root/Development/ray/src/common/cone.c
Revision: 2.2
Committed: Sun Sep 6 11:53:47 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +39 -33 lines
major aesthetic changes -- made R0 always smaller than R1
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * cone.c - routines for making cones
9 *
10 * 2/12/86
11 */
12
13 #include "standard.h"
14
15 #include "object.h"
16
17 #include "otypes.h"
18
19 #include "cone.h"
20
21 /*
22 * In general, a cone may be any one of a cone, a cylinder, a ring,
23 * a cup (inverted cone), or a tube (inverted cylinder).
24 * Most cones are specified with a starting point and radius and
25 * an ending point and radius. In the cases of a cylinder or tube,
26 * only one radius is needed. In the case of a ring, a normal direction
27 * is specified instead of a second endpoint.
28 *
29 * mtype (cone|cup) name
30 * 0
31 * 0
32 * 8 P0x P0y P0z P1x P1y P1z R0 R1
33 *
34 * mtype (cylinder|tube) name
35 * 0
36 * 0
37 * 7 P0x P0y P0z P1x P1y P1z R
38 *
39 * mtype ring name
40 * 0
41 * 0
42 * 8 Px Py Pz Nx Ny Nz R0 R1
43 */
44
45
46 CONE *
47 getcone(o, getxf) /* get cone structure */
48 register OBJREC *o;
49 int getxf;
50 {
51 extern double sqrt();
52 int sgn0, sgn1;
53 register CONE *co;
54
55 if ((co = (CONE *)o->os) == NULL) {
56
57 co = (CONE *)malloc(sizeof(CONE));
58 if (co == NULL)
59 error(SYSTEM, "out of memory in makecone");
60
61 co->ca = o->oargs.farg;
62 /* get radii */
63 if (o->otype == OBJ_CYLINDER | o->otype == OBJ_TUBE) {
64 if (o->oargs.nfargs != 7)
65 goto argcerr;
66 if (co->ca[6] < -FTINY) {
67 objerror(o, WARNING, "negative radius");
68 o->otype = o->otype == OBJ_CYLINDER ?
69 OBJ_TUBE : OBJ_CYLINDER;
70 co->ca[6] = -co->ca[6];
71 } else if (co->ca[6] <= FTINY)
72 goto raderr;
73 co->p0 = 0; co->p1 = 3;
74 co->r0 = co->r1 = 6;
75 } else {
76 if (o->oargs.nfargs != 8)
77 goto argcerr;
78 if (co->ca[6] < -FTINY) sgn0 = -1;
79 else if (co->ca[6] > FTINY) sgn0 = 1;
80 else sgn0 = 0;
81 if (co->ca[7] < -FTINY) sgn1 = -1;
82 else if (co->ca[7] > FTINY) sgn1 = 1;
83 else sgn1 = 0;
84 if (sgn0+sgn1 == 0)
85 goto raderr;
86 if (sgn0 < 0 | sgn1 < 0) {
87 objerror(o, o->otype==OBJ_RING?USER:WARNING,
88 "negative radii");
89 o->otype = o->otype == OBJ_CONE ?
90 OBJ_CUP : OBJ_CONE;
91 }
92 co->ca[6] = co->ca[6]*sgn0;
93 co->ca[7] = co->ca[7]*sgn1;
94 if (co->ca[7] - co->ca[6] > FTINY) {
95 if (o->otype == OBJ_RING)
96 co->p0 = co->p1 = 0;
97 else {
98 co->p0 = 0; co->p1 = 3;
99 }
100 co->r0 = 6; co->r1 = 7;
101 } else if (co->ca[6] - co->ca[7] > FTINY) {
102 if (o->otype == OBJ_RING)
103 co->p0 = co->p1 = 0;
104 else {
105 co->p0 = 3; co->p1 = 0;
106 }
107 co->r0 = 7; co->r1 = 6;
108 } else {
109 if (o->otype == OBJ_RING)
110 goto raderr;
111 o->otype = o->otype == OBJ_CONE ?
112 OBJ_CYLINDER : OBJ_TUBE;
113 o->oargs.nfargs = 7;
114 co->p0 = 0; co->p1 = 3;
115 co->r0 = co->r1 = 6;
116 }
117 }
118 /* get axis orientation */
119 if (o->otype == OBJ_RING)
120 VCOPY(co->ad, o->oargs.farg+3);
121 else {
122 co->ad[0] = CO_P1(co)[0] - CO_P0(co)[0];
123 co->ad[1] = CO_P1(co)[1] - CO_P0(co)[1];
124 co->ad[2] = CO_P1(co)[2] - CO_P0(co)[2];
125 }
126 co->al = normalize(co->ad);
127 if (co->al == 0.0)
128 objerror(o, USER, "zero orientation");
129 /* compute axis and side lengths */
130 if (o->otype == OBJ_RING) {
131 co->al = 0.0;
132 co->sl = CO_R1(co) - CO_R0(co);
133 } else if (o->otype == OBJ_CONE | o->otype == OBJ_CUP) {
134 co->sl = co->ca[7] - co->ca[6];
135 co->sl = sqrt(co->sl*co->sl + co->al*co->al);
136 } else { /* OBJ_CYLINDER or OBJ_TUBE */
137 co->sl = co->al;
138 }
139 co->tm = NULL;
140 o->os = (char *)co;
141 }
142 if (getxf && co->tm == NULL)
143 conexform(co);
144 return(co);
145
146 argcerr:
147 objerror(o, USER, "bad # arguments");
148 raderr:
149 objerror(o, USER, "illegal radii");
150 }
151
152
153 freecone(o) /* free memory associated with cone */
154 OBJREC *o;
155 {
156 register CONE *co = (CONE *)o->os;
157
158 if (o->os == NULL)
159 return;
160 if (co->tm != NULL)
161 free((char *)co->tm);
162 free(o->os);
163 o->os = NULL;
164 }
165
166
167 conexform(co) /* get cone transformation matrix */
168 register CONE *co;
169 {
170 extern double sqrt();
171 MAT4 m4;
172 register double d;
173 register int i;
174
175 co->tm = (FLOAT (*)[4])malloc(sizeof(MAT4));
176 if (co->tm == NULL)
177 error(SYSTEM, "out of memory in conexform");
178
179 /* translate to origin */
180 setident4(co->tm);
181 if (co->r0 == co->r1)
182 d = 0.0;
183 else
184 d = CO_R0(co) / (CO_R1(co) - CO_R0(co));
185 for (i = 0; i < 3; i++)
186 co->tm[3][i] = d*(CO_P1(co)[i] - CO_P0(co)[i])
187 - CO_P0(co)[i];
188
189 /* rotate to positive z-axis */
190 setident4(m4);
191 d = co->ad[1]*co->ad[1] + co->ad[2]*co->ad[2];
192 if (d <= FTINY*FTINY) {
193 m4[0][0] = 0.0;
194 m4[0][2] = co->ad[0];
195 m4[2][0] = -co->ad[0];
196 m4[2][2] = 0.0;
197 } else {
198 d = sqrt(d);
199 m4[0][0] = d;
200 m4[1][0] = -co->ad[0]*co->ad[1]/d;
201 m4[2][0] = -co->ad[0]*co->ad[2]/d;
202 m4[1][1] = co->ad[2]/d;
203 m4[2][1] = -co->ad[1]/d;
204 m4[0][2] = co->ad[0];
205 m4[1][2] = co->ad[1];
206 m4[2][2] = co->ad[2];
207 }
208 multmat4(co->tm, co->tm, m4);
209
210 /* scale z-axis */
211 if (co->p0 != co->p1 & co->r0 != co->r1) {
212 setident4(m4);
213 m4[2][2] = (CO_R1(co) - CO_R0(co)) / co->al;
214 multmat4(co->tm, co->tm, m4);
215 }
216 }
