root/radiance/ray/src/common/cone.c
Diff to previous 2.8 , to selected 1.4
Diff to previous 2.7 , to selected 1.4
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Diff to previous 2.6 , to selected 1.4
Diff to previous 2.5 , to selected 1.4
Sat Feb 22 02:07:22 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.4: +61 -7 lines
Diff to previous 2.4 , to selected 1.4
Thu Nov 19 21:32:48 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.3 , to selected 1.4
insignificant change to freecone()
Fri Oct 2 16:01:06 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +0 -2 lines
Diff to previous 2.2 , to selected 1.4
Sun Sep 6 11:53:47 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.1: +39 -33 lines
Diff to previous 2.1 , to selected 1.4
major aesthetic changes -- made R0 always smaller than R1
Tue Nov 12 16:55:03 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 1.4
Wed Oct 23 13:43:12 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 1.4
Wed Jul 17 14:10:16 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.4
made call to free structures more robust
Revision 1.4 - (view) (download) (annotate) - [selected]
Wed May 22 16:51:12 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +30 -6 lines
Diff to previous 1.3
made getcone VERY forgiving of improper input --
negative radii now result in warnings and altered types
Sat Jan 19 13:43:28 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 1.4
changed error checking to allow for slightly negative radii
Tue Feb 21 14:39:51 1989 UTC (35 years, 4 months ago) by greg
Diff to previous 1.1 , to selected 1.4
portability fixes for SGI
Thu Feb 2 10:34:30 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.4
