--- ray/src/common/cone.c 2003/06/07 12:50:20 2.7 +++ ray/src/common/cone.c 2003/07/27 22:12:01 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cone.c,v 2.7 2003/06/07 12:50:20 schorsch Exp $"; +static const char RCSid[] = "$Id: cone.c,v 2.9 2003/07/27 22:12:01 schorsch Exp $"; #endif /* * cone.c - routines for making cones @@ -56,7 +56,7 @@ int getxf; co->ca = o->oargs.farg; /* get radii */ - if (o->otype == OBJ_CYLINDER | o->otype == OBJ_TUBE) { + if ((o->otype == OBJ_CYLINDER) | (o->otype == OBJ_TUBE)) { if (o->oargs.nfargs != 7) goto argcerr; if (co->ca[6] < -FTINY) { @@ -79,7 +79,7 @@ int getxf; else sgn1 = 0; if (sgn0+sgn1 == 0) goto raderr; - if (sgn0 < 0 | sgn1 < 0) { + if ((sgn0 < 0) | (sgn1 < 0)) { objerror(o, o->otype==OBJ_RING?USER:WARNING, "negative radii"); o->otype = o->otype == OBJ_CONE ? @@ -126,7 +126,7 @@ int getxf; if (o->otype == OBJ_RING) { co->al = 0.0; co->sl = CO_R1(co) - CO_R0(co); - } else if (o->otype == OBJ_CONE | o->otype == OBJ_CUP) { + } else if ((o->otype == OBJ_CONE) | (o->otype == OBJ_CUP)) { co->sl = co->ca[7] - co->ca[6]; co->sl = sqrt(co->sl*co->sl + co->al*co->al); } else { /* OBJ_CYLINDER or OBJ_TUBE */ @@ -170,7 +170,7 @@ register CONE *co; register double d; register int i; - co->tm = (FLOAT (*)[4])malloc(sizeof(MAT4)); + co->tm = (RREAL (*)[4])malloc(sizeof(MAT4)); if (co->tm == NULL) error(SYSTEM, "out of memory in conexform"); @@ -206,7 +206,7 @@ register CONE *co; multmat4(co->tm, co->tm, m4); /* scale z-axis */ - if (co->p0 != co->p1 & co->r0 != co->r1) { + if ((co->p0 != co->p1) & (co->r0 != co->r1)) { setident4(m4); m4[2][2] = (CO_R1(co) - CO_R0(co)) / co->al; multmat4(co->tm, co->tm, m4);
