root/radiance/ray/src/common/cone.c
Revision: 2.11
Committed: Fri Sep 16 15:09:21 2016 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R1, rad5R3, HEAD
Changes since 2.10: +4 -3 lines
Added checks for illegal cones/rings/cylinders
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.11 static const char RCSid[] = "$Id: cone.c,v 2.10 2016/04/21 00:40:35 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * cone.c - routines for making cones
6 greg 2.5 */
7
8 greg 2.6 #include "copyright.h"
9 greg 1.1
10     #include "standard.h"
11
12     #include "object.h"
13
14     #include "otypes.h"
15
16     #include "cone.h"
17
18     /*
19     * In general, a cone may be any one of a cone, a cylinder, a ring,
20     * a cup (inverted cone), or a tube (inverted cylinder).
21     * Most cones are specified with a starting point and radius and
22     * an ending point and radius. In the cases of a cylinder or tube,
23     * only one radius is needed. In the case of a ring, a normal direction
24     * is specified instead of a second endpoint.
25     *
26     * mtype (cone|cup) name
27     * 0
28     * 0
29     * 8 P0x P0y P0z P1x P1y P1z R0 R1
30     *
31     * mtype (cylinder|tube) name
32     * 0
33     * 0
34     * 7 P0x P0y P0z P1x P1y P1z R
35     *
36     * mtype ring name
37     * 0
38     * 0
39     * 8 Px Py Pz Nx Ny Nz R0 R1
40     */
41
42
43     CONE *
44 greg 2.10 getcone( /* get cone structure */
45     OBJREC *o,
46     int getxf
47     )
48 greg 1.1 {
49 greg 1.4 int sgn0, sgn1;
50 greg 2.10 CONE *co;
51 greg 1.1
52     if ((co = (CONE *)o->os) == NULL) {
53
54     co = (CONE *)malloc(sizeof(CONE));
55     if (co == NULL)
56     error(SYSTEM, "out of memory in makecone");
57
58     co->ca = o->oargs.farg;
59     /* get radii */
60 schorsch 2.9 if ((o->otype == OBJ_CYLINDER) | (o->otype == OBJ_TUBE)) {
61 greg 1.1 if (o->oargs.nfargs != 7)
62     goto argcerr;
63 greg 1.4 if (co->ca[6] < -FTINY) {
64     objerror(o, WARNING, "negative radius");
65     o->otype = o->otype == OBJ_CYLINDER ?
66     OBJ_TUBE : OBJ_CYLINDER;
67     co->ca[6] = -co->ca[6];
68     } else if (co->ca[6] <= FTINY)
69 greg 1.1 goto raderr;
70 greg 2.2 co->p0 = 0; co->p1 = 3;
71 greg 1.1 co->r0 = co->r1 = 6;
72     } else {
73     if (o->oargs.nfargs != 8)
74     goto argcerr;
75 greg 1.4 if (co->ca[6] < -FTINY) sgn0 = -1;
76     else if (co->ca[6] > FTINY) sgn0 = 1;
77     else sgn0 = 0;
78     if (co->ca[7] < -FTINY) sgn1 = -1;
79     else if (co->ca[7] > FTINY) sgn1 = 1;
80     else sgn1 = 0;
81     if (sgn0+sgn1 == 0)
82 greg 1.1 goto raderr;
83 schorsch 2.9 if ((sgn0 < 0) | (sgn1 < 0)) {
84 greg 2.11 if (o->otype == OBJ_RING)
85     goto raderr;
86     objerror(o, WARNING, "negative radii");
87 greg 1.4 o->otype = o->otype == OBJ_CONE ?
88     OBJ_CUP : OBJ_CONE;
89     }
90     co->ca[6] = co->ca[6]*sgn0;
91     co->ca[7] = co->ca[7]*sgn1;
92 greg 2.2 if (co->ca[7] - co->ca[6] > FTINY) {
93 greg 1.4 if (o->otype == OBJ_RING)
94 greg 2.2 co->p0 = co->p1 = 0;
95     else {
96     co->p0 = 0; co->p1 = 3;
97     }
98     co->r0 = 6; co->r1 = 7;
99     } else if (co->ca[6] - co->ca[7] > FTINY) {
100     if (o->otype == OBJ_RING)
101     co->p0 = co->p1 = 0;
102     else {
103     co->p0 = 3; co->p1 = 0;
104     }
105     co->r0 = 7; co->r1 = 6;
106     } else {
107     if (o->otype == OBJ_RING)
108 greg 1.4 goto raderr;
109     o->otype = o->otype == OBJ_CONE ?
110     OBJ_CYLINDER : OBJ_TUBE;
111     o->oargs.nfargs = 7;
112 greg 2.2 co->p0 = 0; co->p1 = 3;
113     co->r0 = co->r1 = 6;
114 greg 1.4 }
115 greg 1.1 }
116     /* get axis orientation */
117 greg 2.2 if (o->otype == OBJ_RING)
118 greg 1.1 VCOPY(co->ad, o->oargs.farg+3);
119 greg 2.2 else {
120     co->ad[0] = CO_P1(co)[0] - CO_P0(co)[0];
121     co->ad[1] = CO_P1(co)[1] - CO_P0(co)[1];
122     co->ad[2] = CO_P1(co)[2] - CO_P0(co)[2];
123 greg 1.1 }
124     co->al = normalize(co->ad);
125 greg 2.10 if (co->al == 0.0) {
126     objerror(o, WARNING, "unknown orientation");
127     free(co);
128     return(NULL);
129     }
130 greg 1.1 /* compute axis and side lengths */
131     if (o->otype == OBJ_RING) {
132     co->al = 0.0;
133 greg 2.2 co->sl = CO_R1(co) - CO_R0(co);
134 schorsch 2.9 } else if ((o->otype == OBJ_CONE) | (o->otype == OBJ_CUP)) {
135 greg 1.1 co->sl = co->ca[7] - co->ca[6];
136     co->sl = sqrt(co->sl*co->sl + co->al*co->al);
137 greg 2.2 } else { /* OBJ_CYLINDER or OBJ_TUBE */
138 greg 1.1 co->sl = co->al;
139     }
140     co->tm = NULL;
141 greg 1.2 o->os = (char *)co;
142 greg 1.1 }
143     if (getxf && co->tm == NULL)
144     conexform(co);
145     return(co);
146
147     argcerr:
148     objerror(o, USER, "bad # arguments");
149     raderr:
150 greg 2.10 objerror(o, WARNING, "illegal radii");
151     free(co);
152     return(NULL);
153 greg 1.1 }
154
155
156 greg 2.5 void
157 greg 2.10 freecone(OBJREC *o) /* free memory associated with cone */
158 greg 1.1 {
159 greg 2.10 CONE *co = (CONE *)o->os;
160 greg 1.1
161 greg 2.4 if (co == NULL)
162 greg 1.5 return;
163 greg 1.1 if (co->tm != NULL)
164 greg 2.5 free((void *)co->tm);
165     free((void *)co);
166 greg 1.1 o->os = NULL;
167     }
168
169
170 greg 2.5 void
171 greg 2.10 conexform(CONE *co) /* get cone transformation matrix */
172 greg 1.1 {
173 greg 1.6 MAT4 m4;
174 greg 2.10 double d;
175     int i;
176 greg 1.1
177 schorsch 2.8 co->tm = (RREAL (*)[4])malloc(sizeof(MAT4));
178 greg 1.1 if (co->tm == NULL)
179     error(SYSTEM, "out of memory in conexform");
180
181     /* translate to origin */
182     setident4(co->tm);
183     if (co->r0 == co->r1)
184     d = 0.0;
185     else
186 greg 2.2 d = CO_R0(co) / (CO_R1(co) - CO_R0(co));
187 greg 1.1 for (i = 0; i < 3; i++)
188 greg 2.2 co->tm[3][i] = d*(CO_P1(co)[i] - CO_P0(co)[i])
189     - CO_P0(co)[i];
190 greg 1.1
191     /* rotate to positive z-axis */
192     setident4(m4);
193     d = co->ad[1]*co->ad[1] + co->ad[2]*co->ad[2];
194     if (d <= FTINY*FTINY) {
195     m4[0][0] = 0.0;
196     m4[0][2] = co->ad[0];
197     m4[2][0] = -co->ad[0];
198     m4[2][2] = 0.0;
199     } else {
200     d = sqrt(d);
201     m4[0][0] = d;
202     m4[1][0] = -co->ad[0]*co->ad[1]/d;
203     m4[2][0] = -co->ad[0]*co->ad[2]/d;
204     m4[1][1] = co->ad[2]/d;
205     m4[2][1] = -co->ad[1]/d;
206     m4[0][2] = co->ad[0];
207     m4[1][2] = co->ad[1];
208     m4[2][2] = co->ad[2];
209     }
210     multmat4(co->tm, co->tm, m4);
211
212     /* scale z-axis */
213 schorsch 2.9 if ((co->p0 != co->p1) & (co->r0 != co->r1)) {
214 greg 2.2 setident4(m4);
215     m4[2][2] = (CO_R1(co) - CO_R0(co)) / co->al;
216     multmat4(co->tm, co->tm, m4);
217 greg 1.1 }
218     }
