root/Development/ray/src/common/convertobj.c
Revision: 2.7
Committed: Tue Jun 3 21:31:51 2025 UTC (6 months, 4 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.6: +1 -2 lines
2 static const char RCSid[] = "$Id: convertobj.c,v 2.6 2021/04/17 14:51:33 greg Exp $";
5 * convertobj.c
6 *
7 * Convert .OBJ scene to Radiance
8 *
9 * Created by Greg Ward on Thu Apr 22 2004.
10 */
11
12 #include "paths.h"
13 #include "fvect.h"
14 #include "tmesh.h"
15 #include "rterror.h"
16 #include "objutil.h"
17
18 #define TEXNAME "T-nor"
19
20 static int fcnt = 0; /* face output counter */
21
22 /* Callback for face smoothing detection */
23 static int
24 checksmooth(Scene *sc, Face *f, void *ptr)
25 {
26 int nrev = 0;
27 Normal fnrm;
28 int i;
29
30 f->flags &= ~FACE_RESERVED; /* using reserved flag */
31
32 for (i = f->nv; i--; )
33 if (f->v[i].nid < 0)
34 return(0); /* missing normal */
35
36 if (faceArea(sc, f, fnrm) == 0) /* degenerate?? */
37 return(0);
38 /* check each normal */
39 for (i = f->nv; i--; ) {
40 float *tnrm = sc->norm[f->v[i].nid];
41 double dprod = DOT(tnrm, fnrm);
42 if (dprod >= COSTOL) /* this one agrees? */
43 continue;
44 if (dprod > -COSTOL) /* active smoothing? */
45 break;
46 ++nrev; /* count opposite face normal */
47 }
48 if ((i < 0) & !nrev) /* all normals agree w/ face? */
49 return(0);
50 if (nrev == f->nv) { /* all reversed? */
51 for (i = f->nv/2; i--; ) { /* swap vertices around */
52 int j = f->nv-1 - i;
53 VertEnt tve = f->v[i];
54 f->v[i] = f->v[j];
55 f->v[j] = tve;
56 }
57 return(0);
58 }
59 f->flags |= FACE_RESERVED; /* else we got one to smooth */
60 return(1);
61 }
62
63 /* Callback to write out smoothed Radiance triangle */
64 static int
65 trismooth(Scene *sc, Face *f, void *ptr)
66 {
67 FILE *fp = (FILE *)ptr;
68 BARYCCM bcm;
69 FVECT coor[3];
70 int i;
71
72 if (f->nv != 3)
73 return(0); /* should never happen */
74 #ifdef SMLFLT
75 for (i = 3; i--; ) {
76 double *v = sc->vert[f->v[i].vid].p;
77 VCOPY(coor[i], v);
78 }
79 if (comp_baryc(&bcm, coor[0], coor[1], coor[2]) < 0)
80 return(0); /* degenerate?? */
81 #else
82 if (comp_baryc(&bcm, sc->vert[f->v[0].vid].p,
83 sc->vert[f->v[1].vid].p, sc->vert[f->v[2].vid].p) < 0)
84 return(0); /* degenerate?? */
85 #endif
86 for (i = 3; i--; ) { /* assign BC normals */
87 float *tnrm = sc->norm[f->v[i].nid];
88 coor[0][i] = tnrm[0];
89 coor[1][i] = tnrm[1];
90 coor[2][i] = tnrm[2];
91 } /* print texture */
92 fprintf(fp, "\n%s texfunc %s\n4 dx dy dz %s\n0\n",
93 sc->matname[f->mat], TEXNAME, TCALNAME);
94 fput_baryc(&bcm, coor, 3, fp); /* with BC normals */
95 fprintf(fp, "\n%s polygon %s.%d\n0\n0\n9\n",
96 TEXNAME, sc->grpname[f->grp], ++fcnt);
97 for (i = 0; i < 3; i++) { /* then triangle */
98 double *v = sc->vert[f->v[i].vid].p;
99 fprintf(fp, "\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
100 }
101 return(1);
102 }
103
104 /* Callback to convert face to Radiance */
105 static int
106 radface(Scene *sc, Face *f, void *ptr)
107 {
108 FILE *fp = (FILE *)ptr;
109 int i;
110
111 fprintf(fp, "\n%s polygon %s.%d\n0\n0\n%d\n", sc->matname[f->mat],
112 sc->grpname[f->grp], ++fcnt, 3*f->nv);
113 for (i = 0; i < f->nv; i++) {
114 Vertex *vp = sc->vert + f->v[i].vid;
115 fprintf(fp, "\t%18.12g %18.12g %18.12g\n",
116 vp->p[0], vp->p[1], vp->p[2]);
117 }
118 return(1);
119 }
120
121 /* Convert indicated faces to Radiance, return # written or -1 on error */
122 int
123 toRadiance(Scene *sc, FILE *fp, int flreq, int flexc)
124 {
125 int n;
126
127 if (sc == NULL || sc->nfaces <= 0 || fp == NULL)
128 return(0);
129 /* not passing empties */
130 flexc |= FACE_DEGENERATE;
131 /* reset counter if not stdout */
132 fcnt *= (fp == stdout);
133 /* write comments */
134 for (n = 0; n < sc->ndescr; n++)
135 fprintf(fp, "# %s\n", sc->descr[n]);
136 /* flag faces to smooth */
137 n = foreachFace(sc, checksmooth, flreq, flexc, NULL);
138 if (n > 0) { /* write smooth faces */
139 Scene *smoothies = dupScene(sc, flreq|FACE_RESERVED, flexc);
140 if (!smoothies)
141 return(-1);
142 n = triangulateScene(smoothies);
143 if (n >= 0)
144 n = foreachFace(smoothies, trismooth, 0, 0, fp);
145 freeScene(smoothies);
146 }
147 if (n < 0)
148 return(-1);
149 /* write flat faces */
150 n += foreachFace(sc, radface, flreq, flexc|FACE_RESERVED, fp);
151
152 if (fflush(fp) < 0) {
153 error(SYSTEM, "Error writing Radiance scene data");
154 return(-1);
155 }
156 return(n);
157 }
158
159 /* Convert faces to Radiance file, return # written or -1 on error */
160 int
161 writeRadiance(Scene *sc, const char *fspec, int flreq, int flexc)
162 {
163 FILE *fp;
164 int n;
165
166 if (sc == NULL || sc->nfaces <= 0 || fspec == NULL || !*fspec)
167 return(0);
168 #if POPEN_SUPPORT
169 if (fspec[0] == '!') {
170 if ((fp = popen(fspec+1, "w")) == NULL) {
171 sprintf(errmsg, "%s: cannot execute", fspec);
172 error(SYSTEM, errmsg);
173 return(-1);
174 }
175 } else
176 #endif
177 if ((fp = fopen(fspec, "w")) == NULL) {
178 sprintf(errmsg, "%s: cannot open for writing", fspec);
179 error(SYSTEM, errmsg);
180 return(-1);
181 }
182 /* start off header */
183 fprintf(fp, "# Radiance scene file converted from .OBJ by %s\n#\n",
184 progname);
185 n = toRadiance(sc, fp, flreq, flexc); /* write file */
186 #if POPEN_SUPPORT
187 if (fspec[0] == '!') {
188 if (pclose(fp)) {
189 sprintf(errmsg, "%s: error writing to command\n", fspec);
190 error(SYSTEM, errmsg);
191 return(-1);
192 }
193 } else
194 #endif
195 fclose(fp); /* close it (already flushed) */
196 return(n);
197 }
