root/radiance/ray/src/common/colrops.c
Revision: 2.10
Committed: Sun Jul 27 22:12:01 2003 UTC (22 years ago) by schorsch
2 static const char RCSid[] = "$Id: colrops.c,v 2.9 2003/06/30 19:04:29 greg Exp $";
5 * Integer operations on COLR scanlines
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <math.h>
12 #include "color.h"
13
14 extern char *bmalloc();
15
16 #define MAXGSHIFT 31 /* maximum shift for gamma table */
17
18 static BYTE *g_mant = NULL, *g_nexp = NULL;
19
20 static BYTE (*g_bval)[256] = NULL;
21
22
23 int
24 setcolrcor(f, a2) /* set brightness correction */
25 double (*f)();
26 double a2;
27 {
28 double mult;
29 register int i, j;
30 /* allocate tables */
31 if (g_bval == NULL && (g_bval =
32 (BYTE (*)[256])bmalloc((MAXGSHIFT+1)*256)) == NULL)
33 return(-1);
34 /* compute colr -> gamb mapping */
35 mult = 1.0/256.0;
36 for (i = 0; i <= MAXGSHIFT; i++) {
37 for (j = 0; j < 256; j++)
38 g_bval[i][j] = 256.0 * (*f)((j+.5)*mult, a2);
39 mult *= 0.5;
40 }
41 return(0);
42 }
43
44
45 int
46 setcolrinv(f, a2) /* set inverse brightness correction */
47 double (*f)();
48 double a2;
49 {
50 double mult;
51 register int i, j;
52 /* allocate tables */
53 if (g_mant == NULL && (g_mant = (BYTE *)bmalloc(256)) == NULL)
54 return(-1);
55 if (g_nexp == NULL && (g_nexp = (BYTE *)bmalloc(256)) == NULL)
56 return(-1);
57 /* compute gamb -> colr mapping */
58 i = 0;
59 mult = 256.0;
60 for (j = 256; j--; ) {
61 while ((g_mant[j] = mult * (*f)((j+.5)/256.0, a2)) < 128) {
62 i++;
63 mult *= 2.0;
64 }
65 g_nexp[j] = i;
66 }
67 return(0);
68 }
69
70
71 int
72 setcolrgam(g) /* set gamma conversion */
73 double g;
74 {
75 if (setcolrcor(pow, 1.0/g) < 0)
76 return(-1);
77 return(setcolrinv(pow, g));
78 }
79
80
81 int
82 colrs_gambs(scan, len) /* convert scanline of colrs to gamma bytes */
83 register COLR *scan;
84 int len;
85 {
86 register int i, expo;
87
88 if (g_bval == NULL)
89 return(-1);
90 while (len-- > 0) {
91 expo = scan[0][EXP] - COLXS;
92 if (expo < -MAXGSHIFT) {
93 if (expo < -MAXGSHIFT-8) {
94 scan[0][RED] =
95 scan[0][GRN] =
96 scan[0][BLU] = 0;
97 } else {
98 i = (-MAXGSHIFT-1) - expo;
99 scan[0][RED] =
100 g_bval[MAXGSHIFT][((scan[0][RED]>>i)+1)>>1];
101 scan[0][GRN] =
102 g_bval[MAXGSHIFT][((scan[0][GRN]>>i)+1)>>1];
103 scan[0][BLU] =
104 g_bval[MAXGSHIFT][((scan[0][BLU]>>i)+1)>>1];
105 }
106 } else if (expo > 0) {
107 if (expo > 8) {
108 scan[0][RED] =
109 scan[0][GRN] =
110 scan[0][BLU] = 255;
111 } else {
112 i = (scan[0][RED]<<1 | 1) << (expo-1);
113 scan[0][RED] = i > 255 ? 255 : g_bval[0][i];
114 i = (scan[0][GRN]<<1 | 1) << (expo-1);
115 scan[0][GRN] = i > 255 ? 255 : g_bval[0][i];
116 i = (scan[0][BLU]<<1 | 1) << (expo-1);
117 scan[0][BLU] = i > 255 ? 255 : g_bval[0][i];
118 }
119 } else {
120 scan[0][RED] = g_bval[-expo][scan[0][RED]];
121 scan[0][GRN] = g_bval[-expo][scan[0][GRN]];
122 scan[0][BLU] = g_bval[-expo][scan[0][BLU]];
123 }
124 scan[0][EXP] = COLXS;
125 scan++;
126 }
127 return(0);
128 }
129
130
131 int
132 gambs_colrs(scan, len) /* convert gamma bytes to colr scanline */
133 register COLR *scan;
134 int len;
135 {
136 register int nexpo;
137
138 if ((g_mant == NULL) | (g_nexp == NULL))
139 return(-1);
140 while (len-- > 0) {
141 nexpo = g_nexp[scan[0][RED]];
142 if (g_nexp[scan[0][GRN]] < nexpo)
143 nexpo = g_nexp[scan[0][GRN]];
144 if (g_nexp[scan[0][BLU]] < nexpo)
145 nexpo = g_nexp[scan[0][BLU]];
146 if (nexpo < g_nexp[scan[0][RED]])
147 scan[0][RED] = g_mant[scan[0][RED]]
148 >> (g_nexp[scan[0][RED]]-nexpo);
149 else
150 scan[0][RED] = g_mant[scan[0][RED]];
151 if (nexpo < g_nexp[scan[0][GRN]])
152 scan[0][GRN] = g_mant[scan[0][GRN]]
153 >> (g_nexp[scan[0][GRN]]-nexpo);
154 else
155 scan[0][GRN] = g_mant[scan[0][GRN]];
156 if (nexpo < g_nexp[scan[0][BLU]])
157 scan[0][BLU] = g_mant[scan[0][BLU]]
158 >> (g_nexp[scan[0][BLU]]-nexpo);
159 else
160 scan[0][BLU] = g_mant[scan[0][BLU]];
161 scan[0][EXP] = COLXS - nexpo;
162 scan++;
163 }
164 return(0);
165 }
166
167
168 void
169 shiftcolrs(scan, len, adjust) /* shift a scanline of colors by 2^adjust */
170 register COLR *scan;
171 register int len;
172 register int adjust;
173 {
174 int minexp;
175
176 if (adjust == 0)
177 return;
178 minexp = adjust < 0 ? -adjust : 0;
179 while (len-- > 0) {
180 if (scan[0][EXP] <= minexp)
181 scan[0][RED] = scan[0][GRN] = scan[0][BLU] =
182 scan[0][EXP] = 0;
183 else
184 scan[0][EXP] += adjust;
185 scan++;
186 }
187 }
188
189
190 void
191 normcolrs(scan, len, adjust) /* normalize a scanline of colrs */
192 register COLR *scan;
193 int len;
194 int adjust;
195 {
196 register int c;
197 register int shift;
198
199 while (len-- > 0) {
200 shift = scan[0][EXP] + adjust - COLXS;
201 if (shift > 0) {
202 if (shift > 8) {
203 scan[0][RED] =
204 scan[0][GRN] =
205 scan[0][BLU] = 255;
206 } else {
207 shift--;
208 c = (scan[0][RED]<<1 | 1) << shift;
209 scan[0][RED] = c > 255 ? 255 : c;
210 c = (scan[0][GRN]<<1 | 1) << shift;
211 scan[0][GRN] = c > 255 ? 255 : c;
212 c = (scan[0][BLU]<<1 | 1) << shift;
213 scan[0][BLU] = c > 255 ? 255 : c;
214 }
215 } else if (shift < 0) {
216 if (shift < -8) {
217 scan[0][RED] =
218 scan[0][GRN] =
219 scan[0][BLU] = 0;
220 } else {
221 shift = -1-shift;
222 scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1;
223 scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1;
224 scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1;
225 }
226 }
227 scan[0][EXP] = COLXS - adjust;
228 scan++;
229 }
230 }
