1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: depthcodec.c,v 2.1 2019/07/26 16:18:06 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Routines to encode/decoded 16-bit depths |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include <string.h> |
12 |
#include <math.h> |
13 |
#include <ctype.h> |
14 |
#include "rtio.h" |
15 |
#include "fvect.h" |
16 |
#include "depthcodec.h" |
17 |
18 |
19 |
#if 0 /* defined as macro in depthcodec.h */ |
20 |
/* Encode depth as 16-bit signed integer */ |
21 |
int |
22 |
depth2code(double d, double dref) |
23 |
24 |
if (d <= .0) |
25 |
return -32768; |
26 |
27 |
if (d > dref) |
28 |
return (int)(32768 - 32768*dref/d) - 1; |
29 |
30 |
return (int)(32767*d/dref - 32768); |
31 |
32 |
#endif |
33 |
34 |
35 |
/* Decode depth from 16-bit signed integer */ |
36 |
double |
37 |
code2depth(int c, double dref) |
38 |
39 |
if (c <= -32768) |
40 |
return .0; |
41 |
42 |
if (c >= 32767) |
43 |
return FHUGE; |
44 |
45 |
if (c < 0) |
46 |
return dref*(32767.5 + c)*(1./32767.); |
47 |
48 |
return dref*32768./(32766.5 - c); |
49 |
50 |
51 |
52 |
/* Set codec defaults */ |
53 |
void |
54 |
set_dc_defaults(DEPTHCODEC *dcp) |
55 |
56 |
memset(dcp, 0, sizeof(DEPTHCODEC)); |
57 |
dcp->finp = stdin; |
58 |
dcp->inpname = "<stdin>"; |
59 |
dcp->format = 'a'; |
60 |
dcp->refdepth = 1.; |
61 |
dcp->depth_unit[0] = '1'; |
62 |
dcp->vw = stdview; |
63 |
dcp->res.rt = PIXSTANDARD; |
64 |
if (!progname) progname = "depth_codec"; |
65 |
66 |
67 |
68 |
/* process header line */ |
69 |
static int |
70 |
headline(char *s, void *p) |
71 |
72 |
DEPTHCODEC *dcp = (DEPTHCODEC *)p; |
73 |
74 |
if (formatval(dcp->inpfmt, s)) /* don't pass format */ |
75 |
return 0; |
76 |
/* check for reference depth */ |
77 |
if (!strncmp(s, DEPTHSTR, LDEPTHSTR)) { |
78 |
char *cp; |
79 |
strlcpy(dcp->depth_unit, s+LDEPTHSTR, sizeof(dcp->depth_unit)); |
80 |
cp = dcp->depth_unit; |
81 |
while (*cp) cp++; |
82 |
while (cp > dcp->depth_unit && isspace(cp[-1])) cp--; |
83 |
*cp = '\0'; |
84 |
dcp->refdepth = atof(dcp->depth_unit); |
85 |
if (dcp->refdepth <= .0) { |
86 |
if (dcp->hdrflags & HF_STDERR) { |
87 |
fputs(dcp->inpname, stderr); |
88 |
fputs(": bad reference depth in input header\n", |
89 |
stderr); |
90 |
91 |
return -1; |
92 |
93 |
} else if (isview(s)) /* get view params */ |
94 |
dcp->gotview += (sscanview(&dcp->vw, s) > 0); |
95 |
if (dcp->hdrflags & HF_HEADOUT) |
96 |
fputs(s, stdout); /* copy to standard output */ |
97 |
return 1; |
98 |
99 |
100 |
101 |
/* Load/copy header */ |
102 |
int |
103 |
process_dc_header(DEPTHCODEC *dcp, int ac, char *av[]) |
104 |
105 |
if (dcp->hdrflags & HF_HEADIN && |
106 |
getheader(dcp->finp, headline, dcp) < 0) { |
107 |
108 |
109 |
fputs(": bad header\n", stderr); |
110 |
111 |
return 0; |
112 |
113 |
if (dcp->hdrflags & HF_HEADOUT) { /* finish header */ |
114 |
if (!(dcp->hdrflags & HF_HEADIN)) |
115 |
newheader("RADIANCE", stdout); |
116 |
if (ac > 0) |
117 |
printargs(ac, av, stdout); |
118 |
if (dcp->hdrflags & HF_ENCODE) { |
119 |
fputs(DEPTHSTR, stdout); |
120 |
fputs(dcp->depth_unit, stdout); |
121 |
fputc('\n', stdout); |
122 |
fputformat(DEPTH16FMT, stdout); |
123 |
} else |
124 |
switch (dcp->format) { |
125 |
case 'a': |
126 |
fputformat("ascii", stdout); |
127 |
break; |
128 |
case 'f': |
129 |
fputformat("float", stdout); |
130 |
break; |
131 |
case 'd': |
132 |
fputformat("double", stdout); |
133 |
break; |
134 |
135 |
136 |
137 |
/* get/put resolution string */ |
138 |
if (dcp->hdrflags & HF_RESIN && !fgetsresolu(&dcp->res, dcp->finp)) { |
139 |
140 |
141 |
fputs(": bad resolution string\n", stderr); |
142 |
143 |
return 0; |
144 |
145 |
if (dcp->hdrflags & HF_RESOUT) |
146 |
fputsresolu(&dcp->res, stdout); |
147 |
148 |
dcp->dstart = dcp->curpos = ftell(dcp->finp); |
149 |
return 1; |
150 |
151 |
152 |
153 |
/* Check that we have what we need to decode depths */ |
154 |
int |
155 |
check_decode_depths(DEPTHCODEC *dcp) |
156 |
157 |
158 |
159 |
fputs(progname, stderr); |
160 |
fputs(": wrong header mode for decode\n", stderr); |
161 |
162 |
return 0; |
163 |
164 |
if (dcp->inpfmt[0] && strcmp(dcp->inpfmt, DEPTH16FMT)) { |
165 |
166 |
167 |
fputs(": unexpected input format: ", stderr); |
168 |
fputs(dcp->inpfmt, stderr); |
169 |
fputc('\n', stderr); |
170 |
171 |
return 0; |
172 |
173 |
return 1; |
174 |
175 |
176 |
177 |
/* Check that we have what we need to decode world positions */ |
178 |
int |
179 |
check_decode_worldpos(DEPTHCODEC *dcp) |
180 |
181 |
char *err; |
182 |
183 |
if (!check_decode_depths(dcp)) |
184 |
return 0; |
185 |
if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) { |
186 |
187 |
188 |
fputs(": missing map resolution\n", stderr); |
189 |
190 |
return 0; |
191 |
192 |
if (!dcp->gotview) { |
193 |
194 |
195 |
fputs(": missing view\n", stderr); |
196 |
197 |
return 0; |
198 |
199 |
if ((err = setview(&dcp->vw)) != NULL) { |
200 |
201 |
202 |
fputs(": input view error: ", stderr); |
203 |
fputs(err, stderr); |
204 |
205 |
206 |
return 0; |
207 |
208 |
return 1; |
209 |
210 |
211 |
212 |
/* Decode next depth pixel */ |
213 |
double |
214 |
decode_depth_next(DEPTHCODEC *dcp) |
215 |
216 |
int c = getint(2, dcp->finp); |
217 |
218 |
if (c == EOF && feof(dcp->finp)) |
219 |
return -1.; |
220 |
221 |
dcp->curpos += 2; |
222 |
223 |
return code2depth(c, dcp->refdepth); |
224 |
225 |
226 |
227 |
/* Compute world position from depth */ |
228 |
int |
229 |
compute_worldpos(FVECT wpos, DEPTHCODEC *dcp, int x, int y, double d) |
230 |
231 |
RREAL loc[2]; |
232 |
FVECT rdir; |
233 |
234 |
pix2loc(loc, &dcp->res, x, y); |
235 |
236 |
if (viewray(wpos, rdir, &dcp->vw, loc[0], loc[1]) < -FTINY) { |
237 |
VCOPY(wpos, dcp->vw.vp); |
238 |
return 0; |
239 |
240 |
VSUM(wpos, wpos, rdir, d); |
241 |
return 1; |
242 |
243 |
244 |
245 |
/* Decode the next world position */ |
246 |
int |
247 |
decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp) |
248 |
249 |
const long n = (dcp->curpos - dcp->dstart)>>1; |
250 |
int x, y; |
251 |
double d; |
252 |
253 |
d = decode_depth_next(dcp); |
254 |
if (d < -FTINY) |
255 |
return -1; |
256 |
257 |
x = scanlen(&dcp->res); |
258 |
y = n / x; |
259 |
x = n - (long)y*x; |
260 |
261 |
return compute_worldpos(wpos, dcp, x, y, d); |
262 |
263 |
264 |
265 |
/* Seek to the indicated pixel position */ |
266 |
int |
267 |
seek_dc_pix(DEPTHCODEC *dcp, int x, int y) |
268 |
269 |
long seekpos; |
270 |
271 |
272 |
273 |
274 |
fputs(": need map resolution to seek\n", stderr); |
275 |
276 |
return -1; |
277 |
278 |
if ((x < 0) | (y < 0) || |
279 |
(x >= scanlen(&dcp->res)) | (y >= numscans(&dcp->res))) { |
280 |
281 |
282 |
fputs(": warning - pixel index off map\n", stderr); |
283 |
284 |
return 0; |
285 |
286 |
seekpos = dcp->dstart + 2*((long)y*scanlen(&dcp->res) + x); |
287 |
288 |
if (seekpos != dcp->curpos && |
289 |
fseek(dcp->finp, seekpos, SEEK_SET) == EOF) { |
290 |
291 |
292 |
fputs(": seek error\n", stderr); |
293 |
294 |
return -1; |
295 |
296 |
dcp->curpos = seekpos; |
297 |
return 1; |
298 |
299 |
300 |
301 |
/* Read and decode depth for the given pixel */ |
302 |
double |
303 |
decode_depth_pix(DEPTHCODEC *dcp, int x, int y) |
304 |
305 |
int rval = seek_dc_pix(dcp, x, y); |
306 |
307 |
if (rval < 0) |
308 |
return -1.; |
309 |
if (!rval) |
310 |
return .0; |
311 |
312 |
return decode_depth_next(dcp); |
313 |
314 |
315 |
316 |
/* Read and decode the world position at the given pixel */ |
317 |
int |
318 |
get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y) |
319 |
320 |
double d = decode_depth_pix(dcp, x, y); |
321 |
322 |
if (d < -FTINY) |
323 |
return -1; |
324 |
325 |
326 |
