, dcp->finp)) {
153 if (dcp->hdrflags & HF_STDERR) {
154 fputs(dcp->inpname, stderr);
155 fputs(": bad resolution string\n", stderr);
156 }
157 return 0;
158 }
159 if (dcp->hdrflags & HF_RESOUT)
160 fputsresolu(&dcp->res, stdout);
161
162 dcp->dstart = dcp->curpos = ftell(dcp->finp);
163 return 1;
164 }
165
166
167 /* Check that we have what we need to decode depths */
168 int
169 check_decode_depths(DEPTHCODEC *dcp)
170 {
171 if (dcp->hdrflags & HF_ENCODE) {
172 if (dcp->hdrflags & HF_STDERR) {
173 fputs(progname, stderr);
174 fputs(": wrong header mode for decode\n", stderr);
175 }
176 return 0;
177 }
178 if (dcp->inpfmt[0] && strcmp(dcp->inpfmt, DEPTH16FMT)) {
179 if (dcp->hdrflags & HF_STDERR) {
180 fputs(dcp->inpname, stderr);
181 fputs(": unexpected input format: ", stderr);
182 fputs(dcp->inpfmt, stderr);
183 fputc('\n', stderr);
184 }
185 return 0;
186 }
187 return 1;
188 }
189
190
191 /* Check that we have what we need to decode world positions */
192 int
193 check_decode_worldpos(DEPTHCODEC *dcp)
194 {
195 char *err;
196
197 if (!check_decode_depths(dcp))
198 return 0;
199 if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
200 if (dcp->hdrflags & HF_STDERR) {
201 fputs(progname, stderr);
202 fputs(": missing map resolution\n", stderr);
203 }
204 return 0;
205 }
206 if (!dcp->gotview) {
207 if (dcp->hdrflags & HF_STDERR) {
208 fputs(dcp->inpname, stderr);
209 fputs(": missing view\n", stderr);
210 }
211 return 0;
212 }
213 if ((err = setview(&dcp->vw)) != NULL) {
214 if (dcp->hdrflags & HF_STDERR) {
215 fputs(dcp->inpname, stderr);
216 fputs(": input view error: ", stderr);
217 fputs(err, stderr);
218 fputc('\n', stderr);
219 }
220 return 0;
221 }
222 return 1;
223 }
224
225
226 /* Decode next depth pixel */
227 double
228 decode_depth_next(DEPTHCODEC *dcp)
229 {
230 int c;
231
232 if (dcp->use_last) {
233 dcp->use_last = 0;
234 return code2depth(dcp->last_dc, dcp->refdepth);
235 }
236 c = getint(2, dcp->finp);
237
238 if (c == EOF && feof(dcp->finp))
239 return -1.;
240
241 dcp->last_dc = c;
242 dcp->curpos += 2;
243
244 return code2depth(c, dcp->refdepth);
245 }
246
247
248 /* Compute world position from depth */
249 int
250 compute_worldpos(FVECT wpos, DEPTHCODEC *dcp, int x, int y, double d)
251 {
252 RREAL loc[2];
253 FVECT rdir;
254
255 pix2loc(loc, &dcp->res, x, y);
256
257 if (viewray(wpos, rdir, &dcp->vw, loc[0], loc[1]) < -FTINY) {
258 VCOPY(wpos, dcp->vw.vp);
259 return 0;
260 }
261 VSUM(wpos, wpos, rdir, d);
262 return 1;
263 }
264
265
266 /* Decode the next world position */
267 int
268 decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp)
269 {
270 const long n = (dcp->curpos - dcp->dstart)>>1;
271 int x, y;
272 double d;
273
274 d = decode_depth_next(dcp);
275 if (d < -FTINY)
276 return -1;
277
278 x = scanlen(&dcp->res);
279 y = n / x;
280 x = n - (long)y*x;
281
282 return compute_worldpos(wpos, dcp, x, y, d);
283 }
284
285
286 /* Seek to the indicated pixel position */
287 int
288 seek_dc_pix(DEPTHCODEC *dcp, int x, int y)
289 {
290 long seekpos;
291
292 if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
293 if (dcp->hdrflags & HF_STDERR) {
294 fputs(progname, stderr);
295 fputs(": need map resolution to seek\n", stderr);
296 }
297 return -1;
298 }
299 if ((x < 0) | (y < 0) ||
300 (x >= scanlen(&dcp->res)) | (y >= numscans(&dcp->res))) {
301 if (dcp->hdrflags & HF_STDERR) {
302 fputs(dcp->inpname, stderr);
303 fputs(": warning - pixel index off map\n", stderr);
304 }
305 return 0;
306 }
307 seekpos = dcp->dstart + 2*((long)y*scanlen(&dcp->res) + x);
308
309 if (seekpos == dcp->curpos-2) {
310 dcp->use_last++; /* avoids seek/read */
311 return 1;
312 }
313 if (seekpos != dcp->curpos &&
314 fseek(dcp->finp, seekpos, SEEK_SET) == EOF) {
315 if (dcp->hdrflags & HF_STDERR) {
316 fputs(dcp->inpname, stderr);
317 fputs(": seek error\n", stderr);
318 }
319 return -1;
320 }
321 dcp->curpos = seekpos;
322 return 1;
323 }
324
325
326 /* Read and decode depth for the given pixel */
327 double
328 decode_depth_pix(DEPTHCODEC *dcp, int x, int y)
329 {
330 int rval = seek_dc_pix(dcp, x, y);
331
332 if (rval < 0)
333 return -1.;
334 if (!rval)
335 return .0;
336
337 return decode_depth_next(dcp);
338 }
339
340
341 /* Read and decode the world position at the given pixel */
342 int
343 get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y)
344 {
345 double d = decode_depth_pix(dcp, x, y);
346
347 if (d < -FTINY)
348 return -1;
349
350 return compute_worldpos(wpos, dcp, x, y, d);
351 }
