root/radiance/ray/src/common/convertobj.c
Revision: 2.5
Committed: Fri Apr 16 15:18:33 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.4: +17 -11 lines
fix: added handling of 32-bit RREAL
2 static const char RCSid[] = "$Id: convertobj.c,v 2.4 2021/04/15 23:51:04 greg Exp $";
5 * convertobj.c
6 *
7 * Convert .OBJ scene to Radiance
8 *
9 * Created by Greg Ward on Thu Apr 22 2004.
10 */
11
12 #include "paths.h"
13 #include "fvect.h"
14 #include "tmesh.h"
15 #include "rterror.h"
16 #include "objutil.h"
17
18 #define TEXNAME "T-nor"
19
20 static int fcnt = 0; /* face output counter */
21
22 /* Callback for face smoothing detection */
23 static int
24 checksmooth(Scene *sc, Face *f, void *ptr)
25 {
26 int nrev = 0;
27 Normal fnrm;
28 int i;
29
30 f->flags &= ~FACE_RESERVED; /* using reserved flag */
31
32 for (i = f->nv; i--; )
33 if (f->v[i].nid < 0)
34 return(0); /* missing normal */
35
36 if (faceArea(sc, f, fnrm) == 0) /* degenerate?? */
37 return(0);
38 /* check each normal */
39 for (i = f->nv; i--; ) {
40 float *tnrm = sc->norm[f->v[i].nid];
41 double dprod = DOT(tnrm, fnrm);
42 if (dprod >= COSTOL) /* this one agrees? */
43 continue;
44 if (dprod > -COSTOL) /* active smoothing? */
45 break;
46 ++nrev; /* count opposite face normal */
47 }
48 if ((i < 0) & !nrev) /* all normals agree w/ face? */
49 return(0);
50 if (nrev == f->nv) { /* all reversed? */
51 for (i = f->nv; i--; ) /* remove normal indices */
52 f->v[i].nid = -1;
53 for (i = f->nv/2; i--; ) { /* and swap others around */
54 int j = f->nv-1 - i;
55 int vi = f->v[i].vid;
56 int ti = f->v[i].tid;
57 f->v[i].vid = f->v[j].vid;
58 f->v[i].tid = f->v[j].tid;
59 f->v[j].vid = vi;
60 f->v[j].tid = ti;
61 }
62 return(0);
63 }
64 f->flags |= FACE_RESERVED; /* else we got one to smooth */
65 return(1);
66 }
67
68 /* Callback to write out smoothed Radiance triangle */
69 static int
70 trismooth(Scene *sc, Face *f, void *ptr)
71 {
72 FILE *fp = (FILE *)ptr;
73 BARYCCM bcm;
74 FVECT coor[3];
75 int i;
76
77 if (f->nv != 3)
78 return(0); /* should never happen */
79 #ifdef SMLFLT
80 for (i = 3; i--; ) {
81 double *v = sc->vert[f->v[i].vid].p;
82 VCOPY(coor[i], v);
83 }
84 if (comp_baryc(&bcm, coor[0], coor[1], coor[2]) < 0)
85 return(0); /* degenerate?? */
86 #else
87 if (comp_baryc(&bcm, sc->vert[f->v[0].vid].p,
88 sc->vert[f->v[1].vid].p, sc->vert[f->v[2].vid].p) < 0)
89 return(0); /* degenerate?? */
90 #endif
91 for (i = 3; i--; ) { /* assign BC normals */
92 float *tnrm = sc->norm[f->v[i].nid];
93 coor[0][i] = tnrm[0];
94 coor[1][i] = tnrm[1];
95 coor[2][i] = tnrm[2];
96 } /* print texture */
97 fprintf(fp, "\n%s texfunc %s\n4 dx dy dz %s\n0\n",
98 sc->matname[f->mat], TEXNAME, TCALNAME);
99 fput_baryc(&bcm, coor, 3, fp); /* with BC normals */
100 fprintf(fp, "\n%s polygon %s.%d\n0\n0\n9\n",
101 TEXNAME, sc->grpname[f->grp], ++fcnt);
102 for (i = 0; i < 3; i++) { /* then triangle */
103 double *v = sc->vert[f->v[i].vid].p;
104 fprintf(fp, "\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
105 }
106 return(1);
107 }
108
109 /* Callback to convert face to Radiance */
110 static int
111 radface(Scene *sc, Face *f, void *ptr)
112 {
113 FILE *fp = (FILE *)ptr;
114 int i;
115
116 fprintf(fp, "\n%s polygon %s.%d\n0\n0\n%d\n", sc->matname[f->mat],
117 sc->grpname[f->grp], ++fcnt, 3*f->nv);
118 for (i = 0; i < f->nv; i++) {
119 Vertex *vp = sc->vert + f->v[i].vid;
120 fprintf(fp, "\t%18.12g %18.12g %18.12g\n",
121 vp->p[0], vp->p[1], vp->p[2]);
122 }
123 return(1);
124 }
125
126 /* Convert indicated faces to Radiance, return # written or -1 on error */
127 int
128 toRadiance(Scene *sc, FILE *fp, int flreq, int flexc)
129 {
130 int n;
131
132 if (sc == NULL || sc->nfaces <= 0 || fp == NULL)
133 return(0);
134 /* not passing empties */
135 flexc |= FACE_DEGENERATE;
136 /* reset counter if not stdout */
137 fcnt *= (fp == stdout);
138 /* write comments */
139 for (n = 0; n < sc->ndescr; n++)
140 fprintf(fp, "# %s\n", sc->descr[n]);
141 /* flag faces to smooth */
142 n = foreachFace(sc, checksmooth, flreq, flexc, NULL);
143 if (n > 0) { /* write smooth faces */
144 Scene *smoothies = dupScene(sc, flreq|FACE_RESERVED, flexc);
145 if (!smoothies)
146 return(-1);
147 n = triangulateScene(smoothies);
148 if (n >= 0)
149 n = foreachFace(smoothies, trismooth, 0, 0, fp);
150 freeScene(smoothies);
151 }
152 if (n < 0)
153 return(-1);
154 /* write flat faces */
155 n += foreachFace(sc, radface, flreq, flexc|FACE_RESERVED, fp);
156
157 if (fflush(fp) < 0) {
158 error(SYSTEM, "Error writing Radiance scene data");
159 return(-1);
160 }
161 return(n);
162 }
163
164 /* Convert faces to Radiance file, return # written or -1 on error */
165 int
166 writeRadiance(Scene *sc, const char *fspec, int flreq, int flexc)
167 {
168 extern char *progname;
169 FILE *fp;
170 int n;
171
172 if (sc == NULL || sc->nfaces <= 0 || fspec == NULL || !*fspec)
173 return(0);
174 #if POPEN_SUPPORT
175 if (fspec[0] == '!') {
176 if ((fp = popen(fspec+1, "w")) == NULL) {
177 sprintf(errmsg, "%s: cannot execute", fspec);
178 error(SYSTEM, errmsg);
179 return(-1);
180 }
181 } else
182 #endif
183 if ((fp = fopen(fspec, "w")) == NULL) {
184 sprintf(errmsg, "%s: cannot open for writing", fspec);
185 error(SYSTEM, errmsg);
186 return(-1);
187 }
188 /* start off header */
189 fprintf(fp, "# Radiance scene file converted from .OBJ by %s\n#\n",
190 progname);
191 n = toRadiance(sc, fp, flreq, flexc); /* write file */
192 #if POPEN_SUPPORT
193 if (fspec[0] == '!') {
194 if (pclose(fp)) {
195 sprintf(errmsg, "%s: error writing to command\n", fspec);
196 error(SYSTEM, errmsg);
197 return(-1);
198 }
199 } else
200 #endif
201 fclose(fp); /* close it (already flushed) */
202 return(n);
203 }
