root/radiance/ray/src/common/depthcodec.c
Sat Jun 7 05:09:45 2025 UTC (3 weeks, 5 days ago) by greg
Thu Sep 22 21:45:28 2022 UTC (2 years, 9 months ago) by greg
Changes since 2.12: +23 -3 lines
feat(rcode_depth,rcode_norm): Allow NROWS,NCOLS in header rather than res string
Thu Mar 3 16:09:31 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.11: +17 -11 lines
feat(rcode_depth,rcode_norm): Output NROWS & NCOLS with -Ho
Tue Jan 26 18:47:25 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.10: +10 -6 lines
fix: return view origin rather than point at infinity for infinite depth values
Thu Mar 5 17:43:22 2020 UTC (5 years, 3 months ago) by greg
Fixed bug in pathological case of two sequential calls to seek_dc_pix()
Wed Feb 12 01:11:39 2020 UTC (5 years, 4 months ago) by greg
Removed redundant output of REFDEPTH= in header during encode
Sat Jan 25 05:35:34 2020 UTC (5 years, 5 months ago) by greg
Improvement on previous fix
Sat Jan 25 02:36:25 2020 UTC (5 years, 5 months ago) by greg
Correction to depth code near reference
Fri Jan 10 01:02:14 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.5: +5 -2 lines
Added check for 360-degree spherical sampling (unusable view)
Thu Nov 7 23:20:28 2019 UTC (5 years, 7 months ago) by greg
Changes since 2.4: +18 -9 lines
Wed Aug 14 21:00:14 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.3: +10 -1 lines
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Fri Jul 26 18:52:32 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.2: +6 -4 lines
Made macro for code2depth() and made both it and depth2code() macros optional
Fri Jul 26 17:04:12 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.1: +52 -29 lines
Added control for stderr output
Fri Jul 26 16:18:06 2019 UTC (5 years, 11 months ago) by greg
Diff to selected 2.2
