root/Development/ray/src/common/colrops.c
Wed Jul 30 10:11:06 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.10: +5 -4 lines
Sun Jul 27 22:12:01 2003 UTC (22 years, 5 months ago) by schorsch
Mon Jun 30 19:04:29 2003 UTC (22 years, 6 months ago) by greg
Mon Mar 10 17:13:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.7: +1 -3 lines
Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.5: +66 -8 lines
Wed Jan 21 12:55:00 1998 UTC (27 years, 11 months ago) by gregl
Changes since 2.4: +4 -6 lines
made conversion from gamma-corrected bytes more robust --
no more zeroes in output
Fri Oct 2 16:00:51 1992 UTC (33 years, 3 months ago) by greg
Tue Sep 8 10:04:33 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.2: +52 -10 lines
Tue Feb 18 15:25:55 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.1: +10 -1 lines
bug fix for small exponents in shiftcolrs()
Tue Nov 12 16:55:43 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.3
Fri Nov 9 20:46:50 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.2
increased MAXGSHIFT (again)
Fri Oct 19 21:31:54 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1
increased MAXGSHIFT and made other accuracy improvements
Fri Oct 19 16:33:44 1990 UTC (35 years, 2 months ago) by greg
