root/Development/ray/src/common/data.c
Revision: 2.6
Committed: Wed Dec 17 18:55:28 2025 UTC (8 days, 11 hours ago) by greg
refactor: Changed use of uby8 to COLRV where appropriate
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: data.c,v 2.5 2025/06/07 05:09:45 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * data.c - routines dealing with interpolated data.
6     */
7
8     #include "copyright.h"
9
10     #include <time.h>
11
12     #include "platform.h"
13     #include "standard.h"
14     #include "color.h"
15     #include "view.h"
16     #include "data.h"
17
18     /* picture memory usage before warning */
19     #ifndef PSIZWARN
20     #ifdef SMLMEM
21     #define PSIZWARN 3000000
22     #else
23     #define PSIZWARN 50000000
24     #endif
25     #endif
26
27     #ifndef TABSIZ
28     #define TABSIZ 997 /* table size (prime) */
29     #endif
30
31     #define hash(s) (shash(s)%TABSIZ)
32
33
34     static DATARRAY *dtab[TABSIZ]; /* data array list */
35
36     static gethfunc headaspect;
37
38
39     DATARRAY *
40     getdata( /* get data array dname */
41     char *dname
42     )
43     {
44     char *dfname;
45     FILE *fp;
46     int asize=0;
47     int i, j;
48     DATARRAY *dp;
49     /* look for array in list */
50     for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
51     if (!strcmp(dname, dp->name))
52     return(dp); /* found! */
53     /*
54     * If we haven't loaded the data already, we will look
55     * for it in the directories specified by the library path.
56     *
57     * The file has the following format:
58     *
59     * N
60     * beg0 end0 n0
61     * beg1 end1 n1
62     * . . .
63     * begN endN nN
64     * data, later dimensions changing faster
65     * . . .
66     *
67     * For irregularly spaced points, the following can be
68     * substituted for begi endi ni:
69     *
70     * 0 0 ni p0i p1i .. pni
71     */
72
73     if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
74     sprintf(errmsg, "cannot find data file \"%s\"", dname);
75     error(SYSTEM, errmsg);
76     }
77     if ((fp = fopen(dfname, "r")) == NULL) {
78     sprintf(errmsg, "cannot open data file \"%s\"", dfname);
79     error(SYSTEM, errmsg);
80     }
81     /* get dimensions */
82     if (fgetval(fp, 'i', &asize) <= 0)
83     goto scanerr;
84     if ((asize <= 0) | (asize > MAXDDIM)) {
85     sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
86     error(USER, errmsg);
87     }
88     if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
89     goto memerr;
90     dp->name = savestr(dname);
91     dp->type = DATATY;
92     dp->nd = asize;
93     asize = 1;
94     for (i = 0; i < dp->nd; i++) {
95     if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
96     goto scanerr;
97     if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
98     goto scanerr;
99     if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
100     goto scanerr;
101     if (dp->dim[i].ne < 2)
102     goto scanerr;
103     asize *= dp->dim[i].ne;
104     if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
105     dp->dim[i].p = (DATATYPE *)
106     malloc(dp->dim[i].ne*sizeof(DATATYPE));
107     if (dp->dim[i].p == NULL)
108     goto memerr;
109     for (j = 0; j < dp->dim[i].ne; j++)
110     if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
111     goto scanerr;
112     for (j = 1; j < dp->dim[i].ne-1; j++)
113     if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
114     (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
115     goto scanerr;
116     dp->dim[i].org = dp->dim[i].p[0];
117     dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
118     - dp->dim[i].p[0];
119     } else
120     dp->dim[i].p = NULL;
121     }
122     if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
123     goto memerr;
124
125     for (i = 0; i < asize; i++)
126     if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
127     goto scanerr;
128     fclose(fp);
129     i = hash(dname);
130     dp->next = dtab[i];
131     return(dtab[i] = dp);
132     memerr:
133     error(SYSTEM, "out of memory in getdata");
134     scanerr:
135     sprintf(errmsg, "%s in data file \"%s\"",
136     feof(fp) ? "unexpected EOF" : "bad format", dfname);
137     error(USER, errmsg);
138     return NULL; /* pro forma return */
139     }
140
141
142     static int
143     headaspect( /* check string for aspect ratio */
144     char *s,
145     void *iap
146     )
147     {
148     char fmt[MAXFMTLEN];
149
150     if (isaspect(s))
151     *(double*)iap *= aspectval(s);
152     else if (formatval(fmt, s) && strcmp(fmt, COLRFMT))
153     *(double*)iap = 0.0;
154     return(0);
155     }
156
157     DATARRAY *
158     getpict( /* get picture pname */
159     char *pname
160     )
161     {
162     double inpaspect;
163     char *pfname;
164     FILE *fp;
165     COLR *scanin;
166     int sl, ns;
167     RESOLU inpres;
168     RREAL loc[2];
169     int y;
170     int x, i;
171     DATARRAY *pp;
172     /* look for array in list */
173     for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
174     if (!strcmp(pname, pp->name))
175     return(pp); /* found! */
176
177     if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
178     sprintf(errmsg, "cannot find picture file \"%s\"", pname);
179     error(SYSTEM, errmsg);
180     }
181     if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
182     goto memerr;
183
184     pp[0].name = savestr(pname);
185
186     if ((fp = fopen(pfname, "rb")) == NULL) {
187     sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
188     error(SYSTEM, errmsg);
189     }
190     /* get dimensions */
191     inpaspect = 1.0;
192     getheader(fp, headaspect, &inpaspect);
193     if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
194     goto readerr;
195     pp[0].nd = 2;
196     pp[0].dim[0].ne = inpres.yr;
197     pp[0].dim[1].ne = inpres.xr;
198     pp[0].dim[0].org =
199     pp[0].dim[1].org = 0.0;
200     if (inpres.xr <= inpres.yr*inpaspect) {
201     pp[0].dim[0].siz = inpaspect *
202     (double)inpres.yr/inpres.xr;
203     pp[0].dim[1].siz = 1.0;
204     } else {
205     pp[0].dim[0].siz = 1.0;
206     pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
207     inpaspect;
208     }
209     pp[0].dim[0].p = pp[0].dim[1].p = NULL;
210     sl = scanlen(&inpres); /* allocate array */
211     ns = numscans(&inpres);
212     i = ns*sl*sizeof(COLR);
213     #if PSIZWARN
214     if (i > PSIZWARN) { /* memory warning */
215     sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory",
216     pname, i*(1.0/(1024*1024)));
217     error(WARNING, errmsg);
218     }
219     #endif
220     if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
221     goto memerr;
222     /* load picture */
223     if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
224     goto memerr;
225     for (y = 0; y < ns; y++) {
226     if (freadcolrs(scanin, sl, fp) < 0)
227     goto readerr;
228     for (x = 0; x < sl; x++) {
229     pix2loc(loc, &inpres, x, y);
230     i = (int)(loc[1]*inpres.yr)*inpres.xr +
231     (int)(loc[0]*inpres.xr);
232     copycolr(pp[0].arr.c[i], scanin[x]);
233     }
234     }
235     free(scanin);
236     fclose(fp);
237     i = hash(pname);
238     pp[0].next = dtab[i]; /* link into picture list */
239     pp[1] = pp[0];
240     pp[2] = pp[0];
241     pp[0].type = RED; /* differentiate RGB records */
242     pp[1].type = GRN;
243     pp[2].type = BLU;
244     return(dtab[i] = pp);
245     memerr:
246     error(SYSTEM, "out of memory in getpict");
247     readerr:
248     sprintf(errmsg, "bad picture file \"%s\"", pfname);
249     error(USER, errmsg);
250     return NULL; /* pro forma return */
251     }
252
253
254     /* header info type for hyperspectral image */
255     typedef struct {
256     float wlpart[4]; /* wavelength partitions */
257     int nc; /* number of components */
258     double inpaspect; /* pixel aspect ratio */
259     } SPECINFO;
260
261     static int
262     specheadline( /* get info for spectral image */
263     char *s,
264     void *cdp
265     )
266     {
267     SPECINFO *sip = (SPECINFO *)cdp;
268     char fmt[MAXFMTLEN];
269
270     if (isaspect(s))
271     sip->inpaspect *= aspectval(s);
272     else if (isncomp(s))
273     sip->nc = ncompval(s);
274     else if (iswlsplit(s))
275     wlsplitval(sip->wlpart, s);
276     else if (formatval(fmt, s) && strcmp(fmt, SPECFMT))
277     return(-1);
278     return(0);
279     }
280
281     DATARRAY *
282     getspec( /* load hyperspectral image as data */
283     char *sname
284     )
285     {
286     SPECINFO si;
287     char *pfname;
288     FILE *fp;
289     int sl, ns;
290     int y, i;
291     DATARRAY *pp;
292     /* look for array in list */
293     for (pp = dtab[hash(sname)]; pp != NULL; pp = pp->next)
294     if (!strcmp(sname, pp->name))
295     return(pp); /* found! */
296
297     if ((pfname = getpath(sname, getrlibpath(), R_OK)) == NULL) {
298     sprintf(errmsg, "cannot find hyperspectral image \"%s\"", sname);
299     error(SYSTEM, errmsg);
300     }
301     if ((fp = fopen(pfname, "rb")) == NULL) {
302     sprintf(errmsg, "cannot open hyperspectral image \"%s\"", pfname);
303     error(SYSTEM, errmsg);
304     }
305     si.wlpart[3] = 0;
306     si.nc = 0;
307     si.inpaspect = 1.0;
308     if (getheader(fp, specheadline, &si) < 0 ||
309     (si.nc <= 3) | (si.nc > MAXCSAMP) | (si.wlpart[3] < 1) ||
310     !fscnresolu(&sl, &ns, fp))
311     goto readerr;
312
313     if ((pp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
314     goto memerr;
315
316     pp->name = savestr(sname);
317     pp->type = SPECTY;
318     pp->nd = 3;
319     pp->dim[0].ne = ns;
320     pp->dim[1].ne = sl;
321     pp->dim[0].org =
322     pp->dim[1].org = 0.0;
323     if (sl <= ns*si.inpaspect) {
324     pp->dim[0].siz = si.inpaspect * (double)ns/sl;
325     pp->dim[1].siz = 1.0;
326     } else {
327     pp->dim[0].siz = 1.0;
328     pp->dim[1].siz = (double)sl/ns / si.inpaspect;
329     }
330     pp->dim[2].ne = si.nc;
331     pp->dim[2].siz = si.wlpart[3] - si.wlpart[0];
332     pp->dim[2].org = si.wlpart[0] + 0.5*pp->dim[2].siz/si.nc;
333     pp->dim[2].siz *= (si.nc - 1.0)/si.nc;
334     pp->dim[0].p = pp->dim[1].p = pp->dim[2].p = NULL;
335     i = ns*sl*(si.nc+1);
336     #if PSIZWARN
337     if (i > PSIZWARN) { /* memory warning */
338     sprintf(errmsg, "hyperspectral image \"%s\" using %.1f MB of memory",
339     sname, i*(1.0/(1024*1024)));
340     error(WARNING, errmsg);
341     }
342     #endif
343 greg 2.6 if ((pp->arr.s = (COLRV *)malloc(sizeof(COLRV)*i)) == NULL)
344 greg 2.1 goto memerr;
345 greg 2.2 for (y = ns; y-- > 0; ) /* read each scanline */
346 greg 2.1 if (freadscolrs(pp->arr.s + y*sl*(si.nc+1), si.nc, sl, fp) < 0)
347     goto readerr;
348     fclose(fp);
349     i = hash(sname); /* insert in hash table */
350     pp->next = dtab[i];
351     return(dtab[i] = pp);
352     memerr:
353     error(SYSTEM, "out of memory in getspec");
354     readerr:
355     sprintf(errmsg, "bad hyperspectral image \"%s\"", pfname);
356     error(USER, errmsg);
357     return NULL; /* pro forma return */
358     }
359
360
361     void
362     freedata( /* release data array reference */
363     DATARRAY *dta
364     )
365     {
366     DATARRAY head;
367     int hval, nents;
368     DATARRAY *dpl, *dp;
369     int i;
370
371     if (dta == NULL) { /* free all if NULL */
372     hval = 0; nents = TABSIZ;
373     } else {
374     if (dta->next == dta) {
375     free(dta); /* unlisted temp array */
376     return;
377     }
378     hval = hash(dta->name); nents = 1;
379     if (!*dta->name) { /* not a data file? */
380     dta->next = dtab[hval];
381     dtab[hval] = dta; /* ...fake position */
382     }
383     }
384     while (nents--) {
385     head.next = dtab[hval];
386     dpl = &head;
387     while ((dp = dpl->next) != NULL)
388     if ((dta == NULL) | (dta == dp)) {
389     dpl->next = dp->next;
390     free(dp->arr.p);
391     for (i = 0; i < dp->nd; i++)
392     if (dp->dim[i].p != NULL)
393     free(dp->dim[i].p);
394     freestr(dp->name);
395     free(dp);
396     } else
397     dpl = dp;
398     dtab[hval++] = head.next;
399     }
400     }
401
402
403     /* internal call to interpolate data value or vector */
404     static double
405     data_interp(DATARRAY *dp, double *pt, double coef, DATATYPE *rvec)
406     {
407     DATARRAY sd;
408     int stride, i;
409     double x, c0, c1, y0, y1;
410     /* unlikely, but may as well check */
411     if ((-FTINY <= coef) & (coef <= FTINY))
412     return(0.);
413     /* set up dimensions for recursion */
414     if (dp->nd > 1) {
415     sd.name = dp->name;
416     sd.type = dp->type;
417     sd.nd = dp->nd - 1;
418     memcpy(sd.dim, dp->dim+1, sd.nd*sizeof(struct dadim));
419     stride = sd.dim[i = sd.nd-1].ne + (sd.type==SPECTY);
420     while (i-- > 0)
421     stride *= sd.dim[i].ne;
422     }
423     /* get independent variable */
424     if (dp->dim[0].p == NULL) { /* evenly spaced points */
425     x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
426     x *= (double)(dp->dim[0].ne - 1);
427     i = x;
428     if (i < 0)
429     i = 0;
430     else if (i > dp->dim[0].ne - 2)
431     i = dp->dim[0].ne - 2;
432     } else { /* unevenly spaced points */
433     int lower, upper;
434     if (dp->dim[0].siz > 0.) {
435     lower = 0;
436     upper = dp->dim[0].ne;
437     } else {
438     lower = dp->dim[0].ne;
439     upper = 0;
440     }
441     do {
442     i = (lower + upper) >> 1;
443     if (pt[0] >= dp->dim[0].p[i])
444     lower = i;
445     else
446     upper = i;
447     } while (i != (lower + upper) >> 1);
448
449     if (i > dp->dim[0].ne - 2)
450     i = dp->dim[0].ne - 2;
451
452     x = i + (pt[0] - dp->dim[0].p[i]) /
453     (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
454     }
455     /*
456     * Compute interpolation coefficients:
457     * extrapolate as far as one division, then
458     * taper off harmonically to zero.
459     */
460     if (x > i+2) {
461     c0 = 1./(i-1 - x);
462     c1 = -2.*c0;
463     } else if (x < i-1) {
464 greg 2.3 c1 = 1./(x - i);
465 greg 2.1 c0 = -2.*c1;
466     } else {
467     c0 = i+1 - x;
468     c1 = x - i;
469     }
470     c0 *= coef;
471     c1 *= coef;
472     /* check if vector interp */
473     if ((dp->nd == 2) & (rvec != NULL)) {
474     if (dp->type == DATATY) {
475     sd.arr.d = dp->arr.d + i*stride;
476     for (i = sd.dim[0].ne; i--; )
477     rvec[i] += c0*sd.arr.d[i]
478     + c1*sd.arr.d[i+stride];
479     } else if (dp->type == SPECTY) {
480     double f;
481     sd.arr.s = dp->arr.s + i*stride;
482     if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c0)|(c0>FTINY))) {
483 greg 2.4 f = c0 * cxponent[sd.arr.s[sd.dim[0].ne]];
484 greg 2.1 for (i = sd.dim[0].ne; i--; )
485     rvec[i] += f*(sd.arr.s[i] + .5);
486     }
487     sd.arr.s += stride;
488     if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c1)|(c1>FTINY))) {
489 greg 2.4 f = c1 * cxponent[sd.arr.s[sd.dim[0].ne]];
490 greg 2.1 for (i = sd.dim[0].ne; i--; )
491     rvec[i] += f*(sd.arr.s[i] + .5);
492     }
493     } else {
494     sd.arr.c = dp->arr.c + i*stride;
495     for (i = sd.dim[0].ne; i--; )
496     rvec[i] += c0*colrval(sd.arr.c[i],sd.type)
497     + c1*colrval(sd.arr.c[i+stride],sd.type);
498     }
499     return(0.); /* return value ignored */
500     }
501     /* get dependent variable */
502     if (dp->nd > 1) {
503     if (dp->type == DATATY) {
504     sd.arr.d = dp->arr.d + i*stride;
505     y0 = data_interp(&sd, pt+1, c0, rvec);
506     sd.arr.d += stride;
507     } else if (dp->type == SPECTY) {
508     sd.arr.s = dp->arr.s + i*stride;
509     y0 = data_interp(&sd, pt+1, c0, rvec);
510     sd.arr.s += stride;
511     } else {
512     sd.arr.c = dp->arr.c + i*stride;
513     y0 = data_interp(&sd, pt+1, c0, rvec);
514     sd.arr.c += stride;
515     }
516     y1 = data_interp(&sd, pt+1, c1, rvec);
517     } else { /* end of recursion */
518     if (dp->type == DATATY) {
519     y0 = dp->arr.d[i];
520     y1 = dp->arr.d[i+1];
521     } else if (dp->type == SPECTY) {
522 greg 2.4 double f = cxponent[dp->arr.s[dp->dim[0].ne]];
523     y0 = f*(dp->arr.s[i] + 0.5);
524     y1 = f*(dp->arr.s[i+1] + 0.5);
525 greg 2.1 } else {
526     y0 = colrval(dp->arr.c[i],dp->type);
527     y1 = colrval(dp->arr.c[i+1],dp->type);
528     }
529     y0 *= c0;
530     y1 *= c1;
531     }
532     return(y0 + y1); /* coefficients already applied */
533     }
534
535
536     double
537     datavalue( /* interpolate data value at a point */
538     DATARRAY *dp,
539     double *pt
540     )
541     {
542     return(data_interp(dp, pt, 1., NULL));
543     }
544
545
546     /* Interpolate final vector corresponding to last dimension in data array */
547     DATARRAY *
548     datavector(DATARRAY *dp, double *pt)
549     {
550     DATARRAY *newdp;
551
552     if (dp->nd < 2)
553     error(INTERNAL, "datavector() called with 1-D array");
554     /* create vector array */
555     newdp = (DATARRAY *)malloc(sizeof(DATARRAY) -
556     (MAXDDIM-1)*sizeof(struct dadim) +
557     sizeof(DATATYPE)*dp->dim[dp->nd-1].ne);
558     if (newdp == NULL)
559     error(SYSTEM, "out of memory in datavector");
560     newdp->next = newdp; /* flags us as temp vector */
561     newdp->name = dp->name;
562     newdp->type = DATATY;
563     newdp->nd = 1; /* vector data goes here */
564     newdp->dim[0] = dp->dim[dp->nd-1];
565     newdp->arr.d = (DATATYPE *)(newdp->dim + 1);
566     memset(newdp->arr.d, 0, sizeof(DATATYPE)*newdp->dim[0].ne);
567
568     (void)data_interp(dp, pt, 1., newdp->arr.d);
569
570     return(newdp); /* will be free'd using free() */
571     }
