root/Development/ray/src/common/data.c
Revision: 2.6
Committed: Wed Dec 17 18:55:28 2025 UTC (12 days, 16 hours ago) by greg
refactor: Changed use of uby8 to COLRV where appropriate
2 static const char RCSid[] = "$Id: data.c,v 2.5 2025/06/07 05:09:45 greg Exp $";
5 * data.c - routines dealing with interpolated data.
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11
12 #include "platform.h"
13 #include "standard.h"
14 #include "color.h"
15 #include "view.h"
16 #include "data.h"
17
18 /* picture memory usage before warning */
19 #ifndef PSIZWARN
20 #ifdef SMLMEM
21 #define PSIZWARN 3000000
22 #else
23 #define PSIZWARN 50000000
24 #endif
25 #endif
26
27 #ifndef TABSIZ
28 #define TABSIZ 997 /* table size (prime) */
29 #endif
30
31 #define hash(s) (shash(s)%TABSIZ)
32
33
34 static DATARRAY *dtab[TABSIZ]; /* data array list */
35
36 static gethfunc headaspect;
37
38
39 DATARRAY *
40 getdata( /* get data array dname */
41 char *dname
42 )
43 {
44 char *dfname;
45 FILE *fp;
46 int asize=0;
47 int i, j;
48 DATARRAY *dp;
49 /* look for array in list */
50 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
51 if (!strcmp(dname, dp->name))
52 return(dp); /* found! */
53 /*
54 * If we haven't loaded the data already, we will look
55 * for it in the directories specified by the library path.
56 *
57 * The file has the following format:
58 *
59 * N
60 * beg0 end0 n0
61 * beg1 end1 n1
62 * . . .
63 * begN endN nN
64 * data, later dimensions changing faster
65 * . . .
66 *
67 * For irregularly spaced points, the following can be
68 * substituted for begi endi ni:
69 *
70 * 0 0 ni p0i p1i .. pni
71 */
72
73 if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
74 sprintf(errmsg, "cannot find data file \"%s\"", dname);
75 error(SYSTEM, errmsg);
76 }
77 if ((fp = fopen(dfname, "r")) == NULL) {
78 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
79 error(SYSTEM, errmsg);
80 }
81 /* get dimensions */
82 if (fgetval(fp, 'i', &asize) <= 0)
83 goto scanerr;
84 if ((asize <= 0) | (asize > MAXDDIM)) {
85 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
86 error(USER, errmsg);
87 }
88 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
89 goto memerr;
90 dp->name = savestr(dname);
91 dp->type = DATATY;
92 dp->nd = asize;
93 asize = 1;
94 for (i = 0; i < dp->nd; i++) {
95 if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
96 goto scanerr;
97 if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
98 goto scanerr;
99 if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
100 goto scanerr;
101 if (dp->dim[i].ne < 2)
102 goto scanerr;
103 asize *= dp->dim[i].ne;
104 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
105 dp->dim[i].p = (DATATYPE *)
106 malloc(dp->dim[i].ne*sizeof(DATATYPE));
107 if (dp->dim[i].p == NULL)
108 goto memerr;
109 for (j = 0; j < dp->dim[i].ne; j++)
110 if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
111 goto scanerr;
112 for (j = 1; j < dp->dim[i].ne-1; j++)
113 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
114 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
115 goto scanerr;
116 dp->dim[i].org = dp->dim[i].p[0];
117 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
118 - dp->dim[i].p[0];
119 } else
120 dp->dim[i].p = NULL;
121 }
122 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
123 goto memerr;
124
125 for (i = 0; i < asize; i++)
126 if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
127 goto scanerr;
128 fclose(fp);
129 i = hash(dname);
130 dp->next = dtab[i];
131 return(dtab[i] = dp);
132 memerr:
133 error(SYSTEM, "out of memory in getdata");
134 scanerr:
135 sprintf(errmsg, "%s in data file \"%s\"",
136 feof(fp) ? "unexpected EOF" : "bad format", dfname);
137 error(USER, errmsg);
138 return NULL; /* pro forma return */
139 }
140
141
142 static int
143 headaspect( /* check string for aspect ratio */
144 char *s,
145 void *iap
146 )
147 {
148 char fmt[MAXFMTLEN];
149
150 if (isaspect(s))
151 *(double*)iap *= aspectval(s);
152 else if (formatval(fmt, s) && strcmp(fmt, COLRFMT))
153 *(double*)iap = 0.0;
154 return(0);
155 }
156
157 DATARRAY *
158 getpict( /* get picture pname */
159 char *pname
160 )
161 {
162 double inpaspect;
163 char *pfname;
164 FILE *fp;
165 COLR *scanin;
166 int sl, ns;
167 RESOLU inpres;
168 RREAL loc[2];
169 int y;
170 int x, i;
171 DATARRAY *pp;
172 /* look for array in list */
173 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
174 if (!strcmp(pname, pp->name))
175 return(pp); /* found! */
176
177 if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
178 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
179 error(SYSTEM, errmsg);
180 }
181 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
182 goto memerr;
183
184 pp[0].name = savestr(pname);
185
186 if ((fp = fopen(pfname, "rb")) == NULL) {
187 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
188 error(SYSTEM, errmsg);
189 }
190 /* get dimensions */
191 inpaspect = 1.0;
192 getheader(fp, headaspect, &inpaspect);
193 if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
194 goto readerr;
195 pp[0].nd = 2;
196 pp[0].dim[0].ne = inpres.yr;
197 pp[0].dim[1].ne = inpres.xr;
198 pp[0].dim[0].org =
199 pp[0].dim[1].org = 0.0;
200 if (inpres.xr <= inpres.yr*inpaspect) {
201 pp[0].dim[0].siz = inpaspect *
202 (double)inpres.yr/inpres.xr;
203 pp[0].dim[1].siz = 1.0;
204 } else {
205 pp[0].dim[0].siz = 1.0;
206 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
207 inpaspect;
208 }
209 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
210 sl = scanlen(&inpres); /* allocate array */
211 ns = numscans(&inpres);
212 i = ns*sl*sizeof(COLR);
213 #if PSIZWARN
214 if (i > PSIZWARN) { /* memory warning */
215 sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory",
216 pname, i*(1.0/(1024*1024)));
217 error(WARNING, errmsg);
218 }
219 #endif
220 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
221 goto memerr;
222 /* load picture */
223 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
224 goto memerr;
225 for (y = 0; y < ns; y++) {
226 if (freadcolrs(scanin, sl, fp) < 0)
227 goto readerr;
228 for (x = 0; x < sl; x++) {
229 pix2loc(loc, &inpres, x, y);
230 i = (int)(loc[1]*inpres.yr)*inpres.xr +
231 (int)(loc[0]*inpres.xr);
232 copycolr(pp[0].arr.c[i], scanin[x]);
233 }
234 }
235 free(scanin);
236 fclose(fp);
237 i = hash(pname);
238 pp[0].next = dtab[i]; /* link into picture list */
239 pp[1] = pp[0];
240 pp[2] = pp[0];
241 pp[0].type = RED; /* differentiate RGB records */
242 pp[1].type = GRN;
243 pp[2].type = BLU;
244 return(dtab[i] = pp);
245 memerr:
246 error(SYSTEM, "out of memory in getpict");
247 readerr:
248 sprintf(errmsg, "bad picture file \"%s\"", pfname);
249 error(USER, errmsg);
250 return NULL; /* pro forma return */
251 }
252
253
254 /* header info type for hyperspectral image */
255 typedef struct {
256 float wlpart[4]; /* wavelength partitions */
257 int nc; /* number of components */
258 double inpaspect; /* pixel aspect ratio */
259 } SPECINFO;
260
261 static int
262 specheadline( /* get info for spectral image */
263 char *s,
264 void *cdp
265 )
266 {
267 SPECINFO *sip = (SPECINFO *)cdp;
268 char fmt[MAXFMTLEN];
269
270 if (isaspect(s))
271 sip->inpaspect *= aspectval(s);
272 else if (isncomp(s))
273 sip->nc = ncompval(s);
274 else if (iswlsplit(s))
275 wlsplitval(sip->wlpart, s);
276 else if (formatval(fmt, s) && strcmp(fmt, SPECFMT))
277 return(-1);
278 return(0);
279 }
280
281 DATARRAY *
282 getspec( /* load hyperspectral image as data */
283 char *sname
284 )
285 {
286 SPECINFO si;
287 char *pfname;
288 FILE *fp;
289 int sl, ns;
290 int y, i;
291 DATARRAY *pp;
292 /* look for array in list */
293 for (pp = dtab[hash(sname)]; pp != NULL; pp = pp->next)
294 if (!strcmp(sname, pp->name))
295 return(pp); /* found! */
296
297 if ((pfname = getpath(sname, getrlibpath(), R_OK)) == NULL) {
298 sprintf(errmsg, "cannot find hyperspectral image \"%s\"", sname);
299 error(SYSTEM, errmsg);
300 }
301 if ((fp = fopen(pfname, "rb")) == NULL) {
302 sprintf(errmsg, "cannot open hyperspectral image \"%s\"", pfname);
303 error(SYSTEM, errmsg);
304 }
305 si.wlpart[3] = 0;
306 si.nc = 0;
307 si.inpaspect = 1.0;
308 if (getheader(fp, specheadline, &si) < 0 ||
309 (si.nc <= 3) | (si.nc > MAXCSAMP) | (si.wlpart[3] < 1) ||
310 !fscnresolu(&sl, &ns, fp))
311 goto readerr;
312
313 if ((pp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
314 goto memerr;
315
316 pp->name = savestr(sname);
317 pp->type = SPECTY;
318 pp->nd = 3;
319 pp->dim[0].ne = ns;
320 pp->dim[1].ne = sl;
321 pp->dim[0].org =
322 pp->dim[1].org = 0.0;
323 if (sl <= ns*si.inpaspect) {
324 pp->dim[0].siz = si.inpaspect * (double)ns/sl;
325 pp->dim[1].siz = 1.0;
326 } else {
327 pp->dim[0].siz = 1.0;
328 pp->dim[1].siz = (double)sl/ns / si.inpaspect;
329 }
330 pp->dim[2].ne = si.nc;
331 pp->dim[2].siz = si.wlpart[3] - si.wlpart[0];
332 pp->dim[2].org = si.wlpart[0] + 0.5*pp->dim[2].siz/si.nc;
333 pp->dim[2].siz *= (si.nc - 1.0)/si.nc;
334 pp->dim[0].p = pp->dim[1].p = pp->dim[2].p = NULL;
335 i = ns*sl*(si.nc+1);
336 #if PSIZWARN
337 if (i > PSIZWARN) { /* memory warning */
338 sprintf(errmsg, "hyperspectral image \"%s\" using %.1f MB of memory",
339 sname, i*(1.0/(1024*1024)));
340 error(WARNING, errmsg);
341 }
342 #endif
343 if ((pp->arr.s = (COLRV *)malloc(sizeof(COLRV)*i)) == NULL)
344 goto memerr;
345 for (y = ns; y-- > 0; ) /* read each scanline */
346 if (freadscolrs(pp->arr.s + y*sl*(si.nc+1), si.nc, sl, fp) < 0)
347 goto readerr;
348 fclose(fp);
349 i = hash(sname); /* insert in hash table */
350 pp->next = dtab[i];
351 return(dtab[i] = pp);
352 memerr:
353 error(SYSTEM, "out of memory in getspec");
354 readerr:
355 sprintf(errmsg, "bad hyperspectral image \"%s\"", pfname);
356 error(USER, errmsg);
357 return NULL; /* pro forma return */
358 }
359
360
361 void
362 freedata( /* release data array reference */
363 DATARRAY *dta
364 )
365 {
366 DATARRAY head;
367 int hval, nents;
368 DATARRAY *dpl, *dp;
369 int i;
370
371 if (dta == NULL) { /* free all if NULL */
372 hval = 0; nents = TABSIZ;
373 } else {
374 if (dta->next == dta) {
375 free(dta); /* unlisted temp array */
376 return;
377 }
378 hval = hash(dta->name); nents = 1;
379 if (!*dta->name) { /* not a data file? */
380 dta->next = dtab[hval];
381 dtab[hval] = dta; /* ...fake position */
382 }
383 }
384 while (nents--) {
385 head.next = dtab[hval];
386 dpl = &head;
387 while ((dp = dpl->next) != NULL)
388 if ((dta == NULL) | (dta == dp)) {
389 dpl->next = dp->next;
390 free(dp->arr.p);
391 for (i = 0; i < dp->nd; i++)
392 if (dp->dim[i].p != NULL)
393 free(dp->dim[i].p);
394 freestr(dp->name);
395 free(dp);
396 } else
397 dpl = dp;
398 dtab[hval++] = head.next;
399 }
400 }
401
402
403 /* internal call to interpolate data value or vector */
404 static double
405 data_interp(DATARRAY *dp, double *pt, double coef, DATATYPE *rvec)
406 {
407 DATARRAY sd;
408 int stride, i;
409 double x, c0, c1, y0, y1;
410 /* unlikely, but may as well check */
411 if ((-FTINY <= coef) & (coef <= FTINY))
412 return(0.);
413 /* set up dimensions for recursion */
414 if (dp->nd > 1) {
415 sd.name = dp->name;
416 sd.type = dp->type;
417 sd.nd = dp->nd - 1;
418 memcpy(sd.dim, dp->dim+1, sd.nd*sizeof(struct dadim));
419 stride = sd.dim[i = sd.nd-1].ne + (sd.type==SPECTY);
420 while (i-- > 0)
421 stride *= sd.dim[i].ne;
422 }
423 /* get independent variable */
424 if (dp->dim[0].p == NULL) { /* evenly spaced points */
425 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
426 x *= (double)(dp->dim[0].ne - 1);
427 i = x;
428 if (i < 0)
429 i = 0;
430 else if (i > dp->dim[0].ne - 2)
431 i = dp->dim[0].ne - 2;
432 } else { /* unevenly spaced points */
433 int lower, upper;
434 if (dp->dim[0].siz > 0.) {
435 lower = 0;
436 upper = dp->dim[0].ne;
437 } else {
438 lower = dp->dim[0].ne;
439 upper = 0;
440 }
441 do {
442 i = (lower + upper) >> 1;
443 if (pt[0] >= dp->dim[0].p[i])
444 lower = i;
445 else
446 upper = i;
447 } while (i != (lower + upper) >> 1);
448
449 if (i > dp->dim[0].ne - 2)
450 i = dp->dim[0].ne - 2;
451
452 x = i + (pt[0] - dp->dim[0].p[i]) /
453 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
454 }
455 /*
456 * Compute interpolation coefficients:
457 * extrapolate as far as one division, then
458 * taper off harmonically to zero.
459 */
460 if (x > i+2) {
461 c0 = 1./(i-1 - x);
462 c1 = -2.*c0;
463 } else if (x < i-1) {
464 c1 = 1./(x - i);
465 c0 = -2.*c1;
466 } else {
467 c0 = i+1 - x;
468 c1 = x - i;
469 }
470 c0 *= coef;
471 c1 *= coef;
472 /* check if vector interp */
473 if ((dp->nd == 2) & (rvec != NULL)) {
474 if (dp->type == DATATY) {
475 sd.arr.d = dp->arr.d + i*stride;
476 for (i = sd.dim[0].ne; i--; )
477 rvec[i] += c0*sd.arr.d[i]
478 + c1*sd.arr.d[i+stride];
479 } else if (dp->type == SPECTY) {
480 double f;
481 sd.arr.s = dp->arr.s + i*stride;
482 if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c0)|(c0>FTINY))) {
483 f = c0 * cxponent[sd.arr.s[sd.dim[0].ne]];
484 for (i = sd.dim[0].ne; i--; )
485 rvec[i] += f*(sd.arr.s[i] + .5);
486 }
487 sd.arr.s += stride;
488 if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c1)|(c1>FTINY))) {
489 f = c1 * cxponent[sd.arr.s[sd.dim[0].ne]];
490 for (i = sd.dim[0].ne; i--; )
491 rvec[i] += f*(sd.arr.s[i] + .5);
492 }
493 } else {
494 sd.arr.c = dp->arr.c + i*stride;
495 for (i = sd.dim[0].ne; i--; )
496 rvec[i] += c0*colrval(sd.arr.c[i],sd.type)
497 + c1*colrval(sd.arr.c[i+stride],sd.type);
498 }
499 return(0.); /* return value ignored */
500 }
501 /* get dependent variable */
502 if (dp->nd > 1) {
503 if (dp->type == DATATY) {
504 sd.arr.d = dp->arr.d + i*stride;
505 y0 = data_interp(&sd, pt+1, c0, rvec);
506 sd.arr.d += stride;
507 } else if (dp->type == SPECTY) {
508 sd.arr.s = dp->arr.s + i*stride;
509 y0 = data_interp(&sd, pt+1, c0, rvec);
510 sd.arr.s += stride;
511 } else {
512 sd.arr.c = dp->arr.c + i*stride;
513 y0 = data_interp(&sd, pt+1, c0, rvec);
514 sd.arr.c += stride;
515 }
516 y1 = data_interp(&sd, pt+1, c1, rvec);
517 } else { /* end of recursion */
518 if (dp->type == DATATY) {
519 y0 = dp->arr.d[i];
520 y1 = dp->arr.d[i+1];
521 } else if (dp->type == SPECTY) {
522 double f = cxponent[dp->arr.s[dp->dim[0].ne]];
523 y0 = f*(dp->arr.s[i] + 0.5);
524 y1 = f*(dp->arr.s[i+1] + 0.5);
525 } else {
526 y0 = colrval(dp->arr.c[i],dp->type);
527 y1 = colrval(dp->arr.c[i+1],dp->type);
528 }
529 y0 *= c0;
530 y1 *= c1;
531 }
532 return(y0 + y1); /* coefficients already applied */
533 }
534
535
536 double
537 datavalue( /* interpolate data value at a point */
538 DATARRAY *dp,
539 double *pt
540 )
541 {
542 return(data_interp(dp, pt, 1., NULL));
543 }
544
545
546 /* Interpolate final vector corresponding to last dimension in data array */
547 DATARRAY *
548 datavector(DATARRAY *dp, double *pt)
549 {
550 DATARRAY *newdp;
551
552 if (dp->nd < 2)
553 error(INTERNAL, "datavector() called with 1-D array");
554 /* create vector array */
555 newdp = (DATARRAY *)malloc(sizeof(DATARRAY) -
556 (MAXDDIM-1)*sizeof(struct dadim) +
557 sizeof(DATATYPE)*dp->dim[dp->nd-1].ne);
558 if (newdp == NULL)
559 error(SYSTEM, "out of memory in datavector");
560 newdp->next = newdp; /* flags us as temp vector */
561 newdp->name = dp->name;
562 newdp->type = DATATY;
563 newdp->nd = 1; /* vector data goes here */
564 newdp->dim[0] = dp->dim[dp->nd-1];
565 newdp->arr.d = (DATATYPE *)(newdp->dim + 1);
566 memset(newdp->arr.d, 0, sizeof(DATATYPE)*newdp->dim[0].ne);
567
568 (void)data_interp(dp, pt, 1., newdp->arr.d);
569
570 return(newdp); /* will be free'd using free() */
571 }
