root/radiance/ray/src/common/convertobj.c
Tue Jun 3 21:31:51 2025 UTC (2 days, 18 hours ago) by greg
Changes since 2.6: +1 -2 lines
Sat Apr 17 14:51:33 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.5: +5 -10 lines
fix: vertex swapping code was missing face list pointer
Fri Apr 16 15:18:33 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.4: +17 -11 lines
fix: added handling of 32-bit RREAL
Thu Apr 15 23:51:04 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.3: +108 -6 lines
Thu Apr 23 22:35:27 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.2: +12 -8 lines
Made error reporting and return value more consistent
Thu Apr 23 03:19:48 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 2.1
Fix for missing popen() in Windows
Mon Mar 30 18:28:35 2020 UTC (5 years, 2 months ago) by greg
