--- ray/src/common/cone.h 2003/02/25 02:47:21 2.3 +++ ray/src/common/cone.h 2003/06/27 06:53:21 2.6 @@ -1,4 +1,4 @@ -/* RCSid $Id: cone.h,v 2.3 2003/02/25 02:47:21 greg Exp $ */ +/* RCSid $Id: cone.h,v 2.6 2003/06/27 06:53:21 greg Exp $ */ /* * cone.h - header file for cones (cones, cylinders, rings, cups, tubes). * @@ -9,17 +9,20 @@ * * 2/12/86 */ +#ifndef _RAD_CONE_H_ +#define _RAD_CONE_H_ +#ifdef __cplusplus +extern "C" { +#endif -#include "copyright.h" - typedef struct cone { - FLOAT *ca; /* cone arguments (o->oargs.farg) */ + RREAL *ca; /* cone arguments (o->oargs.farg) */ char p0, p1; /* indices for endpoints */ char r0, r1; /* indices for radii */ FVECT ad; /* axis direction vector */ - FLOAT al; /* axis length */ - FLOAT sl; /* side length */ - FLOAT (*tm)[4]; /* pointer to transformation matrix */ + RREAL al; /* axis length */ + RREAL sl; /* side length */ + RREAL (*tm)[4]; /* pointer to transformation matrix */ } CONE; #define CO_R0(co) ((co)->ca[(co)->r0]) @@ -27,16 +30,14 @@ typedef struct cone { #define CO_P0(co) ((co)->ca+(co)->p0) #define CO_P1(co) ((co)->ca+(co)->p1) -#ifdef NOPROTO -extern CONE *getcone(); -extern void freecone(); -extern void conexform(); - -#else - extern CONE *getcone(OBJREC *o, int getxf); extern void freecone(OBJREC *o); extern void conexform(CONE *co); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_CONE_H_ */ +
