root/radiance/ray/src/common/colrops.c
Revision: 2.8
Committed: Mon Mar 10 17:13:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.7: +1 -3 lines
2 static const char RCSid[] = "$Id: colrops.c,v 2.7 2003/02/25 02:47:21 greg Exp $";
5 * Integer operations on COLR scanlines
6 */
7
8 #include "copyright.h"
9
10 #include <math.h>
11 #include "color.h"
12
13 extern char *bmalloc();
14
15 #define MAXGSHIFT 31 /* maximum shift for gamma table */
16
17 static BYTE *g_mant = NULL, *g_nexp = NULL;
18
19 static BYTE (*g_bval)[256] = NULL;
20
21
22 int
23 setcolrcor(f, a2) /* set brightness correction */
24 double (*f)();
25 double a2;
26 {
27 double mult;
28 register int i, j;
29 /* allocate tables */
30 if (g_bval == NULL && (g_bval =
31 (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL)
32 return(-1);
33 /* compute colr -> gamb mapping */
34 mult = 1.0/256.0;
35 for (i = 0; i <= MAXGSHIFT; i++) {
36 for (j = 0; j < 256; j++)
37 g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2);
38 mult *= 0.5;
39 }
40 return(0);
41 }
42
43
44 int
45 setcolrinv(f, a2) /* set inverse brightness correction */
46 double (*f)();
47 double a2;
48 {
49 double mult;
50 register int i, j;
51 /* allocate tables */
52 if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL)
53 return(-1);
54 if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL)
55 return(-1);
56 /* compute gamb -> colr mapping */
57 i = 0;
58 mult = 256.0;
59 for (j = 256; j--; ) {
60 while ((g_mant[j] = mult * (*f)((j+.5)/256.0, a2)) < 128) {
61 i++;
62 mult *= 2.0;
63 }
64 g_nexp[j] = i;
65 }
66 return(0);
67 }
68
69
70 int
71 setcolrgam(g) /* set gamma conversion */
72 double g;
73 {
74 if (setcolrcor(pow, 1.0/g) < 0)
75 return(-1);
76 return(setcolrinv(pow, g));
77 }
78
79
80 int
81 colrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */
82 register COLR *scan;
83 int len;
84 {
85 register int i, expo;
86
87 if (g_bval == NULL)
88 return(-1);
89 while (len-- > 0) {
90 expo = scan[0][EXP] - COLXS;
91 if (expo < -MAXGSHIFT) {
92 if (expo < -MAXGSHIFT-8) {
93 scan[0][RED] =
94 scan[0][GRN] =
95 scan[0][BLU] = 0;
96 } else {
97 i = (-MAXGSHIFT-1) - expo;
98 scan[0][RED] =
99 g_bval[MAXGSHIFT][((scan[0][RED]>>i)+1)>>1];
100 scan[0][GRN] =
101 g_bval[MAXGSHIFT][((scan[0][GRN]>>i)+1)>>1];
102 scan[0][BLU] =
103 g_bval[MAXGSHIFT][((scan[0][BLU]>>i)+1)>>1];
104 }
105 } else if (expo > 0) {
106 if (expo > 8) {
107 scan[0][RED] =
108 scan[0][GRN] =
109 scan[0][BLU] = 255;
110 } else {
111 i = (scan[0][RED]<<1 | 1) << (expo-1);
112 scan[0][RED] = i > 255 ? 255 : g_bval[0][i];
113 i = (scan[0][GRN]<<1 | 1) << (expo-1);
114 scan[0][GRN] = i > 255 ? 255 : g_bval[0][i];
115 i = (scan[0][BLU]<<1 | 1) << (expo-1);
116 scan[0][BLU] = i > 255 ? 255 : g_bval[0][i];
117 }
118 } else {
119 scan[0][RED] = g_bval[-expo][scan[0][RED]];
120 scan[0][GRN] = g_bval[-expo][scan[0][GRN]];
121 scan[0][BLU] = g_bval[-expo][scan[0][BLU]];
122 }
123 scan[0][EXP] = COLXS;
124 scan++;
125 }
126 return(0);
127 }
128
129
130 int
131 gambs_colrs(scan, len) /* convert gamma bytes to colr scanline */
132 register COLR *scan;
133 int len;
134 {
135 register int nexpo;
136
137 if (g_mant == NULL | g_nexp == NULL)
138 return(-1);
139 while (len-- > 0) {
140 nexpo = g_nexp[scan[0][RED]];
141 if (g_nexp[scan[0][GRN]] < nexpo)
142 nexpo = g_nexp[scan[0][GRN]];
143 if (g_nexp[scan[0][BLU]] < nexpo)
144 nexpo = g_nexp[scan[0][BLU]];
145 if (nexpo < g_nexp[scan[0][RED]])
146 scan[0][RED] = g_mant[scan[0][RED]]
147 >> (g_nexp[scan[0][RED]]-nexpo);
148 else
149 scan[0][RED] = g_mant[scan[0][RED]];
150 if (nexpo < g_nexp[scan[0][GRN]])
151 scan[0][GRN] = g_mant[scan[0][GRN]]
152 >> (g_nexp[scan[0][GRN]]-nexpo);
153 else
154 scan[0][GRN] = g_mant[scan[0][GRN]];
155 if (nexpo < g_nexp[scan[0][BLU]])
156 scan[0][BLU] = g_mant[scan[0][BLU]]
157 >> (g_nexp[scan[0][BLU]]-nexpo);
158 else
159 scan[0][BLU] = g_mant[scan[0][BLU]];
160 scan[0][EXP] = COLXS - nexpo;
161 scan++;
162 }
163 return(0);
164 }
165
166
167 void
168 shiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */
169 register COLR *scan;
170 register int len;
171 register int adjust;
172 {
173 int minexp;
174
175 if (adjust == 0)
176 return;
177 minexp = adjust < 0 ? -adjust : 0;
178 while (len-- > 0) {
179 if (scan[0][EXP] <= minexp)
180 scan[0][RED] = scan[0][GRN] = scan[0][BLU] =
181 scan[0][EXP] = 0;
182 else
183 scan[0][EXP] += adjust;
184 scan++;
185 }
186 }
187
188
189 void
190 normcolrs(scan, len, adjust) /* normalize a scanline of colrs */
191 register COLR *scan;
192 int len;
193 int adjust;
194 {
195 register int c;
196 register int shift;
197
198 while (len-- > 0) {
199 shift = scan[0][EXP] + adjust - COLXS;
200 if (shift > 0) {
201 if (shift > 8) {
202 scan[0][RED] =
203 scan[0][GRN] =
204 scan[0][BLU] = 255;
205 } else {
206 shift--;
207 c = (scan[0][RED]<<1 | 1) << shift;
208 scan[0][RED] = c > 255 ? 255 : c;
209 c = (scan[0][GRN]<<1 | 1) << shift;
210 scan[0][GRN] = c > 255 ? 255 : c;
211 c = (scan[0][BLU]<<1 | 1) << shift;
212 scan[0][BLU] = c > 255 ? 255 : c;
213 }
214 } else if (shift < 0) {
215 if (shift < -8) {
216 scan[0][RED] =
217 scan[0][GRN] =
218 scan[0][BLU] = 0;
219 } else {
220 shift = -1-shift;
221 scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1;
222 scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1;
223 scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1;
224 }
225 }
226 scan[0][EXP] = COLXS - adjust;
227 scan++;
228 }
229 }
