root/radiance/ray/src/common/cone.h
Fri Sep 23 19:04:52 2005 UTC (19 years, 10 months ago) by greg
CVS Tags: HEAD, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Fri Nov 14 17:22:06 2003 UTC (21 years, 8 months ago) by schorsch
Fri Jun 27 06:53:21 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.5: +1 -3 lines
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.4: +5 -5 lines
Fri Jun 6 16:38:47 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.3: +11 -8 lines
*** empty log message ***
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.2: +2 -57 lines
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.1: +70 -4 lines
Tue Nov 12 16:54:18 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.2 , to selected 2.6
Wed Oct 23 12:19:24 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1 , to selected 2.6
added FLOAT definition for vectors and matrices
Thu Feb 2 10:34:15 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.6
