root/radiance/ray/src/common/colrops.c
Revision: 2.4
Committed: Fri Oct 2 16:00:51 1992 UTC (31 years, 7 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Integer operations on COLR scanlines
9 */
10
11 #include "color.h"
12
13 #define NULL 0
14
15 extern char *bmalloc();
16
17 #define MAXGSHIFT 31 /* maximum shift for gamma table */
18
19 static BYTE *g_mant = NULL, *g_nexp = NULL;
20
21 static BYTE (*g_bval)[256] = NULL;
22
23 #ifndef pow
24 extern double pow();
25 #endif
26
27
28 setcolrcor(f, a2) /* set brightness correction */
29 double (*f)();
30 double a2;
31 {
32 double mult;
33 register int i, j;
34 /* allocate tables */
35 if (g_bval == NULL && (g_bval =
36 (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL)
37 return(-1);
38 /* compute colr -> gamb mapping */
39 mult = 1.0/256.0;
40 for (i = 0; i <= MAXGSHIFT; i++) {
41 for (j = 0; j < 256; j++)
42 g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2);
43 mult *= 0.5;
44 }
45 return(0);
46 }
47
48
49 setcolrinv(f, a2) /* set inverse brightness correction */
50 double (*f)();
51 double a2;
52 {
53 double mult;
54 register int i, j;
55 /* allocate tables */
56 if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL)
57 return(-1);
58 if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL)
59 return(-1);
60 /* compute gamb -> colr mapping */
61 i = 0;
62 mult = 256.0;
63 for (j = 255; j > 0; j--) {
64 while ((g_mant[j] = mult * (*f)(j/256.0, a2)) < 128) {
65 i++;
66 mult *= 2.0;
67 }
68 g_nexp[j] = i;
69 }
70 g_mant[0] = 0;
71 g_nexp[0] = COLXS;
72 return(0);
73 }
74
75
76 setcolrgam(g) /* set gamma conversion */
77 double g;
78 {
79 if (setcolrcor(pow, 1.0/g) < 0)
80 return(-1);
81 return(setcolrinv(pow, g));
82 }
83
84
85 colrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */
86 register COLR *scan;
87 int len;
88 {
89 register int i, expo;
90
91 if (g_bval == NULL)
92 return(-1);
93 while (len-- > 0) {
94 expo = scan[0][EXP] - COLXS;
95 if (expo < -MAXGSHIFT) {
96 if (expo < -MAXGSHIFT-8) {
97 scan[0][RED] =
98 scan[0][GRN] =
99 scan[0][BLU] = 0;
100 } else {
101 i = (-MAXGSHIFT-1) - expo;
102 scan[0][RED] =
103 g_bval[MAXGSHIFT][((scan[0][RED]>>i)+1)>>1];
104 scan[0][GRN] =
105 g_bval[MAXGSHIFT][((scan[0][GRN]>>i)+1)>>1];
106 scan[0][BLU] =
107 g_bval[MAXGSHIFT][((scan[0][BLU]>>i)+1)>>1];
108 }
109 } else if (expo > 0) {
110 if (expo > 8) {
111 scan[0][RED] =
112 scan[0][GRN] =
113 scan[0][BLU] = 255;
114 } else {
115 i = (scan[0][RED]<<1 | 1) << (expo-1);
116 scan[0][RED] = i > 255 ? 255 : g_bval[0][i];
117 i = (scan[0][GRN]<<1 | 1) << (expo-1);
118 scan[0][GRN] = i > 255 ? 255 : g_bval[0][i];
119 i = (scan[0][BLU]<<1 | 1) << (expo-1);
120 scan[0][BLU] = i > 255 ? 255 : g_bval[0][i];
121 }
122 } else {
123 scan[0][RED] = g_bval[-expo][scan[0][RED]];
124 scan[0][GRN] = g_bval[-expo][scan[0][GRN]];
125 scan[0][BLU] = g_bval[-expo][scan[0][BLU]];
126 }
127 scan[0][EXP] = COLXS;
128 scan++;
129 }
130 return(0);
131 }
132
133
134 gambs_colrs(scan, len) /* convert gamma bytes to colr scanline */
135 register COLR *scan;
136 int len;
137 {
138 register int nexpo;
139
140 if (g_mant == NULL | g_nexp == NULL)
141 return(-1);
142 while (len-- > 0) {
143 nexpo = g_nexp[scan[0][RED]];
144 if (g_nexp[scan[0][GRN]] < nexpo)
145 nexpo = g_nexp[scan[0][GRN]];
146 if (g_nexp[scan[0][BLU]] < nexpo)
147 nexpo = g_nexp[scan[0][BLU]];
148 if (nexpo < g_nexp[scan[0][RED]])
149 scan[0][RED] = g_mant[scan[0][RED]]
150 >> (g_nexp[scan[0][RED]]-nexpo);
151 else
152 scan[0][RED] = g_mant[scan[0][RED]];
153 if (nexpo < g_nexp[scan[0][GRN]])
154 scan[0][GRN] = g_mant[scan[0][GRN]]
155 >> (g_nexp[scan[0][GRN]]-nexpo);
156 else
157 scan[0][GRN] = g_mant[scan[0][GRN]];
158 if (nexpo < g_nexp[scan[0][BLU]])
159 scan[0][BLU] = g_mant[scan[0][BLU]]
160 >> (g_nexp[scan[0][BLU]]-nexpo);
161 else
162 scan[0][BLU] = g_mant[scan[0][BLU]];
163 scan[0][EXP] = COLXS - nexpo;
164 scan++;
165 }
166 return(0);
167 }
168
169
170 shiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */
171 register COLR *scan;
172 register int len;
173 register int adjust;
174 {
175 int minexp;
176
177 if (adjust == 0)
178 return;
179 minexp = adjust < 0 ? -adjust : 0;
180 while (len-- > 0) {
181 if (scan[0][EXP] <= minexp)
182 scan[0][RED] = scan[0][GRN] = scan[0][BLU] =
183 scan[0][EXP] = 0;
184 else
185 scan[0][EXP] += adjust;
186 scan++;
187 }
188 }
189
190
191 normcolrs(scan, len, adjust) /* normalize a scanline of colrs */
192 register COLR *scan;
193 int len;
194 int adjust;
195 {
196 register int c;
197 register int shift;
198
199 while (len-- > 0) {
200 shift = scan[0][EXP] + adjust - COLXS;
201 if (shift > 0) {
202 if (shift > 8) {
203 scan[0][RED] =
204 scan[0][GRN] =
205 scan[0][BLU] = 255;
206 } else {
207 shift--;
208 c = (scan[0][RED]<<1 | 1) << shift;
209 scan[0][RED] = c > 255 ? 255 : c;
210 c = (scan[0][GRN]<<1 | 1) << shift;
211 scan[0][GRN] = c > 255 ? 255 : c;
212 c = (scan[0][BLU]<<1 | 1) << shift;
213 scan[0][BLU] = c > 255 ? 255 : c;
214 }
215 } else if (shift < 0) {
216 if (shift < -8) {
217 scan[0][RED] =
218 scan[0][GRN] =
219 scan[0][BLU] = 0;
220 } else {
221 shift = -1-shift;
222 scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1;
223 scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1;
224 scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1;
225 }
226 }
227 scan[0][EXP] = COLXS - adjust;
228 scan++;
229 }
230 }
