| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: data.c,v 2.2 2024/08/19 18:06:14 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* data.c - routines dealing with interpolated data.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <time.h>
| 11 |
| 12 |
#include "platform.h"
| 13 |
#include "paths.h"
| 14 |
#include "standard.h"
| 15 |
#include "color.h"
| 16 |
#include "view.h"
| 17 |
#include "data.h"
| 18 |
| 19 |
/* picture memory usage before warning */
| 20 |
#ifndef PSIZWARN
| 21 |
#ifdef SMLMEM
| 22 |
#define PSIZWARN 3000000
| 23 |
#else
| 24 |
#define PSIZWARN 50000000
| 25 |
#endif
| 26 |
#endif
| 27 |
| 28 |
#ifndef TABSIZ
| 29 |
#define TABSIZ 997 /* table size (prime) */
| 30 |
#endif
| 31 |
| 32 |
#define hash(s) (shash(s)%TABSIZ)
| 33 |
| 34 |
| 35 |
static DATARRAY *dtab[TABSIZ]; /* data array list */
| 36 |
| 37 |
static gethfunc headaspect;
| 38 |
| 39 |
| 40 |
DATARRAY *
| 41 |
getdata( /* get data array dname */
| 42 |
char *dname
| 43 |
| 44 |
| 45 |
char *dfname;
| 46 |
FILE *fp;
| 47 |
int asize=0;
| 48 |
int i, j;
| 49 |
DATARRAY *dp;
| 50 |
/* look for array in list */
| 51 |
for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
| 52 |
if (!strcmp(dname, dp->name))
| 53 |
return(dp); /* found! */
| 54 |
| 55 |
* If we haven't loaded the data already, we will look
| 56 |
* for it in the directories specified by the library path.
| 57 |
| 58 |
* The file has the following format:
| 59 |
| 60 |
* N
| 61 |
* beg0 end0 n0
| 62 |
* beg1 end1 n1
| 63 |
| 64 |
* begN endN nN
| 65 |
* data, later dimensions changing faster
| 66 |
| 67 |
| 68 |
* For irregularly spaced points, the following can be
| 69 |
* substituted for begi endi ni:
| 70 |
| 71 |
* 0 0 ni p0i p1i .. pni
| 72 |
| 73 |
| 74 |
if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
| 75 |
sprintf(errmsg, "cannot find data file \"%s\"", dname);
| 76 |
error(SYSTEM, errmsg);
| 77 |
| 78 |
if ((fp = fopen(dfname, "r")) == NULL) {
| 79 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname);
| 80 |
| 81 |
| 82 |
/* get dimensions */
| 83 |
if (fgetval(fp, 'i', &asize) <= 0)
| 84 |
goto scanerr;
| 85 |
if ((asize <= 0) | (asize > MAXDDIM)) {
| 86 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
| 87 |
error(USER, errmsg);
| 88 |
| 89 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
| 90 |
goto memerr;
| 91 |
dp->name = savestr(dname);
| 92 |
dp->type = DATATY;
| 93 |
dp->nd = asize;
| 94 |
asize = 1;
| 95 |
for (i = 0; i < dp->nd; i++) {
| 96 |
if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
| 97 |
goto scanerr;
| 98 |
if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
| 99 |
goto scanerr;
| 100 |
if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
| 101 |
goto scanerr;
| 102 |
if (dp->dim[i].ne < 2)
| 103 |
goto scanerr;
| 104 |
asize *= dp->dim[i].ne;
| 105 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
| 106 |
dp->dim[i].p = (DATATYPE *)
| 107 |
malloc(dp->dim[i].ne*sizeof(DATATYPE));
| 108 |
if (dp->dim[i].p == NULL)
| 109 |
goto memerr;
| 110 |
for (j = 0; j < dp->dim[i].ne; j++)
| 111 |
if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
| 112 |
goto scanerr;
| 113 |
for (j = 1; j < dp->dim[i].ne-1; j++)
| 114 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
| 115 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1]))
| 116 |
goto scanerr;
| 117 |
dp->dim[i].org = dp->dim[i].p[0];
| 118 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
| 119 |
- dp->dim[i].p[0];
| 120 |
} else
| 121 |
dp->dim[i].p = NULL;
| 122 |
| 123 |
if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
| 124 |
goto memerr;
| 125 |
| 126 |
for (i = 0; i < asize; i++)
| 127 |
if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
| 128 |
goto scanerr;
| 129 |
fclose(fp);
| 130 |
i = hash(dname);
| 131 |
dp->next = dtab[i];
| 132 |
return(dtab[i] = dp);
| 133 |
memerr:
| 134 |
error(SYSTEM, "out of memory in getdata");
| 135 |
scanerr:
| 136 |
sprintf(errmsg, "%s in data file \"%s\"",
| 137 |
feof(fp) ? "unexpected EOF" : "bad format", dfname);
| 138 |
| 139 |
return NULL; /* pro forma return */
| 140 |
| 141 |
| 142 |
| 143 |
static int
| 144 |
headaspect( /* check string for aspect ratio */
| 145 |
char *s,
| 146 |
void *iap
| 147 |
| 148 |
| 149 |
char fmt[MAXFMTLEN];
| 150 |
| 151 |
if (isaspect(s))
| 152 |
*(double*)iap *= aspectval(s);
| 153 |
else if (formatval(fmt, s) && strcmp(fmt, COLRFMT))
| 154 |
*(double*)iap = 0.0;
| 155 |
return(0);
| 156 |
| 157 |
| 158 |
DATARRAY *
| 159 |
getpict( /* get picture pname */
| 160 |
char *pname
| 161 |
| 162 |
| 163 |
double inpaspect;
| 164 |
char *pfname;
| 165 |
FILE *fp;
| 166 |
COLR *scanin;
| 167 |
int sl, ns;
| 168 |
RESOLU inpres;
| 169 |
RREAL loc[2];
| 170 |
int y;
| 171 |
int x, i;
| 172 |
DATARRAY *pp;
| 173 |
| 174 |
for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
| 175 |
if (!strcmp(pname, pp->name))
| 176 |
return(pp); /* found! */
| 177 |
| 178 |
if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
| 179 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname);
| 180 |
| 181 |
| 182 |
if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
| 183 |
goto memerr;
| 184 |
| 185 |
pp[0].name = savestr(pname);
| 186 |
| 187 |
if ((fp = fopen(pfname, "rb")) == NULL) {
| 188 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
| 189 |
| 190 |
| 191 |
| 192 |
inpaspect = 1.0;
| 193 |
getheader(fp, headaspect, &inpaspect);
| 194 |
if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
| 195 |
goto readerr;
| 196 |
pp[0].nd = 2;
| 197 |
pp[0].dim[0].ne = inpres.yr;
| 198 |
pp[0].dim[1].ne = inpres.xr;
| 199 |
pp[0].dim[0].org =
| 200 |
pp[0].dim[1].org = 0.0;
| 201 |
if (inpres.xr <= inpres.yr*inpaspect) {
| 202 |
pp[0].dim[0].siz = inpaspect *
| 203 |
(double)inpres.yr/inpres.xr;
| 204 |
pp[0].dim[1].siz = 1.0;
| 205 |
} else {
| 206 |
pp[0].dim[0].siz = 1.0;
| 207 |
pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
| 208 |
inpaspect;
| 209 |
| 210 |
pp[0].dim[0].p = pp[0].dim[1].p = NULL;
| 211 |
sl = scanlen(&inpres); /* allocate array */
| 212 |
ns = numscans(&inpres);
| 213 |
i = ns*sl*sizeof(COLR);
| 214 |
#if PSIZWARN
| 215 |
if (i > PSIZWARN) { /* memory warning */
| 216 |
sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory",
| 217 |
pname, i*(1.0/(1024*1024)));
| 218 |
error(WARNING, errmsg);
| 219 |
| 220 |
#endif
| 221 |
if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
| 222 |
goto memerr;
| 223 |
/* load picture */
| 224 |
if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
| 225 |
goto memerr;
| 226 |
for (y = 0; y < ns; y++) {
| 227 |
if (freadcolrs(scanin, sl, fp) < 0)
| 228 |
goto readerr;
| 229 |
for (x = 0; x < sl; x++) {
| 230 |
pix2loc(loc, &inpres, x, y);
| 231 |
i = (int)(loc[1]*inpres.yr)*inpres.xr +
| 232 |
(int)(loc[0]*inpres.xr);
| 233 |
copycolr(pp[0].arr.c[i], scanin[x]);
| 234 |
| 235 |
| 236 |
free(scanin);
| 237 |
fclose(fp);
| 238 |
i = hash(pname);
| 239 |
pp[0].next = dtab[i]; /* link into picture list */
| 240 |
pp[1] = pp[0];
| 241 |
pp[2] = pp[0];
| 242 |
pp[0].type = RED; /* differentiate RGB records */
| 243 |
pp[1].type = GRN;
| 244 |
pp[2].type = BLU;
| 245 |
return(dtab[i] = pp);
| 246 |
memerr:
| 247 |
error(SYSTEM, "out of memory in getpict");
| 248 |
readerr:
| 249 |
sprintf(errmsg, "bad picture file \"%s\"", pfname);
| 250 |
| 251 |
| 252 |
| 253 |
| 254 |
| 255 |
/* header info type for hyperspectral image */
| 256 |
typedef struct {
| 257 |
float wlpart[4]; /* wavelength partitions */
| 258 |
int nc; /* number of components */
| 259 |
double inpaspect; /* pixel aspect ratio */
| 260 |
} SPECINFO;
| 261 |
| 262 |
static int
| 263 |
specheadline( /* get info for spectral image */
| 264 |
char *s,
| 265 |
void *cdp
| 266 |
| 267 |
| 268 |
SPECINFO *sip = (SPECINFO *)cdp;
| 269 |
| 270 |
| 271 |
if (isaspect(s))
| 272 |
sip->inpaspect *= aspectval(s);
| 273 |
else if (isncomp(s))
| 274 |
sip->nc = ncompval(s);
| 275 |
else if (iswlsplit(s))
| 276 |
wlsplitval(sip->wlpart, s);
| 277 |
else if (formatval(fmt, s) && strcmp(fmt, SPECFMT))
| 278 |
return(-1);
| 279 |
return(0);
| 280 |
| 281 |
| 282 |
DATARRAY *
| 283 |
getspec( /* load hyperspectral image as data */
| 284 |
char *sname
| 285 |
| 286 |
| 287 |
SPECINFO si;
| 288 |
char *pfname;
| 289 |
FILE *fp;
| 290 |
int sl, ns;
| 291 |
int y, i;
| 292 |
DATARRAY *pp;
| 293 |
| 294 |
for (pp = dtab[hash(sname)]; pp != NULL; pp = pp->next)
| 295 |
if (!strcmp(sname, pp->name))
| 296 |
| 297 |
| 298 |
if ((pfname = getpath(sname, getrlibpath(), R_OK)) == NULL) {
| 299 |
sprintf(errmsg, "cannot find hyperspectral image \"%s\"", sname);
| 300 |
| 301 |
| 302 |
| 303 |
sprintf(errmsg, "cannot open hyperspectral image \"%s\"", pfname);
| 304 |
| 305 |
| 306 |
si.wlpart[3] = 0;
| 307 |
si.nc = 0;
| 308 |
si.inpaspect = 1.0;
| 309 |
if (getheader(fp, specheadline, &si) < 0 ||
| 310 |
(si.nc <= 3) | (si.nc > MAXCSAMP) | (si.wlpart[3] < 1) ||
| 311 |
!fscnresolu(&sl, &ns, fp))
| 312 |
goto readerr;
| 313 |
| 314 |
if ((pp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
| 315 |
goto memerr;
| 316 |
| 317 |
pp->name = savestr(sname);
| 318 |
pp->type = SPECTY;
| 319 |
pp->nd = 3;
| 320 |
pp->dim[0].ne = ns;
| 321 |
pp->dim[1].ne = sl;
| 322 |
pp->dim[0].org =
| 323 |
pp->dim[1].org = 0.0;
| 324 |
if (sl <= ns*si.inpaspect) {
| 325 |
pp->dim[0].siz = si.inpaspect * (double)ns/sl;
| 326 |
pp->dim[1].siz = 1.0;
| 327 |
} else {
| 328 |
pp->dim[0].siz = 1.0;
| 329 |
pp->dim[1].siz = (double)sl/ns / si.inpaspect;
| 330 |
| 331 |
pp->dim[2].ne = si.nc;
| 332 |
pp->dim[2].siz = si.wlpart[3] - si.wlpart[0];
| 333 |
pp->dim[2].org = si.wlpart[0] + 0.5*pp->dim[2].siz/si.nc;
| 334 |
pp->dim[2].siz *= (si.nc - 1.0)/si.nc;
| 335 |
pp->dim[0].p = pp->dim[1].p = pp->dim[2].p = NULL;
| 336 |
i = ns*sl*(si.nc+1);
| 337 |
#if PSIZWARN
| 338 |
| 339 |
sprintf(errmsg, "hyperspectral image \"%s\" using %.1f MB of memory",
| 340 |
sname, i*(1.0/(1024*1024)));
| 341 |
| 342 |
| 343 |
#endif
| 344 |
if ((pp->arr.s = (uby8 *)malloc(i)) == NULL)
| 345 |
goto memerr;
| 346 |
for (y = ns; y-- > 0; ) /* read each scanline */
| 347 |
if (freadscolrs(pp->arr.s + y*sl*(si.nc+1), si.nc, sl, fp) < 0)
| 348 |
goto readerr;
| 349 |
fclose(fp);
| 350 |
i = hash(sname); /* insert in hash table */
| 351 |
pp->next = dtab[i];
| 352 |
| 353 |
memerr:
| 354 |
error(SYSTEM, "out of memory in getspec");
| 355 |
readerr:
| 356 |
sprintf(errmsg, "bad hyperspectral image \"%s\"", pfname);
| 357 |
| 358 |
| 359 |
| 360 |
| 361 |
| 362 |
void
| 363 |
freedata( /* release data array reference */
| 364 |
DATARRAY *dta
| 365 |
| 366 |
| 367 |
DATARRAY head;
| 368 |
int hval, nents;
| 369 |
DATARRAY *dpl, *dp;
| 370 |
int i;
| 371 |
| 372 |
if (dta == NULL) { /* free all if NULL */
| 373 |
hval = 0; nents = TABSIZ;
| 374 |
} else {
| 375 |
if (dta->next == dta) {
| 376 |
free(dta); /* unlisted temp array */
| 377 |
return;
| 378 |
| 379 |
hval = hash(dta->name); nents = 1;
| 380 |
if (!*dta->name) { /* not a data file? */
| 381 |
dta->next = dtab[hval];
| 382 |
dtab[hval] = dta; /* ...fake position */
| 383 |
| 384 |
| 385 |
while (nents--) {
| 386 |
head.next = dtab[hval];
| 387 |
dpl = &head;
| 388 |
while ((dp = dpl->next) != NULL)
| 389 |
if ((dta == NULL) | (dta == dp)) {
| 390 |
dpl->next = dp->next;
| 391 |
free(dp->arr.p);
| 392 |
| 393 |
if (dp->dim[i].p != NULL)
| 394 |
free(dp->dim[i].p);
| 395 |
freestr(dp->name);
| 396 |
free(dp);
| 397 |
} else
| 398 |
dpl = dp;
| 399 |
dtab[hval++] = head.next;
| 400 |
| 401 |
| 402 |
| 403 |
| 404 |
/* internal call to interpolate data value or vector */
| 405 |
static double
| 406 |
data_interp(DATARRAY *dp, double *pt, double coef, DATATYPE *rvec)
| 407 |
| 408 |
DATARRAY sd;
| 409 |
int stride, i;
| 410 |
double x, c0, c1, y0, y1;
| 411 |
/* unlikely, but may as well check */
| 412 |
if ((-FTINY <= coef) & (coef <= FTINY))
| 413 |
return(0.);
| 414 |
/* set up dimensions for recursion */
| 415 |
if (dp->nd > 1) {
| 416 |
sd.name = dp->name;
| 417 |
sd.type = dp->type;
| 418 |
sd.nd = dp->nd - 1;
| 419 |
memcpy(sd.dim, dp->dim+1, sd.nd*sizeof(struct dadim));
| 420 |
stride = sd.dim[i = sd.nd-1].ne + (sd.type==SPECTY);
| 421 |
while (i-- > 0)
| 422 |
stride *= sd.dim[i].ne;
| 423 |
| 424 |
/* get independent variable */
| 425 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */
| 426 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
| 427 |
x *= (double)(dp->dim[0].ne - 1);
| 428 |
i = x;
| 429 |
if (i < 0)
| 430 |
i = 0;
| 431 |
else if (i > dp->dim[0].ne - 2)
| 432 |
i = dp->dim[0].ne - 2;
| 433 |
} else { /* unevenly spaced points */
| 434 |
int lower, upper;
| 435 |
if (dp->dim[0].siz > 0.) {
| 436 |
lower = 0;
| 437 |
upper = dp->dim[0].ne;
| 438 |
} else {
| 439 |
lower = dp->dim[0].ne;
| 440 |
upper = 0;
| 441 |
| 442 |
do {
| 443 |
i = (lower + upper) >> 1;
| 444 |
if (pt[0] >= dp->dim[0].p[i])
| 445 |
lower = i;
| 446 |
else
| 447 |
upper = i;
| 448 |
} while (i != (lower + upper) >> 1);
| 449 |
| 450 |
| 451 |
| 452 |
| 453 |
x = i + (pt[0] - dp->dim[0].p[i]) /
| 454 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]);
| 455 |
| 456 |
| 457 |
* Compute interpolation coefficients:
| 458 |
* extrapolate as far as one division, then
| 459 |
* taper off harmonically to zero.
| 460 |
| 461 |
if (x > i+2) {
| 462 |
c0 = 1./(i-1 - x);
| 463 |
c1 = -2.*c0;
| 464 |
} else if (x < i-1) {
| 465 |
c1 = 1./(x - i);
| 466 |
c0 = -2.*c1;
| 467 |
} else {
| 468 |
c0 = i+1 - x;
| 469 |
c1 = x - i;
| 470 |
| 471 |
c0 *= coef;
| 472 |
c1 *= coef;
| 473 |
/* check if vector interp */
| 474 |
if ((dp->nd == 2) & (rvec != NULL)) {
| 475 |
if (dp->type == DATATY) {
| 476 |
sd.arr.d = dp->arr.d + i*stride;
| 477 |
for (i = sd.dim[0].ne; i--; )
| 478 |
rvec[i] += c0*sd.arr.d[i]
| 479 |
+ c1*sd.arr.d[i+stride];
| 480 |
} else if (dp->type == SPECTY) {
| 481 |
double f;
| 482 |
sd.arr.s = dp->arr.s + i*stride;
| 483 |
if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c0)|(c0>FTINY))) {
| 484 |
f = ldexp(c0, (int)sd.arr.s[sd.dim[0].ne]-(COLXS+8));
| 485 |
| 486 |
rvec[i] += f*(sd.arr.s[i] + .5);
| 487 |
| 488 |
sd.arr.s += stride;
| 489 |
if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c1)|(c1>FTINY))) {
| 490 |
f = ldexp(c1, (int)sd.arr.s[sd.dim[0].ne]-(COLXS+8));
| 491 |
| 492 |
| 493 |
| 494 |
} else {
| 495 |
sd.arr.c = dp->arr.c + i*stride;
| 496 |
| 497 |
rvec[i] += c0*colrval(sd.arr.c[i],sd.type)
| 498 |
+ c1*colrval(sd.arr.c[i+stride],sd.type);
| 499 |
| 500 |
return(0.); /* return value ignored */
| 501 |
| 502 |
/* get dependent variable */
| 503 |
if (dp->nd > 1) {
| 504 |
| 505 |
| 506 |
y0 = data_interp(&sd, pt+1, c0, rvec);
| 507 |
sd.arr.d += stride;
| 508 |
| 509 |
| 510 |
| 511 |
sd.arr.s += stride;
| 512 |
} else {
| 513 |
| 514 |
| 515 |
sd.arr.c += stride;
| 516 |
| 517 |
y1 = data_interp(&sd, pt+1, c1, rvec);
| 518 |
} else { /* end of recursion */
| 519 |
| 520 |
y0 = dp->arr.d[i];
| 521 |
y1 = dp->arr.d[i+1];
| 522 |
| 523 |
if (dp->arr.s[dp->dim[0].ne]) {
| 524 |
double f = dp->arr.s[dp->dim[0].ne]
| 525 |
? ldexp(1., -(COLXS+8) +
| 526 |
(int)dp->arr.s[dp->dim[0].ne])
| 527 |
: 0.;
| 528 |
y0 = f*(dp->arr.s[i] + 0.5);
| 529 |
y1 = f*(dp->arr.s[i+1] + 0.5);
| 530 |
} else
| 531 |
y0 = y1 = 0.;
| 532 |
} else {
| 533 |
y0 = colrval(dp->arr.c[i],dp->type);
| 534 |
y1 = colrval(dp->arr.c[i+1],dp->type);
| 535 |
| 536 |
y0 *= c0;
| 537 |
y1 *= c1;
| 538 |
| 539 |
return(y0 + y1); /* coefficients already applied */
| 540 |
| 541 |
| 542 |
| 543 |
double
| 544 |
datavalue( /* interpolate data value at a point */
| 545 |
DATARRAY *dp,
| 546 |
double *pt
| 547 |
| 548 |
| 549 |
return(data_interp(dp, pt, 1., NULL));
| 550 |
| 551 |
| 552 |
| 553 |
/* Interpolate final vector corresponding to last dimension in data array */
| 554 |
DATARRAY *
| 555 |
datavector(DATARRAY *dp, double *pt)
| 556 |
| 557 |
DATARRAY *newdp;
| 558 |
| 559 |
if (dp->nd < 2)
| 560 |
error(INTERNAL, "datavector() called with 1-D array");
| 561 |
/* create vector array */
| 562 |
newdp = (DATARRAY *)malloc(sizeof(DATARRAY) -
| 563 |
(MAXDDIM-1)*sizeof(struct dadim) +
| 564 |
sizeof(DATATYPE)*dp->dim[dp->nd-1].ne);
| 565 |
if (newdp == NULL)
| 566 |
error(SYSTEM, "out of memory in datavector");
| 567 |
newdp->next = newdp; /* flags us as temp vector */
| 568 |
newdp->name = dp->name;
| 569 |
newdp->type = DATATY;
| 570 |
newdp->nd = 1; /* vector data goes here */
| 571 |
newdp->dim[0] = dp->dim[dp->nd-1];
| 572 |
newdp->arr.d = (DATATYPE *)(newdp->dim + 1);
| 573 |
memset(newdp->arr.d, 0, sizeof(DATATYPE)*newdp->dim[0].ne);
| 574 |
| 575 |
(void)data_interp(dp, pt, 1., newdp->arr.d);
| 576 |
| 577 |
return(newdp); /* will be free'd using free() */
| 578 |
