root/radiance/ray/src/common/color.h
Revision: 2.9
Committed: Fri Sep 2 12:02:17 1994 UTC (29 years, 8 months ago) by greg
added comment as to values of CIE_rf, CIE_gf and CIE_bf
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * color.h - header for routines using pixel color values.
7 *
8 * 12/31/85
9 *
10 * Two color representations are used, one for calculation and
11 * another for storage. Calculation is done with three floats
12 * for speed. Stored color values use 4 bytes which contain
13 * three single byte mantissas and a common exponent.
14 */
15
16 #define RED 0
17 #define GRN 1
18 #define BLU 2
19 #define EXP 3
20 #define COLXS 128 /* excess used for exponent */
21
22 typedef unsigned char BYTE; /* 8-bit unsigned integer */
23
24 typedef BYTE COLR[4]; /* red, green, blue, exponent */
25
26 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
27 c1[2]=c2[2],c1[3]=c2[3])
28
29 typedef float COLOR[3]; /* red, green, blue */
30
31 #define colval(col,pri) ((col)[pri])
32
33 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
34
35 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
36
37 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
38
39 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
40
41 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
42
43 #ifdef NTSC
44 #define CIE_x_r 0.670 /* standard NTSC primaries */
45 #define CIE_y_r 0.330
46 #define CIE_x_g 0.210
47 #define CIE_y_g 0.710
48 #define CIE_x_b 0.140
49 #define CIE_y_b 0.080
50 #define CIE_x_w 0.3333 /* use true white */
51 #define CIE_y_w 0.3333
52 #else
53 #define CIE_x_r 0.640 /* nominal CRT primaries */
54 #define CIE_y_r 0.330
55 #define CIE_x_g 0.290
56 #define CIE_y_g 0.600
57 #define CIE_x_b 0.150
58 #define CIE_y_b 0.060
59 #define CIE_x_w 0.3333 /* use true white */
60 #define CIE_y_w 0.3333
61 #endif
62
63 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
64 CIE_x_g*(CIE_y_b - CIE_y_r) + \
65 CIE_x_b*(CIE_y_r - CIE_y_g) )
66 #define CIE_C_rD ( (1./CIE_y_w) * \
67 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \
68 CIE_y_w*(CIE_x_g - CIE_x_b) + \
69 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
70 #define CIE_C_gD ( (1./CIE_y_w) * \
71 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \
72 CIE_y_w*(CIE_x_b - CIE_x_r) - \
73 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
74 #define CIE_C_bD ( (1./CIE_y_w) * \
75 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \
76 CIE_y_w*(CIE_x_r - CIE_x_g) + \
77 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
78
79 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
80 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
81 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
82
83 /* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */
84
85 #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU])
86 #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \
87 (long)(CIE_gf*256.+.5)*(c)[GRN] + \
88 (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 )
89
90 /* luminous efficacies over visible spectrum */
91 #define MAXEFFICACY 683. /* defined maximum at 550 nm */
92 #define WHTEFFICACY 179. /* uniform white light */
93 #define D65EFFICACY 203. /* standard illuminant D65 */
94 #define INCEFFICACY 160. /* illuminant A (incand.) */
95 #define SUNEFFICACY 208. /* illuminant B (solar dir.) */
96 #define SKYEFFICACY D65EFFICACY /* skylight */
97 #define DAYEFFICACY D65EFFICACY /* combined sky and solar */
98
99 #define luminance(col) (WHTEFFICACY * bright(col))
100
101 #define intens(col) ( (col)[0] > (col)[1] \
102 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
103 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
104
105 #define colrval(c,p) ( (c)[EXP] ? \
106 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
107 0. )
108
109 #define WHTCOLOR {1.0,1.0,1.0}
110 #define BLKCOLOR {0.0,0.0,0.0}
111 #define WHTCOLR {128,128,128,COLXS+1}
112 #define BLKCOLR {0,0,0,0}
113
114 /* picture format identifier */
115 #define COLRFMT "32-bit_rle_rgbe"
116
117 /* macros for exposures */
118 #define EXPOSSTR "EXPOSURE="
119 #define LEXPOSSTR 9
120 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR))
121 #define exposval(hl) atof((hl)+LEXPOSSTR)
122 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
123
124 /* macros for pixel aspect ratios */
125 #define ASPECTSTR "PIXASPECT="
126 #define LASPECTSTR 10
127 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR))
128 #define aspectval(hl) atof((hl)+LASPECTSTR)
129 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
130
131 /* macros for color correction */
132 #define COLCORSTR "COLORCORR="
133 #define LCOLCORSTR 10
134 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR))
135 #define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \
136 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
137 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
138 (cc)[RED],(cc)[GRN],(cc)[BLU])
139
140 #ifdef DCL_ATOF
141 extern double atof(), ldexp(), frexp();
142 #endif
