--- ray/src/common/cone.c 1991/01/19 13:43:28 1.3 +++ ray/src/common/cone.c 1991/10/23 13:43:12 1.6 @@ -49,6 +49,7 @@ register OBJREC *o; int getxf; { double fabs(), sqrt(); + int sgn0, sgn1; register CONE *co; if ((co = (CONE *)o->os) == NULL) { @@ -62,20 +63,43 @@ int getxf; if (o->otype == OBJ_CYLINDER || o->otype == OBJ_TUBE) { if (o->oargs.nfargs != 7) goto argcerr; - if (co->ca[6] <= FTINY) + if (co->ca[6] < -FTINY) { + objerror(o, WARNING, "negative radius"); + o->otype = o->otype == OBJ_CYLINDER ? + OBJ_TUBE : OBJ_CYLINDER; + co->ca[6] = -co->ca[6]; + } else if (co->ca[6] <= FTINY) goto raderr; co->r0 = co->r1 = 6; } else { if (o->oargs.nfargs != 8) goto argcerr; - if (co->ca[6] < -FTINY || co->ca[7] < -FTINY) + if (co->ca[6] < -FTINY) sgn0 = -1; + else if (co->ca[6] > FTINY) sgn0 = 1; + else sgn0 = 0; + if (co->ca[7] < -FTINY) sgn1 = -1; + else if (co->ca[7] > FTINY) sgn1 = 1; + else sgn1 = 0; + if (sgn0+sgn1 == 0) goto raderr; - if (co->ca[6] < 0.0) co->ca[6] = 0.0; - if (co->ca[7] < 0.0) co->ca[7] = 0.0; - if (fabs(co->ca[7] - co->ca[6]) <= FTINY) - goto raderr; + if (sgn0 < 0 || sgn1 < 0) { + objerror(o, o->otype==OBJ_RING?USER:WARNING, + "negative radii"); + o->otype = o->otype == OBJ_CONE ? + OBJ_CUP : OBJ_CONE; + } + co->ca[6] = co->ca[6]*sgn0; + co->ca[7] = co->ca[7]*sgn1; co->r0 = 6; co->r1 = 7; + if (fabs(co->ca[7] - co->ca[6]) <= FTINY) { + if (o->otype == OBJ_RING) + goto raderr; + o->otype = o->otype == OBJ_CONE ? + OBJ_CYLINDER : OBJ_TUBE; + o->oargs.nfargs = 7; + co->r1 = 6; + } } /* get axis orientation */ co->p0 = 0; @@ -124,6 +148,8 @@ OBJREC *o; { register CONE *co = (CONE *)o->os; + if (o->os == NULL) + return; if (co->tm != NULL) free((char *)co->tm); free(o->os); @@ -135,11 +161,11 @@ conexform(co) /* get cone transformation matrix */ register CONE *co; { double sqrt(), fabs(); - double m4[4][4]; + MAT4 m4; register double d; register int i; - co->tm = (double (*)[4])malloc(sizeof(m4)); + co->tm = (FLOAT (*)[4])malloc(sizeof(m4)); if (co->tm == NULL) error(SYSTEM, "out of memory in conexform");
