1 |
/* RCSid $Id: color.h,v 2.40 2023/11/21 01:30:20 greg Exp $ */ |
2 |
3 |
* color.h - header for routines using pixel color and spectral values |
4 |
5 |
* Two color representations are used, one for calculation and |
6 |
* another for storage. Calculation is done with three floats |
7 |
* for speed. Stored color values use 4 bytes which contain |
8 |
* three single byte mantissas and a common exponent. |
9 |
10 |
* Spectral colors have between 3 and MAXCSAMP samples, and cover |
11 |
* wavelengths from WLPART[0] to WLPART[3] (max to min nanometers). |
12 |
* Wavelengths WLPART[1] and WLPART[2] mark the separation |
13 |
* of red/green and green/blue intervals, respectively. |
14 |
* The wavelength range may go well beyond visible in either |
15 |
* direction, but some routines will average over each interval |
16 |
* and designate the means as R, G, and B, regardless. |
17 |
* The number of samples is set in CNDX[3], and CNDX[0,1,2] |
18 |
* give peak wavelength indices corresponding to stdprims. |
19 |
* For best accuracy, internal calculations are promoted to |
20 |
* the current number of samples and final conversions |
21 |
* to tristimulus should use scolor_rgb() or scolor_cie(). |
22 |
23 |
* A new Radiance format is provided for spectral pictures, |
24 |
* and spectral colors must be converted by caller using |
25 |
* convertscolor() if the sampling doesn't match. |
26 |
27 |
#ifndef _RAD_COLOR_H_ |
28 |
#define _RAD_COLOR_H_ |
29 |
30 |
#include <stdio.h> |
31 |
#include <stdlib.h> |
32 |
#include <string.h> |
33 |
34 |
#ifdef __cplusplus |
35 |
extern "C" { |
36 |
#endif |
37 |
38 |
#ifndef MAXCSAMP |
39 |
#define MAXCSAMP 24 /* maximum # spectral samples */ |
40 |
#endif |
41 |
42 |
#define RED 0 |
43 |
#define GRN 1 |
44 |
#define BLU 2 |
45 |
#define CIEX 0 /* or, if input is XYZ... */ |
46 |
#define CIEY 1 |
47 |
#define CIEZ 2 |
48 |
#define EXP 3 /* exponent same for either format */ |
49 |
#define COLXS 128 /* excess used for exponent */ |
50 |
#define WHT 3 /* used for RGBPRIMS type */ |
51 |
52 |
#undef uby8 |
53 |
#define uby8 unsigned char /* 8-bit unsigned integer */ |
54 |
55 |
typedef uby8 COLR[4]; /* red, green, blue (or X,Y,Z), exponent */ |
56 |
typedef uby8 SCOLR[MAXCSAMP+1]; /* spectral color, common exponent */ |
57 |
58 |
typedef float COLORV; |
59 |
typedef COLORV COLOR[3]; /* red, green, blue (or X,Y,Z) */ |
60 |
typedef COLORV SCOLOR[MAXCSAMP]; /* spectral color */ |
61 |
62 |
typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */ |
63 |
typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */ |
64 |
65 |
typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */ |
66 |
67 |
#define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \ |
68 |
c1[2]=c2[2],c1[3]=c2[3]) |
69 |
70 |
#define colval(col,pri) (col)[pri] |
71 |
72 |
#define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b)) |
73 |
74 |
#define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf)) |
75 |
76 |
#define opcolor(c1,op,c2) ((c1)[0]op(c2)[0],(c1)[1]op(c2)[1],(c1)[2]op(c2)[2]) |
77 |
78 |
#define copycolor(c1,c2) opcolor(c1,=,c2) |
79 |
80 |
#define addcolor(c1,c2) opcolor(c1,+=,c2) |
81 |
82 |
#define multcolor(c1,c2) opcolor(c1,*=,c2) |
83 |
84 |
#define NCSAMP CNDX[EXP] /* current number of spectral samples */ |
85 |
#define LSCOLR (NCSAMP+1) |
86 |
87 |
#define copyscolr(sc1,sc2) memcpy(sc1,sc2,LSCOLR) |
88 |
89 |
#define scolval(sc,pri) (sc)[CNDX[pri]] |
90 |
91 |
#define copyscolor(sc1,sc2) memcpy(sc1,sc2,sizeof(COLORV)*NCSAMP) |
92 |
93 |
#define scalescolor(sc,sf) {const float _f=sf; int _i=NCSAMP; \ |
94 |
while (_i--) (sc)[_i] *= _f;} |
95 |
96 |
/* faster, use principal colors for RGB */ |
97 |
#define pcolor_color(col,scol) setcolor(col,scolval(scol,RED),\ |
98 |
scolval(scol,GRN),scolval(scol,BLU)) |
99 |
#define pcolor_colr(clr,scol) setcolr(clr,scolval(scol,RED),\ |
100 |
101 |
102 |
#define sopscolor(sc1,op,sc2) {int _i=NCSAMP; while (_i--) (sc1)[_i] op (sc2)[_i];} |
103 |
104 |
#define saddscolor(sc1,sc2) sopscolor(sc1,+=,sc2) |
105 |
106 |
#define smultscolor(sc1,sc2) sopscolor(sc1,*=,sc2) |
107 |
108 |
#define scolrblack(c) memset(c,0,LSCOLR) |
109 |
110 |
#define scolorblack(c) memset(c,0,sizeof(COLORV)*MAXCSAMP) |
111 |
112 |
#define scolor_color(col,scol) scolor2color(col,scol,NCSAMP,WLPART) |
113 |
#define scolor_colr(clr,scol) scolor2colr(clr,scol,NCSAMP,WLPART) |
114 |
#define scolor_scolr(sclr,scol) scolor2scolr(sclr,scol,NCSAMP) |
115 |
#define scolr_scolor(scol,sclr) scolr2scolor(scol,sclr,NCSAMP) |
116 |
#define scolr_color(col,sclr) scolr2color(col,sclr,NCSAMP,WLPART) |
117 |
118 |
#define sopcolor(sc1,op,c2) {SCOLOR _sct;\ |
119 |
setscolor(_sct,c2[RED],c2[GRN],c2[BLU]);\ |
120 |
sopscolor(sc1,op,_sct);} |
121 |
122 |
#define saddcolor(sc1,c2) sopcolor(sc1,+=,c2) |
123 |
124 |
#define smultcolor(sc1,c2) sopcolor(sc1,*=,c2) |
125 |
126 |
#define opscolor(c1,op,sc2) {COLOR _ct; scolor_color(_ct,sc2);\ |
127 |
opcolor(c1,op,_ct);} |
128 |
129 |
#define addscolor(c1,sc2) opscolor(c1,+=,sc2) |
130 |
131 |
#define multscolor(c1,sc2) opscolor(c1,*=,sc2) |
132 |
133 |
#if defined(NTSC_RGB) |
134 |
#define CIE_x_r 0.670 /* standard NTSC primaries */ |
135 |
#define CIE_y_r 0.330 |
136 |
#define CIE_x_g 0.210 |
137 |
#define CIE_y_g 0.710 |
138 |
#define CIE_x_b 0.140 |
139 |
#define CIE_y_b 0.080 |
140 |
#define CIE_x_w (1./3.) /* use EE white */ |
141 |
#define CIE_y_w (1./3.) |
142 |
#elif defined(SHARP_RGB) |
143 |
#define CIE_x_r 0.6898 /* "sharp" RGB primaries */ |
144 |
#define CIE_y_r 0.3206 |
145 |
#define CIE_x_g 0.0736 |
146 |
#define CIE_y_g 0.9003 |
147 |
#define CIE_x_b 0.1166 |
148 |
#define CIE_y_b 0.0374 |
149 |
150 |
151 |
#else |
152 |
#define CIE_x_r 0.640 /* nominal CRT primaries */ |
153 |
154 |
#define CIE_x_g 0.290 |
155 |
#define CIE_y_g 0.600 |
156 |
#define CIE_x_b 0.150 |
157 |
#define CIE_y_b 0.060 |
158 |
159 |
160 |
#endif |
161 |
162 |
#define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \ |
163 |
{CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}} |
164 |
165 |
#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \ |
166 |
CIE_x_g*(CIE_y_b - CIE_y_r) + \ |
167 |
CIE_x_b*(CIE_y_r - CIE_y_g) ) |
168 |
#define CIE_C_rD ( (1./CIE_y_w) * \ |
169 |
( CIE_x_w*(CIE_y_g - CIE_y_b) - \ |
170 |
CIE_y_w*(CIE_x_g - CIE_x_b) + \ |
171 |
CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ) |
172 |
#define CIE_C_gD ( (1./CIE_y_w) * \ |
173 |
( CIE_x_w*(CIE_y_b - CIE_y_r) - \ |
174 |
CIE_y_w*(CIE_x_b - CIE_x_r) - \ |
175 |
CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ) |
176 |
#define CIE_C_bD ( (1./CIE_y_w) * \ |
177 |
( CIE_x_w*(CIE_y_r - CIE_y_g) - \ |
178 |
CIE_y_w*(CIE_x_r - CIE_x_g) + \ |
179 |
CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ) |
180 |
181 |
#define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D) |
182 |
#define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D) |
183 |
#define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D) |
184 |
185 |
/* Default CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */ |
186 |
187 |
/***** The following definitions are not for XYZ colors *****/ |
188 |
189 |
#define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU]) |
190 |
#define pbright(col) (CIE_rf*scolval(col,RED) + CIE_gf*scolval(col,GRN) + \ |
191 |
CIE_bf*scolval(col,BLU)) |
192 |
#define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \ |
193 |
(long)(CIE_gf*256.+.5)*(c)[GRN] + \ |
194 |
(long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 ) |
195 |
#define normpbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[CNDX[RED]] + \ |
196 |
(long)(CIE_gf*256.+.5)*(c)[CNDX[GRN]] + \ |
197 |
(long)(CIE_bf*256.+.5)*(c)[CNDX[BLU]] ) >> 8 ) |
198 |
199 |
/* luminous efficacies over visible spectrum */ |
200 |
#define MAXEFFICACY 683. /* defined maximum at 550 nm */ |
201 |
#define WHTEFFICACY 179. /* equal energy white 380-780nm */ |
202 |
#define D65EFFICACY 203. /* standard illuminant D65 */ |
203 |
#define INCEFFICACY 160. /* illuminant A (incand.) */ |
204 |
#define SUNEFFICACY 208. /* illuminant B (solar dir.) */ |
205 |
#define SKYEFFICACY D65EFFICACY /* skylight (should be 110) */ |
206 |
#define DAYEFFICACY D65EFFICACY /* combined sky and solar */ |
207 |
#define WHTSCOTOPIC 412. /* scotopic EE white 380-780nm */ |
208 |
#define WHTMELANOPIC 179. /* melanopic EE white 380-780nm */ |
209 |
210 |
#define luminance(col) (WHTEFFICACY * bright(col)) |
211 |
#define pluminance(scol) (WHTEFFICACY * pbright(scol)) |
212 |
213 |
#define scolor_rgb(col,scol) scolor2rgb(col,scol,NCSAMP,WLPART) |
214 |
215 |
/***** ...end of stuff specific to RGB colors *****/ |
216 |
217 |
#define scolor_cie(col,scol) scolor2cie(col,scol,NCSAMP,WLPART) |
218 |
219 |
#define sluminance(scol) (WHTEFFICACY * scolor_photopic(scol)) |
220 |
221 |
#define intens(col) ( (col)[0] > (col)[1] \ |
222 |
? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \ |
223 |
: (col)[1] > (col)[2] ? (col)[1] : (col)[2] ) |
224 |
225 |
#define colrval(c,p) ( (c)[EXP] ? \ |
226 |
ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \ |
227 |
0. ) |
228 |
229 |
#define scolrval(c,p) ( (c)[CNDX[EXP]] ? \ |
230 |
ldexp((c)[CNDX[p]]+.5,(int)(c)[CNDX[EXP]]-(COLXS+8)) : \ |
231 |
0. ) |
232 |
233 |
#define WHTCOLOR {1.0,1.0,1.0} |
234 |
#define BLKCOLOR {0.0,0.0,0.0} |
235 |
#define WHTCOLR {128,128,128,COLXS+1} |
236 |
#define BLKCOLR {0,0,0,0} |
237 |
238 |
/* picture format identifier */ |
239 |
#define COLRFMT "32-bit_rle_rgbe" |
240 |
#define CIEFMT "32-bit_rle_xyze" |
241 |
#define PICFMT "32-bit_rle_???e" /* matches either */ |
242 |
#define SPECFMT "Radiance_spectra" /* spectral data w/ exponent */ |
243 |
244 |
/* Number of spectral components */ |
245 |
#define NCOMPSTR "NCOMP=" |
246 |
#define LNCOMPSTR 6 |
247 |
#define isncomp(hl) (!strncmp(hl,NCOMPSTR,LNCOMPSTR)) |
248 |
#define ncompval(hl) atoi((hl)+LNCOMPSTR) |
249 |
#define fputncomp(nc,fp) fprintf(fp,"%s%d\n",NCOMPSTR,nc) |
250 |
251 |
/* 4 wavelength partitions for (IR+)R,G,B(+UV) */ |
252 |
#define WLSPLTSTR "WAVELENGTH_SPLITS=" |
253 |
#define LWLSPLTSTR 18 |
254 |
#define iswlsplit(hl) (!strncmp(hl,WLSPLTSTR,LWLSPLTSTR)) |
255 |
#define wlsplitval(w,hl) (sscanf((hl)+LWLSPLTSTR,"%f %f %f %f",\ |
256 |
&(w)[0],&(w)[1],&(w)[2],&(w)[3]) == 4) |
257 |
#define fputwlsplit(w,fp) fprintf(fp,"%s %g %g %g %g\n",WLSPLTSTR,\ |
258 |
(w)[0],(w)[1],(w)[2],(w)[3]) |
259 |
260 |
/* macros for exposures */ |
261 |
#define EXPOSSTR "EXPOSURE=" |
262 |
#define LEXPOSSTR 9 |
263 |
#define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR)) |
264 |
#define exposval(hl) atof((hl)+LEXPOSSTR) |
265 |
#define fputexpos(ex,fp) fprintf(fp,"%s%.4e\n",EXPOSSTR,ex) |
266 |
267 |
/* macros for pixel aspect ratios */ |
268 |
#define ASPECTSTR "PIXASPECT=" |
269 |
#define LASPECTSTR 10 |
270 |
#define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR)) |
271 |
#define aspectval(hl) atof((hl)+LASPECTSTR) |
272 |
#define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa) |
273 |
274 |
/* macros for primary specifications */ |
275 |
#define PRIMARYSTR "PRIMARIES=" |
276 |
#define LPRIMARYSTR 10 |
277 |
#define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR)) |
278 |
#define primsval(p,hl) (sscanf((hl)+LPRIMARYSTR, \ |
279 |
"%f %f %f %f %f %f %f %f", \ |
280 |
&(p)[RED][CIEX],&(p)[RED][CIEY], \ |
281 |
&(p)[GRN][CIEX],&(p)[GRN][CIEY], \ |
282 |
&(p)[BLU][CIEX],&(p)[BLU][CIEY], \ |
283 |
&(p)[WHT][CIEX],&(p)[WHT][CIEY]) == 8) |
284 |
#define fputprims(p,fp) fprintf(fp, \ |
285 |
"%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\ |
286 |
PRIMARYSTR, \ |
287 |
(p)[RED][CIEX],(p)[RED][CIEY], \ |
288 |
(p)[GRN][CIEX],(p)[GRN][CIEY], \ |
289 |
(p)[BLU][CIEX],(p)[BLU][CIEY], \ |
290 |
(p)[WHT][CIEX],(p)[WHT][CIEY]) |
291 |
292 |
/* macros for color correction */ |
293 |
#define COLCORSTR "COLORCORR=" |
294 |
#define LCOLCORSTR 10 |
295 |
#define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR)) |
296 |
#define colcorval(cc,hl) sscanf((hl)+LCOLCORSTR,"%f %f %f", \ |
297 |
&(cc)[RED],&(cc)[GRN],&(cc)[BLU]) |
298 |
#define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \ |
299 |
(cc)[RED],(cc)[GRN],(cc)[BLU]) |
300 |
301 |
302 |
* Conversions to and from XYZ space generally don't apply WHTEFFICACY. |
303 |
* If you need Y to be luminance (cd/m^2), this must be applied when |
304 |
* converting from radiance (watts/sr/m^2). |
305 |
306 |
307 |
extern int CNDX[4]; /* RGBE indices for SCOLOR, SCOLR */ |
308 |
extern float WLPART[4]; /* RGB wavelength limits+partitions (nm) */ |
309 |
extern RGBPRIMS stdprims; /* standard primary chromaticities */ |
310 |
extern RGBPRIMS xyzprims; /* to indicate XYZ input or output */ |
311 |
extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */ |
312 |
extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */ |
313 |
extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */ |
314 |
315 |
#define CGAMUT_LOWER 01 |
316 |
#define CGAMUT_UPPER 02 |
317 |
#define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER) |
318 |
319 |
#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb) |
320 |
321 |
#define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT)) |
322 |
323 |
/* defined in color.c */ |
324 |
extern void *tempbuffer(size_t len); |
325 |
/* in cn[3]=nsamps, wlpt[0],wlpt[3]=extrema */ |
326 |
extern int setspectrsamp(int cn[4], float wlpt[4]); |
327 |
extern int fwritecolrs(COLR *scanline, int len, FILE *fp); |
328 |
extern int fwritescan(COLOR *scanline, int len, FILE *fp); |
329 |
extern int fwritescolrs(uby8 *sscanline, int nc, int len, FILE *fp); |
330 |
extern int fwritesscan(COLORV *sscanline, int nc, int len, FILE *fp); |
331 |
extern int freadcolrs(COLR *scanline, int len, FILE *fp); |
332 |
extern int freadscan(COLOR *scanline, int len, FILE *fp); |
333 |
extern int freadscolrs(uby8 *scanline, int nc, int len, FILE *fp); |
334 |
extern int freadsscan(COLORV *sscanline, int nc, int len, FILE *fp); |
335 |
/* spectrum conversion, zero-fill past ends */ |
336 |
extern void convertscolor(SCOLOR dst, int dnc, double dwl0, double dwl1, |
337 |
const COLORV src[], int snc, double swl0, double swl1); |
338 |
/* the following use avg spectral ranges */ |
339 |
/* compare scolor_rgb() and scolor_cie() */ |
340 |
/* also, pcolor_color() and pcolor_colr() */ |
341 |
extern void setscolor(SCOLOR scol, double r, double g, double b); |
342 |
extern void scolor2color(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); |
343 |
extern void scolor2colr(COLR clr, SCOLOR scol, int ncs, const float wlpt[4]); |
344 |
extern void scolor2scolr(SCOLR sclr, SCOLOR scol, int ncs); |
345 |
extern void colr_color(COLOR col, COLR clr); |
346 |
extern void scolr2scolor(SCOLOR scol, SCOLR sclr, int ncs); |
347 |
extern void scolr2color(COLOR col, SCOLR sclr, int ncs, const float wlpt[4]); |
348 |
extern void colr_scolor(SCOLOR scol, COLR clr); |
349 |
extern void setcolr(COLR clr, double r, double g, double b); |
350 |
extern void setscolr(SCOLR sclr, double r, double g, double b); |
351 |
extern double scolor_mean(SCOLOR scol); |
352 |
extern double sintens(SCOLOR scol); |
353 |
extern int bigdiff(COLOR c1, COLOR c2, double md); |
354 |
extern int sbigsdiff(SCOLOR sc1, SCOLOR sc2, double md); |
355 |
/* defined in spec_rgb.c */ |
356 |
extern void spec_cie(COLOR col, int s, int e); |
357 |
extern void spec_rgb(COLOR col, int s, int e); |
358 |
extern void cie_rgb(COLOR rgb, COLOR xyz); |
359 |
extern int clipgamut(COLOR col, double brt, int gamut, |
360 |
COLOR lower, COLOR upper); |
361 |
extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1); |
362 |
extern void multcolormat(COLORMAT m3, COLORMAT m2, |
363 |
COLORMAT m1); |
364 |
extern int colorprimsOK(RGBPRIMS pr); |
365 |
extern int compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr); |
366 |
extern int comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr); |
367 |
extern int comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); |
368 |
extern int compxyzWBmat(COLORMAT mat, float wht1[2], |
369 |
float wht2[2]); |
370 |
extern int compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr); |
371 |
extern int comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr); |
372 |
extern int comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); |
373 |
/* most accurate spectral->tristim */ |
374 |
extern void scolor2cie(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); |
375 |
extern void scolor2rgb(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); |
376 |
extern double scolor2photopic(SCOLOR scol, int ncs, const float wlpt[4]); |
377 |
extern double scolor2scotopic(SCOLOR scol, int ncs, const float wlpt[4]); |
378 |
extern double scolor2melanopic(SCOLOR scol, int ncs, const float wlpt[4]); |
379 |
extern double scolor_photopic(SCOLOR scol); |
380 |
extern double scolor_scotopic(SCOLOR scol); |
381 |
extern double scolor_melanopic(SCOLOR scol); |
382 |
/* defined in colrops.c */ |
383 |
extern int setcolrcor(double (*f)(double, double), double a2); |
384 |
extern int setcolrinv(double (*f)(double, double), double a2); |
385 |
extern int setcolrgam(double g); |
386 |
extern int colrs_gambs(COLR *scan, int len); |
387 |
extern int gambs_colrs(COLR *scan, int len); |
388 |
extern void shiftcolrs(COLR *scan, int len, int adjust); |
389 |
extern void normcolrs(COLR *scan, int len, int adjust); |
390 |
391 |
392 |
393 |
#endif |
394 |
#endif /* _RAD_COLOR_H_ */ |
395 |
