root/radiance/ray/src/common/colrops.c
Revision: 2.3
Committed: Tue Sep 8 10:04:33 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.2: +52 -10 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Integer operations on COLR scanlines
9 */
10
11 #include "color.h"
12
13 #define NULL 0
14
15 extern char *bmalloc();
16
17 #define MAXGSHIFT 31 /* maximum shift for gamma table */
18
19 static BYTE *g_mant = NULL, *g_nexp = NULL;
20
21 static BYTE (*g_bval)[256] = NULL;
22
23 extern double pow();
24
25
26 setcolrcor(f, a2) /* set brightness correction */
27 double (*f)();
28 double a2;
29 {
30 double mult;
31 register int i, j;
32 /* allocate tables */
33 if (g_bval == NULL && (g_bval =
34 (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL)
35 return(-1);
36 /* compute colr -> gamb mapping */
37 mult = 1.0/256.0;
38 for (i = 0; i <= MAXGSHIFT; i++) {
39 for (j = 0; j < 256; j++)
40 g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2);
41 mult *= 0.5;
42 }
43 return(0);
44 }
45
46
47 setcolrinv(f, a2) /* set inverse brightness correction */
48 double (*f)();
49 double a2;
50 {
51 double mult;
52 register int i, j;
53 /* allocate tables */
54 if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL)
55 return(-1);
56 if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL)
57 return(-1);
58 /* compute gamb -> colr mapping */
59 i = 0;
60 mult = 256.0;
61 for (j = 255; j > 0; j--) {
62 while ((g_mant[j] = mult * (*f)(j/256.0, a2)) < 128) {
63 i++;
64 mult *= 2.0;
65 }
66 g_nexp[j] = i;
67 }
68 g_mant[0] = 0;
69 g_nexp[0] = COLXS;
70 return(0);
71 }
72
73
74 setcolrgam(g) /* set gamma conversion */
75 double g;
76 {
77 if (setcolrcor(pow, 1.0/g) < 0)
78 return(-1);
79 return(setcolrinv(pow, g));
80 }
81
82
83 colrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */
84 register COLR *scan;
85 int len;
86 {
87 register int i, expo;
88
89 if (g_bval == NULL)
90 return(-1);
91 while (len-- > 0) {
92 expo = scan[0][EXP] - COLXS;
93 if (expo < -MAXGSHIFT) {
94 if (expo < -MAXGSHIFT-8) {
95 scan[0][RED] =
96 scan[0][GRN] =
97 scan[0][BLU] = 0;
98 } else {
99 i = (-MAXGSHIFT-1) - expo;
100 scan[0][RED] =
101 g_bval[MAXGSHIFT][((scan[0][RED]>>i)+1)>>1];
102 scan[0][GRN] =
103 g_bval[MAXGSHIFT][((scan[0][GRN]>>i)+1)>>1];
104 scan[0][BLU] =
105 g_bval[MAXGSHIFT][((scan[0][BLU]>>i)+1)>>1];
106 }
107 } else if (expo > 0) {
108 if (expo > 8) {
109 scan[0][RED] =
110 scan[0][GRN] =
111 scan[0][BLU] = 255;
112 } else {
113 i = (scan[0][RED]<<1 | 1) << (expo-1);
114 scan[0][RED] = i > 255 ? 255 : g_bval[0][i];
115 i = (scan[0][GRN]<<1 | 1) << (expo-1);
116 scan[0][GRN] = i > 255 ? 255 : g_bval[0][i];
117 i = (scan[0][BLU]<<1 | 1) << (expo-1);
118 scan[0][BLU] = i > 255 ? 255 : g_bval[0][i];
119 }
120 } else {
121 scan[0][RED] = g_bval[-expo][scan[0][RED]];
122 scan[0][GRN] = g_bval[-expo][scan[0][GRN]];
123 scan[0][BLU] = g_bval[-expo][scan[0][BLU]];
124 }
125 scan[0][EXP] = COLXS;
126 scan++;
127 }
128 return(0);
129 }
130
131
132 gambs_colrs(scan, len) /* convert gamma bytes to colr scanline */
133 register COLR *scan;
134 int len;
135 {
136 register int nexpo;
137
138 if (g_mant == NULL | g_nexp == NULL)
139 return(-1);
140 while (len-- > 0) {
141 nexpo = g_nexp[scan[0][RED]];
142 if (g_nexp[scan[0][GRN]] < nexpo)
143 nexpo = g_nexp[scan[0][GRN]];
144 if (g_nexp[scan[0][BLU]] < nexpo)
145 nexpo = g_nexp[scan[0][BLU]];
146 if (nexpo < g_nexp[scan[0][RED]])
147 scan[0][RED] = g_mant[scan[0][RED]]
148 >> (g_nexp[scan[0][RED]]-nexpo);
149 else
150 scan[0][RED] = g_mant[scan[0][RED]];
151 if (nexpo < g_nexp[scan[0][GRN]])
152 scan[0][GRN] = g_mant[scan[0][GRN]]
153 >> (g_nexp[scan[0][GRN]]-nexpo);
154 else
155 scan[0][GRN] = g_mant[scan[0][GRN]];
156 if (nexpo < g_nexp[scan[0][BLU]])
157 scan[0][BLU] = g_mant[scan[0][BLU]]
158 >> (g_nexp[scan[0][BLU]]-nexpo);
159 else
160 scan[0][BLU] = g_mant[scan[0][BLU]];
161 scan[0][EXP] = COLXS - nexpo;
162 scan++;
163 }
164 return(0);
165 }
166
167
168 shiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */
169 register COLR *scan;
170 register int len;
171 register int adjust;
172 {
173 int minexp;
174
175 if (adjust == 0)
176 return;
177 minexp = adjust < 0 ? -adjust : 0;
178 while (len-- > 0) {
179 if (scan[0][EXP] <= minexp)
180 scan[0][RED] = scan[0][GRN] = scan[0][BLU] =
181 scan[0][EXP] = 0;
182 else
183 scan[0][EXP] += adjust;
184 scan++;
185 }
186 }
187
188
189 normcolrs(scan, len, adjust) /* normalize a scanline of colrs */
190 register COLR *scan;
191 int len;
192 int adjust;
193 {
194 register int c;
195 register int shift;
196
197 while (len-- > 0) {
198 shift = scan[0][EXP] + adjust - COLXS;
199 if (shift > 0) {
200 if (shift > 8) {
201 scan[0][RED] =
202 scan[0][GRN] =
203 scan[0][BLU] = 255;
204 } else {
205 shift--;
206 c = (scan[0][RED]<<1 | 1) << shift;
207 scan[0][RED] = c > 255 ? 255 : c;
208 c = (scan[0][GRN]<<1 | 1) << shift;
209 scan[0][GRN] = c > 255 ? 255 : c;
210 c = (scan[0][BLU]<<1 | 1) << shift;
211 scan[0][BLU] = c > 255 ? 255 : c;
212 }
213 } else if (shift < 0) {
214 if (shift < -8) {
215 scan[0][RED] =
216 scan[0][GRN] =
217 scan[0][BLU] = 0;
218 } else {
219 shift = -1-shift;
220 scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1;
221 scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1;
222 scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1;
223 }
224 }
225 scan[0][EXP] = COLXS - adjust;
226 scan++;
227 }
228 }
