root/radiance/ray/src/common/cone.h
Revision: 2.4
Committed: Fri Jun 6 16:38:47 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.3: +11 -8 lines
*** empty log message ***
1 /* RCSid $Id: cone.h,v 2.3 2003/02/25 02:47:21 greg Exp $ */
2 /*
3 * cone.h - header file for cones (cones, cylinders, rings, cups, tubes).
4 *
5 * Storage of arguments in the cone structure is a little strange.
6 * To save space, we use an index into the real arguments of the
7 * object structure through ca. The indices are for the axis
8 * endpoints and radii: p0, p1, r0 and r1.
9 *
10 * 2/12/86
11 */
12 #ifndef _RAD_CONE_H_
13 #define _RAD_CONE_H_
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 #include "copyright.h"
19
20 typedef struct cone {
21 FLOAT *ca; /* cone arguments (o->oargs.farg) */
22 char p0, p1; /* indices for endpoints */
23 char r0, r1; /* indices for radii */
24 FVECT ad; /* axis direction vector */
25 FLOAT al; /* axis length */
26 FLOAT sl; /* side length */
27 FLOAT (*tm)[4]; /* pointer to transformation matrix */
28 } CONE;
29
30 #define CO_R0(co) ((co)->ca[(co)->r0])
31 #define CO_R1(co) ((co)->ca[(co)->r1])
32 #define CO_P0(co) ((co)->ca+(co)->p0)
33 #define CO_P1(co) ((co)->ca+(co)->p1)
34
35
36 extern CONE *getcone(OBJREC *o, int getxf);
37 extern void freecone(OBJREC *o);
38 extern void conexform(CONE *co);
39
40
41 #ifdef __cplusplus
42 }
43 #endif
44 #endif /* _RAD_CONE_H_ */
45
