root/radiance/ray/src/common/data.c
Revision: 2.4
Committed: Sun Mar 9 19:11:51 2025 UTC (8 weeks, 4 days ago) by greg
Changes since 2.3: +6 -12 lines
perf: Eliminated calls to ldexp() in favor of exponent multiplier table
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.4 static const char RCSid[] = "$Id: data.c,v 2.3 2025/02/28 21:07:18 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * data.c - routines dealing with interpolated data.
6     */
7
8     #include "copyright.h"
9
10     #include <time.h>
11
12     #include "platform.h"
13     #include "paths.h"
14     #include "standard.h"
15     #include "color.h"
16     #include "view.h"
17     #include "data.h"
18
19     /* picture memory usage before warning */
20     #ifndef PSIZWARN
21     #ifdef SMLMEM
22     #define PSIZWARN 3000000
23     #else
24     #define PSIZWARN 50000000
25     #endif
26     #endif
27
28     #ifndef TABSIZ
29     #define TABSIZ 997 /* table size (prime) */
30     #endif
31
32     #define hash(s) (shash(s)%TABSIZ)
33
34
35     static DATARRAY *dtab[TABSIZ]; /* data array list */
36
37     static gethfunc headaspect;
38
39
40     DATARRAY *
41     getdata( /* get data array dname */
42     char *dname
43     )
44     {
45     char *dfname;
46     FILE *fp;
47     int asize=0;
48     int i, j;
49     DATARRAY *dp;
50     /* look for array in list */
51     for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
52     if (!strcmp(dname, dp->name))
53     return(dp); /* found! */
54     /*
55     * If we haven't loaded the data already, we will look
56     * for it in the directories specified by the library path.
57     *
58     * The file has the following format:
59     *
60     * N
61     * beg0 end0 n0
62     * beg1 end1 n1
63     * . . .
64     * begN endN nN
65     * data, later dimensions changing faster
66     * . . .
67     *
68     * For irregularly spaced points, the following can be
69     * substituted for begi endi ni:
70     *
71     * 0 0 ni p0i p1i .. pni
72     */
73
74     if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
75     sprintf(errmsg, "cannot find data file \"%s\"", dname);
76     error(SYSTEM, errmsg);
77     }
78     if ((fp = fopen(dfname, "r")) == NULL) {
79     sprintf(errmsg, "cannot open data file \"%s\"", dfname);
80     error(SYSTEM, errmsg);
81     }
82     /* get dimensions */
83     if (fgetval(fp, 'i', &asize) <= 0)
84     goto scanerr;
85     if ((asize <= 0) | (asize > MAXDDIM)) {
86     sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
87     error(USER, errmsg);
88     }
89     if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
90     goto memerr;
91     dp->name = savestr(dname);
92     dp->type = DATATY;
93     dp->nd = asize;
94     asize = 1;
95     for (i = 0; i < dp->nd; i++) {
96     if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
97     goto scanerr;
98     if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
99     goto scanerr;
100     if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
101     goto scanerr;
102     if (dp->dim[i].ne < 2)
103     goto scanerr;
104     asize *= dp->dim[i].ne;
105     if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
106     dp->dim[i].p = (DATATYPE *)
107     malloc(dp->dim[i].ne*sizeof(DATATYPE));
108     if (dp->dim[i].p == NULL)
109     goto memerr;
110     for (j = 0; j < dp->dim[i].ne; j++)
111     if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
112     goto scanerr;
113     for (j = 1; j < dp->dim[i].ne-1; j++)
114     if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
115     (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
116     goto scanerr;
117     dp->dim[i].org = dp->dim[i].p[0];
118     dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
119     - dp->dim[i].p[0];
120     } else
121     dp->dim[i].p = NULL;
122     }
123     if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
124     goto memerr;
125
126     for (i = 0; i < asize; i++)
127     if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
128     goto scanerr;
129     fclose(fp);
130     i = hash(dname);
131     dp->next = dtab[i];
132     return(dtab[i] = dp);
133     memerr:
134     error(SYSTEM, "out of memory in getdata");
135     scanerr:
136     sprintf(errmsg, "%s in data file \"%s\"",
137     feof(fp) ? "unexpected EOF" : "bad format", dfname);
138     error(USER, errmsg);
139     return NULL; /* pro forma return */
140     }
141
142
143     static int
144     headaspect( /* check string for aspect ratio */
145     char *s,
146     void *iap
147     )
148     {
149     char fmt[MAXFMTLEN];
150
151     if (isaspect(s))
152     *(double*)iap *= aspectval(s);
153     else if (formatval(fmt, s) && strcmp(fmt, COLRFMT))
154     *(double*)iap = 0.0;
155     return(0);
156     }
157
158     DATARRAY *
159     getpict( /* get picture pname */
160     char *pname
161     )
162     {
163     double inpaspect;
164     char *pfname;
165     FILE *fp;
166     COLR *scanin;
167     int sl, ns;
168     RESOLU inpres;
169     RREAL loc[2];
170     int y;
171     int x, i;
172     DATARRAY *pp;
173     /* look for array in list */
174     for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
175     if (!strcmp(pname, pp->name))
176     return(pp); /* found! */
177
178     if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
179     sprintf(errmsg, "cannot find picture file \"%s\"", pname);
180     error(SYSTEM, errmsg);
181     }
182     if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
183     goto memerr;
184
185     pp[0].name = savestr(pname);
186
187     if ((fp = fopen(pfname, "rb")) == NULL) {
188     sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
189     error(SYSTEM, errmsg);
190     }
191     /* get dimensions */
192     inpaspect = 1.0;
193     getheader(fp, headaspect, &inpaspect);
194     if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
195     goto readerr;
196     pp[0].nd = 2;
197     pp[0].dim[0].ne = inpres.yr;
198     pp[0].dim[1].ne = inpres.xr;
199     pp[0].dim[0].org =
200     pp[0].dim[1].org = 0.0;
201     if (inpres.xr <= inpres.yr*inpaspect) {
202     pp[0].dim[0].siz = inpaspect *
203     (double)inpres.yr/inpres.xr;
204     pp[0].dim[1].siz = 1.0;
205     } else {
206     pp[0].dim[0].siz = 1.0;
207     pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
208     inpaspect;
209     }
210     pp[0].dim[0].p = pp[0].dim[1].p = NULL;
211     sl = scanlen(&inpres); /* allocate array */
212     ns = numscans(&inpres);
213     i = ns*sl*sizeof(COLR);
214     #if PSIZWARN
215     if (i > PSIZWARN) { /* memory warning */
216     sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory",
217     pname, i*(1.0/(1024*1024)));
218     error(WARNING, errmsg);
219     }
220     #endif
221     if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
222     goto memerr;
223     /* load picture */
224     if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
225     goto memerr;
226     for (y = 0; y < ns; y++) {
227     if (freadcolrs(scanin, sl, fp) < 0)
228     goto readerr;
229     for (x = 0; x < sl; x++) {
230     pix2loc(loc, &inpres, x, y);
231     i = (int)(loc[1]*inpres.yr)*inpres.xr +
232     (int)(loc[0]*inpres.xr);
233     copycolr(pp[0].arr.c[i], scanin[x]);
234     }
235     }
236     free(scanin);
237     fclose(fp);
238     i = hash(pname);
239     pp[0].next = dtab[i]; /* link into picture list */
240     pp[1] = pp[0];
241     pp[2] = pp[0];
242     pp[0].type = RED; /* differentiate RGB records */
243     pp[1].type = GRN;
244     pp[2].type = BLU;
245     return(dtab[i] = pp);
246     memerr:
247     error(SYSTEM, "out of memory in getpict");
248     readerr:
249     sprintf(errmsg, "bad picture file \"%s\"", pfname);
250     error(USER, errmsg);
251     return NULL; /* pro forma return */
252     }
253
254
255     /* header info type for hyperspectral image */
256     typedef struct {
257     float wlpart[4]; /* wavelength partitions */
258     int nc; /* number of components */
259     double inpaspect; /* pixel aspect ratio */
260     } SPECINFO;
261
262     static int
263     specheadline( /* get info for spectral image */
264     char *s,
265     void *cdp
266     )
267     {
268     SPECINFO *sip = (SPECINFO *)cdp;
269     char fmt[MAXFMTLEN];
270
271     if (isaspect(s))
272     sip->inpaspect *= aspectval(s);
273     else if (isncomp(s))
274     sip->nc = ncompval(s);
275     else if (iswlsplit(s))
276     wlsplitval(sip->wlpart, s);
277     else if (formatval(fmt, s) && strcmp(fmt, SPECFMT))
278     return(-1);
279     return(0);
280     }
281
282     DATARRAY *
283     getspec( /* load hyperspectral image as data */
284     char *sname
285     )
286     {
287     SPECINFO si;
288     char *pfname;
289     FILE *fp;
290     int sl, ns;
291     int y, i;
292     DATARRAY *pp;
293     /* look for array in list */
294     for (pp = dtab[hash(sname)]; pp != NULL; pp = pp->next)
295     if (!strcmp(sname, pp->name))
296     return(pp); /* found! */
297
298     if ((pfname = getpath(sname, getrlibpath(), R_OK)) == NULL) {
299     sprintf(errmsg, "cannot find hyperspectral image \"%s\"", sname);
300     error(SYSTEM, errmsg);
301     }
302     if ((fp = fopen(pfname, "rb")) == NULL) {
303     sprintf(errmsg, "cannot open hyperspectral image \"%s\"", pfname);
304     error(SYSTEM, errmsg);
305     }
306     si.wlpart[3] = 0;
307     si.nc = 0;
308     si.inpaspect = 1.0;
309     if (getheader(fp, specheadline, &si) < 0 ||
310     (si.nc <= 3) | (si.nc > MAXCSAMP) | (si.wlpart[3] < 1) ||
311     !fscnresolu(&sl, &ns, fp))
312     goto readerr;
313
314     if ((pp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
315     goto memerr;
316
317     pp->name = savestr(sname);
318     pp->type = SPECTY;
319     pp->nd = 3;
320     pp->dim[0].ne = ns;
321     pp->dim[1].ne = sl;
322     pp->dim[0].org =
323     pp->dim[1].org = 0.0;
324     if (sl <= ns*si.inpaspect) {
325     pp->dim[0].siz = si.inpaspect * (double)ns/sl;
326     pp->dim[1].siz = 1.0;
327     } else {
328     pp->dim[0].siz = 1.0;
329     pp->dim[1].siz = (double)sl/ns / si.inpaspect;
330     }
331     pp->dim[2].ne = si.nc;
332     pp->dim[2].siz = si.wlpart[3] - si.wlpart[0];
333     pp->dim[2].org = si.wlpart[0] + 0.5*pp->dim[2].siz/si.nc;
334     pp->dim[2].siz *= (si.nc - 1.0)/si.nc;
335     pp->dim[0].p = pp->dim[1].p = pp->dim[2].p = NULL;
336     i = ns*sl*(si.nc+1);
337     #if PSIZWARN
338     if (i > PSIZWARN) { /* memory warning */
339     sprintf(errmsg, "hyperspectral image \"%s\" using %.1f MB of memory",
340     sname, i*(1.0/(1024*1024)));
341     error(WARNING, errmsg);
342     }
343     #endif
344     if ((pp->arr.s = (uby8 *)malloc(i)) == NULL)
345     goto memerr;
346 greg 2.2 for (y = ns; y-- > 0; ) /* read each scanline */
347 greg 2.1 if (freadscolrs(pp->arr.s + y*sl*(si.nc+1), si.nc, sl, fp) < 0)
348     goto readerr;
349     fclose(fp);
350     i = hash(sname); /* insert in hash table */
351     pp->next = dtab[i];
352     return(dtab[i] = pp);
353     memerr:
354     error(SYSTEM, "out of memory in getspec");
355     readerr:
356     sprintf(errmsg, "bad hyperspectral image \"%s\"", pfname);
357     error(USER, errmsg);
358     return NULL; /* pro forma return */
359     }
360
361
362     void
363     freedata( /* release data array reference */
364     DATARRAY *dta
365     )
366     {
367     DATARRAY head;
368     int hval, nents;
369     DATARRAY *dpl, *dp;
370     int i;
371
372     if (dta == NULL) { /* free all if NULL */
373     hval = 0; nents = TABSIZ;
374     } else {
375     if (dta->next == dta) {
376     free(dta); /* unlisted temp array */
377     return;
378     }
379     hval = hash(dta->name); nents = 1;
380     if (!*dta->name) { /* not a data file? */
381     dta->next = dtab[hval];
382     dtab[hval] = dta; /* ...fake position */
383     }
384     }
385     while (nents--) {
386     head.next = dtab[hval];
387     dpl = &head;
388     while ((dp = dpl->next) != NULL)
389     if ((dta == NULL) | (dta == dp)) {
390     dpl->next = dp->next;
391     free(dp->arr.p);
392     for (i = 0; i < dp->nd; i++)
393     if (dp->dim[i].p != NULL)
394     free(dp->dim[i].p);
395     freestr(dp->name);
396     free(dp);
397     } else
398     dpl = dp;
399     dtab[hval++] = head.next;
400     }
401     }
402
403
404     /* internal call to interpolate data value or vector */
405     static double
406     data_interp(DATARRAY *dp, double *pt, double coef, DATATYPE *rvec)
407     {
408     DATARRAY sd;
409     int stride, i;
410     double x, c0, c1, y0, y1;
411     /* unlikely, but may as well check */
412     if ((-FTINY <= coef) & (coef <= FTINY))
413     return(0.);
414     /* set up dimensions for recursion */
415     if (dp->nd > 1) {
416     sd.name = dp->name;
417     sd.type = dp->type;
418     sd.nd = dp->nd - 1;
419     memcpy(sd.dim, dp->dim+1, sd.nd*sizeof(struct dadim));
420     stride = sd.dim[i = sd.nd-1].ne + (sd.type==SPECTY);
421     while (i-- > 0)
422     stride *= sd.dim[i].ne;
423     }
424     /* get independent variable */
425     if (dp->dim[0].p == NULL) { /* evenly spaced points */
426     x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
427     x *= (double)(dp->dim[0].ne - 1);
428     i = x;
429     if (i < 0)
430     i = 0;
431     else if (i > dp->dim[0].ne - 2)
432     i = dp->dim[0].ne - 2;
433     } else { /* unevenly spaced points */
434     int lower, upper;
435     if (dp->dim[0].siz > 0.) {
436     lower = 0;
437     upper = dp->dim[0].ne;
438     } else {
439     lower = dp->dim[0].ne;
440     upper = 0;
441     }
442     do {
443     i = (lower + upper) >> 1;
444     if (pt[0] >= dp->dim[0].p[i])
445     lower = i;
446     else
447     upper = i;
448     } while (i != (lower + upper) >> 1);
449
450     if (i > dp->dim[0].ne - 2)
451     i = dp->dim[0].ne - 2;
452
453     x = i + (pt[0] - dp->dim[0].p[i]) /
454     (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
455     }
456     /*
457     * Compute interpolation coefficients:
458     * extrapolate as far as one division, then
459     * taper off harmonically to zero.
460     */
461     if (x > i+2) {
462     c0 = 1./(i-1 - x);
463     c1 = -2.*c0;
464     } else if (x < i-1) {
465 greg 2.3 c1 = 1./(x - i);
466 greg 2.1 c0 = -2.*c1;
467     } else {
468     c0 = i+1 - x;
469     c1 = x - i;
470     }
471     c0 *= coef;
472     c1 *= coef;
473     /* check if vector interp */
474     if ((dp->nd == 2) & (rvec != NULL)) {
475     if (dp->type == DATATY) {
476     sd.arr.d = dp->arr.d + i*stride;
477     for (i = sd.dim[0].ne; i--; )
478     rvec[i] += c0*sd.arr.d[i]
479     + c1*sd.arr.d[i+stride];
480     } else if (dp->type == SPECTY) {
481     double f;
482     sd.arr.s = dp->arr.s + i*stride;
483     if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c0)|(c0>FTINY))) {
484 greg 2.4 f = c0 * cxponent[sd.arr.s[sd.dim[0].ne]];
485 greg 2.1 for (i = sd.dim[0].ne; i--; )
486     rvec[i] += f*(sd.arr.s[i] + .5);
487     }
488     sd.arr.s += stride;
489     if ((sd.arr.s[sd.dim[0].ne] > 0) & ((-FTINY>c1)|(c1>FTINY))) {
490 greg 2.4 f = c1 * cxponent[sd.arr.s[sd.dim[0].ne]];
491 greg 2.1 for (i = sd.dim[0].ne; i--; )
492     rvec[i] += f*(sd.arr.s[i] + .5);
493     }
494     } else {
495     sd.arr.c = dp->arr.c + i*stride;
496     for (i = sd.dim[0].ne; i--; )
497     rvec[i] += c0*colrval(sd.arr.c[i],sd.type)
498     + c1*colrval(sd.arr.c[i+stride],sd.type);
499     }
500     return(0.); /* return value ignored */
501     }
502     /* get dependent variable */
503     if (dp->nd > 1) {
504     if (dp->type == DATATY) {
505     sd.arr.d = dp->arr.d + i*stride;
506     y0 = data_interp(&sd, pt+1, c0, rvec);
507     sd.arr.d += stride;
508     } else if (dp->type == SPECTY) {
509     sd.arr.s = dp->arr.s + i*stride;
510     y0 = data_interp(&sd, pt+1, c0, rvec);
511     sd.arr.s += stride;
512     } else {
513     sd.arr.c = dp->arr.c + i*stride;
514     y0 = data_interp(&sd, pt+1, c0, rvec);
515     sd.arr.c += stride;
516     }
517     y1 = data_interp(&sd, pt+1, c1, rvec);
518     } else { /* end of recursion */
519     if (dp->type == DATATY) {
520     y0 = dp->arr.d[i];
521     y1 = dp->arr.d[i+1];
522     } else if (dp->type == SPECTY) {
523 greg 2.4 double f = cxponent[dp->arr.s[dp->dim[0].ne]];
524     y0 = f*(dp->arr.s[i] + 0.5);
525     y1 = f*(dp->arr.s[i+1] + 0.5);
526 greg 2.1 } else {
527     y0 = colrval(dp->arr.c[i],dp->type);
528     y1 = colrval(dp->arr.c[i+1],dp->type);
529     }
530     y0 *= c0;
531     y1 *= c1;
532     }
533     return(y0 + y1); /* coefficients already applied */
534     }
535
536
537     double
538     datavalue( /* interpolate data value at a point */
539     DATARRAY *dp,
540     double *pt
541     )
542     {
543     return(data_interp(dp, pt, 1., NULL));
544     }
545
546
547     /* Interpolate final vector corresponding to last dimension in data array */
548     DATARRAY *
549     datavector(DATARRAY *dp, double *pt)
550     {
551     DATARRAY *newdp;
552
553     if (dp->nd < 2)
554     error(INTERNAL, "datavector() called with 1-D array");
555     /* create vector array */
556     newdp = (DATARRAY *)malloc(sizeof(DATARRAY) -
557     (MAXDDIM-1)*sizeof(struct dadim) +
558     sizeof(DATATYPE)*dp->dim[dp->nd-1].ne);
559     if (newdp == NULL)
560     error(SYSTEM, "out of memory in datavector");
561     newdp->next = newdp; /* flags us as temp vector */
562     newdp->name = dp->name;
563     newdp->type = DATATY;
564     newdp->nd = 1; /* vector data goes here */
565     newdp->dim[0] = dp->dim[dp->nd-1];
566     newdp->arr.d = (DATATYPE *)(newdp->dim + 1);
567     memset(newdp->arr.d, 0, sizeof(DATATYPE)*newdp->dim[0].ne);
568
569     (void)data_interp(dp, pt, 1., newdp->arr.d);
570
571     return(newdp); /* will be free'd using free() */
572     }
