root/radiance/ray/src/common/depthcodec.c
Revision: 2.14
Committed: Sat Jun 7 05:09:45 2025 UTC (17 hours, 54 minutes ago) by greg
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: depthcodec.c,v 2.13 2022/09/22 21:45:28 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines to encode/decoded 16-bit depths
6     */
7
8     #include "copyright.h"
9
10     #include <math.h>
11     #include <ctype.h>
12 greg 2.14 #include "paths.h"
13 greg 2.1 #include "rtio.h"
14     #include "fvect.h"
15     #include "depthcodec.h"
16
17
18 greg 2.3 #ifndef depth2code
19 greg 2.1 /* Encode depth as 16-bit signed integer */
20     int
21     depth2code(double d, double dref)
22     {
23     if (d <= .0)
24     return -32768;
25
26     if (d > dref)
27 greg 2.3 return (int)(32768.001 - 32768.*dref/d) - 1;
28 greg 2.1
29 greg 2.8 return (int)(32767.*d/dref - 32768.999);
30 greg 2.1 }
31     #endif
32
33
34 greg 2.3 #ifndef code2depth
35 greg 2.1 /* Decode depth from 16-bit signed integer */
36     double
37     code2depth(int c, double dref)
38     {
39     if (c <= -32768)
40     return .0;
41
42     if (c >= 32767)
43     return FHUGE;
44 greg 2.5
45 greg 2.7 if (c >= -1)
46 greg 2.5 return dref*32768./(32766.5 - c);
47
48 greg 2.7 return dref*(32768.5 + c)*(1./32767.);
49 greg 2.1 }
50 greg 2.3 #endif
51 greg 2.1
52
53     /* Set codec defaults */
54     void
55     set_dc_defaults(DEPTHCODEC *dcp)
56     {
57     memset(dcp, 0, sizeof(DEPTHCODEC));
58     dcp->finp = stdin;
59     dcp->inpname = "<stdin>";
60     dcp->format = 'a';
61     dcp->refdepth = 1.;
62     dcp->depth_unit[0] = '1';
63     dcp->vw = stdview;
64     dcp->res.rt = PIXSTANDARD;
65     if (!progname) progname = "depth_codec";
66     }
67
68
69     /* process header line */
70     static int
71     headline(char *s, void *p)
72     {
73     DEPTHCODEC *dcp = (DEPTHCODEC *)p;
74 greg 2.4 int rv;
75 greg 2.1
76     if (formatval(dcp->inpfmt, s)) /* don't pass format */
77     return 0;
78 greg 2.4
79     if ((rv = isbigendian(s)) >= 0) {
80     dcp->swapped = (nativebigendian() != rv);
81     return 0;
82     }
83 greg 2.13 if (!strncmp(s, "NCOMP=", 6)) {
84     if (atoi(s+6) != 1) {
85     if (dcp->hdrflags & HF_STDERR) {
86     fputs(dcp->inpname, stderr);
87     fputs(": NCOMP must equal 1\n", stderr);
88     }
89     return -1;
90     }
91     return 0;
92     }
93     if (!strncmp(s, "NROWS=", 6)) {
94     dcp->res.yr = atoi(s+6);
95     return 0;
96     }
97     if (!strncmp(s, "NCOLS=", 6)) {
98     dcp->res.xr = atoi(s+6);
99     return 0;
100     }
101     /* check for reference depth */
102 greg 2.1 if (!strncmp(s, DEPTHSTR, LDEPTHSTR)) {
103     char *cp;
104     strlcpy(dcp->depth_unit, s+LDEPTHSTR, sizeof(dcp->depth_unit));
105     cp = dcp->depth_unit;
106     while (*cp) cp++;
107     while (cp > dcp->depth_unit && isspace(cp[-1])) cp--;
108     *cp = '\0';
109     dcp->refdepth = atof(dcp->depth_unit);
110     if (dcp->refdepth <= .0) {
111 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
112     fputs(dcp->inpname, stderr);
113     fputs(": bad reference depth in input header\n",
114     stderr);
115     }
116 greg 2.1 return -1;
117     }
118 greg 2.9 if (dcp->hdrflags & HF_ENCODE)
119     return 0; /* will add this later */
120 greg 2.6 } else if (!strncmp(s, "SAMP360=", 8))
121     dcp->gotview--;
122     else if (isview(s)) /* get view params */
123 greg 2.1 dcp->gotview += (sscanview(&dcp->vw, s) > 0);
124     if (dcp->hdrflags & HF_HEADOUT)
125     fputs(s, stdout); /* copy to standard output */
126     return 1;
127     }
128
129
130     /* Load/copy header */
131     int
132     process_dc_header(DEPTHCODEC *dcp, int ac, char *av[])
133     {
134     if (dcp->hdrflags & HF_HEADIN &&
135     getheader(dcp->finp, headline, dcp) < 0) {
136 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
137     fputs(dcp->inpname, stderr);
138     fputs(": bad header\n", stderr);
139     }
140     return 0;
141 greg 2.1 }
142 greg 2.6 dcp->gotview *= (dcp->gotview > 0);
143 greg 2.12 /* get resolution string? */
144 greg 2.13 if (dcp->hdrflags & HF_RESIN &&
145     (dcp->res.xr <= 0) | (dcp->res.yr <= 0) &&
146     !fgetsresolu(&dcp->res, dcp->finp)) {
147 greg 2.12 if (dcp->hdrflags & HF_STDERR) {
148     fputs(dcp->inpname, stderr);
149     fputs(": bad resolution string\n", stderr);
150     }
151     return 0;
152     }
153 greg 2.1 if (dcp->hdrflags & HF_HEADOUT) { /* finish header */
154     if (!(dcp->hdrflags & HF_HEADIN))
155     newheader("RADIANCE", stdout);
156     if (ac > 0)
157     printargs(ac, av, stdout);
158     if (dcp->hdrflags & HF_ENCODE) {
159     fputs(DEPTHSTR, stdout);
160     fputs(dcp->depth_unit, stdout);
161     fputc('\n', stdout);
162     fputformat(DEPTH16FMT, stdout);
163 greg 2.12 } else {
164     fputs("NCOMP=1\n", stdout);
165     if ((dcp->hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESIN)
166     printf("NCOLS=%d\nNROWS=%d\n",
167     scanlen(&dcp->res),
168     numscans(&dcp->res));
169 greg 2.1 switch (dcp->format) {
170     case 'a':
171     fputformat("ascii", stdout);
172     break;
173     case 'f':
174 greg 2.4 fputendian(stdout);
175 greg 2.1 fputformat("float", stdout);
176     break;
177     case 'd':
178 greg 2.4 fputendian(stdout);
179 greg 2.1 fputformat("double", stdout);
180     break;
181     }
182 greg 2.12 }
183 greg 2.1 fputc('\n', stdout);
184     }
185 greg 2.12 if (dcp->hdrflags & HF_RESOUT) /* put resolution string? */
186 greg 2.1 fputsresolu(&dcp->res, stdout);
187
188     dcp->dstart = dcp->curpos = ftell(dcp->finp);
189     return 1;
190     }
191
192
193     /* Check that we have what we need to decode depths */
194     int
195     check_decode_depths(DEPTHCODEC *dcp)
196     {
197     if (dcp->hdrflags & HF_ENCODE) {
198 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
199     fputs(progname, stderr);
200     fputs(": wrong header mode for decode\n", stderr);
201     }
202 greg 2.1 return 0;
203     }
204     if (dcp->inpfmt[0] && strcmp(dcp->inpfmt, DEPTH16FMT)) {
205 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
206     fputs(dcp->inpname, stderr);
207     fputs(": unexpected input format: ", stderr);
208     fputs(dcp->inpfmt, stderr);
209     fputc('\n', stderr);
210     }
211 greg 2.1 return 0;
212     }
213     return 1;
214     }
215
216
217     /* Check that we have what we need to decode world positions */
218     int
219     check_decode_worldpos(DEPTHCODEC *dcp)
220     {
221     char *err;
222
223     if (!check_decode_depths(dcp))
224     return 0;
225     if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
226 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
227     fputs(progname, stderr);
228     fputs(": missing map resolution\n", stderr);
229     }
230 greg 2.1 return 0;
231     }
232     if (!dcp->gotview) {
233 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
234     fputs(dcp->inpname, stderr);
235     fputs(": missing view\n", stderr);
236     }
237 greg 2.1 return 0;
238     }
239     if ((err = setview(&dcp->vw)) != NULL) {
240 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
241     fputs(dcp->inpname, stderr);
242     fputs(": input view error: ", stderr);
243     fputs(err, stderr);
244     fputc('\n', stderr);
245     }
246 greg 2.1 return 0;
247     }
248     return 1;
249     }
250
251
252     /* Decode next depth pixel */
253     double
254     decode_depth_next(DEPTHCODEC *dcp)
255     {
256 greg 2.5 int c;
257
258     if (dcp->use_last) {
259     dcp->use_last = 0;
260     return code2depth(dcp->last_dc, dcp->refdepth);
261     }
262     c = getint(2, dcp->finp);
263 greg 2.1
264     if (c == EOF && feof(dcp->finp))
265     return -1.;
266
267 greg 2.5 dcp->last_dc = c;
268 greg 2.1 dcp->curpos += 2;
269
270     return code2depth(c, dcp->refdepth);
271     }
272
273
274     /* Compute world position from depth */
275     int
276     compute_worldpos(FVECT wpos, DEPTHCODEC *dcp, int x, int y, double d)
277     {
278     RREAL loc[2];
279     FVECT rdir;
280
281 greg 2.11 if (d >= FHUGE*.99)
282     goto badval;
283
284 greg 2.1 pix2loc(loc, &dcp->res, x, y);
285
286 greg 2.11 if (viewray(wpos, rdir, &dcp->vw, loc[0], loc[1]) >= -FTINY) {
287     VSUM(wpos, wpos, rdir, d);
288     return 1;
289 greg 2.1 }
290 greg 2.11 badval:
291     VCOPY(wpos, dcp->vw.vp);
292     return 0;
293 greg 2.1 }
294
295
296     /* Decode the next world position */
297     int
298     decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp)
299     {
300     const long n = (dcp->curpos - dcp->dstart)>>1;
301     int x, y;
302     double d;
303
304     d = decode_depth_next(dcp);
305     if (d < -FTINY)
306     return -1;
307
308     x = scanlen(&dcp->res);
309     y = n / x;
310     x = n - (long)y*x;
311
312     return compute_worldpos(wpos, dcp, x, y, d);
313     }
314
315
316     /* Seek to the indicated pixel position */
317     int
318     seek_dc_pix(DEPTHCODEC *dcp, int x, int y)
319     {
320     long seekpos;
321
322     if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
323 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
324     fputs(progname, stderr);
325     fputs(": need map resolution to seek\n", stderr);
326     }
327 greg 2.1 return -1;
328     }
329     if ((x < 0) | (y < 0) ||
330     (x >= scanlen(&dcp->res)) | (y >= numscans(&dcp->res))) {
331 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
332     fputs(dcp->inpname, stderr);
333     fputs(": warning - pixel index off map\n", stderr);
334     }
335 greg 2.1 return 0;
336     }
337     seekpos = dcp->dstart + 2*((long)y*scanlen(&dcp->res) + x);
338
339 greg 2.5 if (seekpos == dcp->curpos-2) {
340     dcp->use_last++; /* avoids seek/read */
341     return 1;
342     }
343 greg 2.1 if (seekpos != dcp->curpos &&
344     fseek(dcp->finp, seekpos, SEEK_SET) == EOF) {
345 greg 2.2 if (dcp->hdrflags & HF_STDERR) {
346     fputs(dcp->inpname, stderr);
347     fputs(": seek error\n", stderr);
348     }
349 greg 2.1 return -1;
350     }
351     dcp->curpos = seekpos;
352 greg 2.10 dcp->use_last = 0;
353 greg 2.1 return 1;
354     }
355
356
357     /* Read and decode depth for the given pixel */
358     double
359     decode_depth_pix(DEPTHCODEC *dcp, int x, int y)
360     {
361     int rval = seek_dc_pix(dcp, x, y);
362
363     if (rval < 0)
364     return -1.;
365     if (!rval)
366     return .0;
367
368     return decode_depth_next(dcp);
369     }
370
371
372     /* Read and decode the world position at the given pixel */
373     int
374     get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y)
375     {
376     double d = decode_depth_pix(dcp, x, y);
377
378     if (d < -FTINY)
379     return -1;
380
381     return compute_worldpos(wpos, dcp, x, y, d);
382     }
