root/radiance/ray/src/common/cone.h
Fri Sep 23 19:04:52 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: HEAD, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Fri Nov 14 17:22:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.5: +1 -3 lines
Changes since 2.4: +5 -5 lines
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.3: +11 -8 lines
*** empty log message ***
Changes since 2.2: +2 -57 lines
Changes since 2.1: +70 -4 lines
Tue Nov 12 16:54:18 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 2.4
Wed Oct 23 12:19:24 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1 , to selected 2.4
added FLOAT definition for vectors and matrices
Thu Feb 2 10:34:15 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.4
