root/radiance/ray/src/common/cone.c
Revision: 2.1
Committed: Tue Nov 12 16:55:03 1991 UTC (33 years, 5 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * cone.c - routines for making cones
9 *
10 * 2/12/86
11 */
12
13 #include "standard.h"
14
15 #include "object.h"
16
17 #include "otypes.h"
18
19 #include "cone.h"
20
21 /*
22 * In general, a cone may be any one of a cone, a cylinder, a ring,
23 * a cup (inverted cone), or a tube (inverted cylinder).
24 * Most cones are specified with a starting point and radius and
25 * an ending point and radius. In the cases of a cylinder or tube,
26 * only one radius is needed. In the case of a ring, a normal direction
27 * is specified instead of a second endpoint.
28 *
29 * mtype (cone|cup) name
30 * 0
31 * 0
32 * 8 P0x P0y P0z P1x P1y P1z R0 R1
33 *
34 * mtype (cylinder|tube) name
35 * 0
36 * 0
37 * 7 P0x P0y P0z P1x P1y P1z R
38 *
39 * mtype ring name
40 * 0
41 * 0
42 * 8 Px Py Pz Nx Ny Nz R0 R1
43 */
44
45
46 CONE *
47 getcone(o, getxf) /* get cone structure */
48 register OBJREC *o;
49 int getxf;
50 {
51 double fabs(), sqrt();
52 int sgn0, sgn1;
53 register CONE *co;
54
55 if ((co = (CONE *)o->os) == NULL) {
56
57 co = (CONE *)malloc(sizeof(CONE));
58 if (co == NULL)
59 error(SYSTEM, "out of memory in makecone");
60
61 co->ca = o->oargs.farg;
62 /* get radii */
63 if (o->otype == OBJ_CYLINDER || o->otype == OBJ_TUBE) {
64 if (o->oargs.nfargs != 7)
65 goto argcerr;
66 if (co->ca[6] < -FTINY) {
67 objerror(o, WARNING, "negative radius");
68 o->otype = o->otype == OBJ_CYLINDER ?
69 OBJ_TUBE : OBJ_CYLINDER;
70 co->ca[6] = -co->ca[6];
71 } else if (co->ca[6] <= FTINY)
72 goto raderr;
73 co->r0 = co->r1 = 6;
74 } else {
75 if (o->oargs.nfargs != 8)
76 goto argcerr;
77 if (co->ca[6] < -FTINY) sgn0 = -1;
78 else if (co->ca[6] > FTINY) sgn0 = 1;
79 else sgn0 = 0;
80 if (co->ca[7] < -FTINY) sgn1 = -1;
81 else if (co->ca[7] > FTINY) sgn1 = 1;
82 else sgn1 = 0;
83 if (sgn0+sgn1 == 0)
84 goto raderr;
85 if (sgn0 < 0 || sgn1 < 0) {
86 objerror(o, o->otype==OBJ_RING?USER:WARNING,
87 "negative radii");
88 o->otype = o->otype == OBJ_CONE ?
89 OBJ_CUP : OBJ_CONE;
90 }
91 co->ca[6] = co->ca[6]*sgn0;
92 co->ca[7] = co->ca[7]*sgn1;
93 co->r0 = 6;
94 co->r1 = 7;
95 if (fabs(co->ca[7] - co->ca[6]) <= FTINY) {
96 if (o->otype == OBJ_RING)
97 goto raderr;
98 o->otype = o->otype == OBJ_CONE ?
99 OBJ_CYLINDER : OBJ_TUBE;
100 o->oargs.nfargs = 7;
101 co->r1 = 6;
102 }
103 }
104 /* get axis orientation */
105 co->p0 = 0;
106 if (o->otype == OBJ_RING) {
107 if (co->ca[6] > co->ca[7]) { /* make r0 smaller */
108 co->r0 = 7;
109 co->r1 = 6;
110 }
111 co->p1 = 0;
112 VCOPY(co->ad, o->oargs.farg+3);
113 } else {
114 co->p1 = 3;
115 co->ad[0] = co->ca[3] - co->ca[0];
116 co->ad[1] = co->ca[4] - co->ca[1];
117 co->ad[2] = co->ca[5] - co->ca[2];
118 }
119 co->al = normalize(co->ad);
120 if (co->al == 0.0)
121 objerror(o, USER, "zero orientation");
122 /* compute axis and side lengths */
123 if (o->otype == OBJ_RING) {
124 co->al = 0.0;
125 co->sl = co->ca[co->r1] - co->ca[co->r0];
126 } else if (o->otype == OBJ_CONE || o->otype == OBJ_CUP) {
127 co->sl = co->ca[7] - co->ca[6];
128 co->sl = sqrt(co->sl*co->sl + co->al*co->al);
129 } else { /* OBJ_CYLINDER || OBJ_TUBE */
130 co->sl = co->al;
131 }
132 co->tm = NULL;
133 o->os = (char *)co;
134 }
135 if (getxf && co->tm == NULL)
136 conexform(co);
137 return(co);
138
139 argcerr:
140 objerror(o, USER, "bad # arguments");
141 raderr:
142 objerror(o, USER, "illegal radii");
143 }
144
145
146 freecone(o) /* free memory associated with cone */
147 OBJREC *o;
148 {
149 register CONE *co = (CONE *)o->os;
150
151 if (o->os == NULL)
152 return;
153 if (co->tm != NULL)
154 free((char *)co->tm);
155 free(o->os);
156 o->os = NULL;
157 }
158
159
160 conexform(co) /* get cone transformation matrix */
161 register CONE *co;
162 {
163 double sqrt(), fabs();
164 MAT4 m4;
165 register double d;
166 register int i;
167
168 co->tm = (FLOAT (*)[4])malloc(sizeof(m4));
169 if (co->tm == NULL)
170 error(SYSTEM, "out of memory in conexform");
171
172 /* translate to origin */
173 setident4(co->tm);
174 if (co->r0 == co->r1)
175 d = 0.0;
176 else
177 d = co->ca[co->r0] / (co->ca[co->r1] - co->ca[co->r0]);
178 for (i = 0; i < 3; i++)
179 co->tm[3][i] = d*(co->ca[co->p1+i] - co->ca[co->p0+i])
180 - co->ca[co->p0+i];
181
182 /* rotate to positive z-axis */
183 setident4(m4);
184 d = co->ad[1]*co->ad[1] + co->ad[2]*co->ad[2];
185 if (d <= FTINY*FTINY) {
186 m4[0][0] = 0.0;
187 m4[0][2] = co->ad[0];
188 m4[2][0] = -co->ad[0];
189 m4[2][2] = 0.0;
190 } else {
191 d = sqrt(d);
192 m4[0][0] = d;
193 m4[1][0] = -co->ad[0]*co->ad[1]/d;
194 m4[2][0] = -co->ad[0]*co->ad[2]/d;
195 m4[1][1] = co->ad[2]/d;
196 m4[2][1] = -co->ad[1]/d;
197 m4[0][2] = co->ad[0];
198 m4[1][2] = co->ad[1];
199 m4[2][2] = co->ad[2];
200 }
201 multmat4(co->tm, co->tm, m4);
202
203 /* scale z-axis */
204 setident4(m4);
205 if (co->p0 != co->p1 && co->r0 != co->r1) {
206 d = fabs(co->ca[co->r1] - co->ca[co->r0]);
207 m4[2][2] = d/co->al;
208 }
209 multmat4(co->tm, co->tm, m4);
210 }
