root/radiance/ray/src/common/data.h
Revision: 2.1
Committed: Fri Aug 2 18:47:25 2024 UTC (9 months ago) by greg
Error occurred while calculating annotation data.
feat(gensdaymtx,epw2wea,genssky): Taoning added new gensdaymtx and updated others
1 /* RCSid $Id: data.h,v 2.9 2024/03/12 16:54:51 greg Exp $ */
2 /*
3 * Header for data file loading and computation routines.
4 */
5 #ifndef _RAD_DATA_H_
6 #define _RAD_DATA_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #define MAXDDIM 6 /* maximum data dimensions */
12
13 #define DATATYPE float /* single precision to save space */
14 #define DATATY 'f' /* format for DATATYPE */
15 #define SPECTY 'c' /* format for SCOLR */
16
17 typedef struct datarray {
18 struct datarray *next; /* next array in list */
19 char *name; /* name of our data */
20 short type; /* DATATY, SPECTY, RED, GRN or BLU */
21 short nd; /* number of dimensions */
22 union {
23 DATATYPE *d; /* float data */
24 COLR *c; /* RGBE data */
25 uby8 *s; /* spectral data */
26 void *p; /* generic pointer */
27 } arr; /* the data */
28 struct dadim { /* put this last */
29 DATATYPE *p; /* point locations */
30 DATATYPE org, siz; /* coordinate domain */
31 int ne; /* number of elements */
32 } dim[MAXDDIM]; /* dimension specifications */
33 } DATARRAY; /* a data array */
34
35 extern DATARRAY *getdata(char *dname);
36 extern DATARRAY *getpict(char *pname);
37 extern DATARRAY *getspec(char *sname);
38 extern void freedata(DATARRAY *dta);
39 extern double datavalue(DATARRAY *dp, double *pt);
40 /* release datavector() pointer with free() not freedata() */
41 extern DATARRAY *datavector(DATARRAY *dp, double *pt);
42
43 #ifdef __cplusplus
44 }
45 #endif
46 #endif /* _RAD_DATA_H_ */
