--- ray/src/common/colrops.c 1991/11/12 16:55:43 2.1 +++ ray/src/common/colrops.c 2003/06/30 19:04:29 2.9 @@ -1,55 +1,92 @@ -/* Copyright (c) 1990 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: colrops.c,v 2.9 2003/06/30 19:04:29 greg Exp $"; #endif - /* * Integer operations on COLR scanlines */ +#include "copyright.h" + +#include +#include #include "color.h" -#define MAXGSHIFT 15 /* maximum shift for gamma table */ +extern char *bmalloc(); -static BYTE g_mant[256], g_nexp[256]; +#define MAXGSHIFT 31 /* maximum shift for gamma table */ -static BYTE g_bval[MAXGSHIFT+1][256]; +static BYTE *g_mant = NULL, *g_nexp = NULL; +static BYTE (*g_bval)[256] = NULL; -setcolrgam(g) /* set gamma conversion */ -double g; + +int +setcolrcor(f, a2) /* set brightness correction */ +double (*f)(); +double a2; { - extern double pow(); double mult; register int i, j; + /* allocate tables */ + if (g_bval == NULL && (g_bval = + (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL) + return(-1); /* compute colr -> gamb mapping */ + mult = 1.0/256.0; for (i = 0; i <= MAXGSHIFT; i++) { - mult = pow(0.5, (double)(i+8)); for (j = 0; j < 256; j++) - g_bval[i][j] = 256.0 * pow((j+.5)*mult, 1.0/g); + g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2); + mult *= 0.5; } + return(0); +} + + +int +setcolrinv(f, a2) /* set inverse brightness correction */ +double (*f)(); +double a2; +{ + double mult; + register int i, j; + /* allocate tables */ + if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL) + return(-1); + if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL) + return(-1); /* compute gamb -> colr mapping */ i = 0; mult = 256.0; - for (j = 255; j > 0; j--) { - while ((g_mant[j] = mult * pow(j/256.0, g)) < 128) { + for (j = 256; j--; ) { + while ((g_mant[j] = mult * (*f)((j+.5)/256.0, a2)) < 128) { i++; mult *= 2.0; } g_nexp[j] = i; } - g_mant[0] = 0; - g_nexp[0] = COLXS; + return(0); } +int +setcolrgam(g) /* set gamma conversion */ +double g; +{ + if (setcolrcor(pow, 1.0/g) < 0) + return(-1); + return(setcolrinv(pow, g)); +} + + +int colrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */ register COLR *scan; int len; { register int i, expo; + if (g_bval == NULL) + return(-1); while (len-- > 0) { expo = scan[0][EXP] - COLXS; if (expo < -MAXGSHIFT) { @@ -87,15 +124,19 @@ int len; scan[0][EXP] = COLXS; scan++; } + return(0); } +int gambs_colrs(scan, len) /* convert gamma bytes to colr scanline */ register COLR *scan; int len; { register int nexpo; + if (g_mant == NULL | g_nexp == NULL) + return(-1); while (len-- > 0) { nexpo = g_nexp[scan[0][RED]]; if (g_nexp[scan[0][GRN]] < nexpo) @@ -120,21 +161,33 @@ int len; scan[0][EXP] = COLXS - nexpo; scan++; } + return(0); } +void shiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */ register COLR *scan; register int len; register int adjust; { + int minexp; + + if (adjust == 0) + return; + minexp = adjust < 0 ? -adjust : 0; while (len-- > 0) { - scan[0][EXP] += adjust; + if (scan[0][EXP] <= minexp) + scan[0][RED] = scan[0][GRN] = scan[0][BLU] = + scan[0][EXP] = 0; + else + scan[0][EXP] += adjust; scan++; } } +void normcolrs(scan, len, adjust) /* normalize a scanline of colrs */ register COLR *scan; int len;
