root/Development/ray/src/common/cone.c
Sun Jul 27 22:12:01 2003 UTC (22 years, 5 months ago) by schorsch
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Sat Jun 7 12:50:20 2003 UTC (22 years, 6 months ago) by schorsch
Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.4: +61 -7 lines
Thu Nov 19 21:32:48 1992 UTC (33 years, 1 month ago) by greg
insignificant change to freecone()
Fri Oct 2 16:01:06 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +0 -2 lines
Sun Sep 6 11:53:47 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.1: +39 -33 lines
Diff to previous 2.1
major aesthetic changes -- made R0 always smaller than R1
Tue Nov 12 16:55:03 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.6
Wed Oct 23 13:43:12 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.5
Wed Jul 17 14:10:16 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.4
made call to free structures more robust
Wed May 22 16:51:12 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +30 -6 lines
Diff to previous 1.3
made getcone VERY forgiving of improper input --
negative radii now result in warnings and altered types
Sat Jan 19 13:43:28 1991 UTC (34 years, 11 months ago) by greg
Diff to previous 1.2
changed error checking to allow for slightly negative radii
Tue Feb 21 14:39:51 1989 UTC (36 years, 10 months ago) by greg
Diff to previous 1.1
portability fixes for SGI
Thu Feb 2 10:34:30 1989 UTC (36 years, 10 months ago) by greg
