root/radiance/ray/src/common/color.h
Revision: 2.26
Committed: Wed Jul 30 10:11:06 2003 UTC (20 years, 10 months ago) by schorsch
1 /* RCSid $Id: color.h,v 2.25 2003/07/14 22:23:59 schorsch Exp $ */
2 /*
3 * color.h - header for routines using pixel color values.
4 *
5 * Must be included after X11 headers, since they declare a BYTE type.
6 *
7 * Two color representations are used, one for calculation and
8 * another for storage. Calculation is done with three floats
9 * for speed. Stored color values use 4 bytes which contain
10 * three single byte mantissas and a common exponent.
11 */
12 #ifndef _RAD_COLOR_H_
13 #define _RAD_COLOR_H_
14
15 #include <stdlib.h>
16
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
20
21 #define RED 0
22 #define GRN 1
23 #define BLU 2
24 #define CIEX 0 /* or, if input is XYZ... */
25 #define CIEY 1
26 #define CIEZ 2
27 #define EXP 3 /* exponent same for either format */
28 #define COLXS 128 /* excess used for exponent */
29 #define WHT 3 /* used for RGBPRIMS type */
30
31 #undef BYTE
32 #define BYTE unsigned char /* 8-bit unsigned integer */
33
34 typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */
35
36 typedef float COLOR[3]; /* red, green, blue (or X,Y,Z) */
37
38 typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */
39 typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */
40
41 typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */
42
43 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
44 c1[2]=c2[2],c1[3]=c2[3])
45
46 #define colval(col,pri) ((col)[pri])
47
48 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
49
50 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
51
52 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
53
54 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
55
56 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
57
58 #ifdef NTSC
59 #define CIE_x_r 0.670 /* standard NTSC primaries */
60 #define CIE_y_r 0.330
61 #define CIE_x_g 0.210
62 #define CIE_y_g 0.710
63 #define CIE_x_b 0.140
64 #define CIE_y_b 0.080
65 #define CIE_x_w 0.3333 /* use true white */
66 #define CIE_y_w 0.3333
67 #else
68 #define CIE_x_r 0.640 /* nominal CRT primaries */
69 #define CIE_y_r 0.330
70 #define CIE_x_g 0.290
71 #define CIE_y_g 0.600
72 #define CIE_x_b 0.150
73 #define CIE_y_b 0.060
74 #define CIE_x_w 0.3333 /* use true white */
75 #define CIE_y_w 0.3333
76 #endif
77
78 #define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \
79 {CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}}
80
81 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
82 CIE_x_g*(CIE_y_b - CIE_y_r) + \
83 CIE_x_b*(CIE_y_r - CIE_y_g) )
84 #define CIE_C_rD ( (1./CIE_y_w) * \
85 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \
86 CIE_y_w*(CIE_x_g - CIE_x_b) + \
87 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
88 #define CIE_C_gD ( (1./CIE_y_w) * \
89 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \
90 CIE_y_w*(CIE_x_b - CIE_x_r) - \
91 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
92 #define CIE_C_bD ( (1./CIE_y_w) * \
93 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \
94 CIE_y_w*(CIE_x_r - CIE_x_g) + \
95 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
96
97 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
98 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
99 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
100
101 /* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */
102
103 /***** The following definitions are valid for RGB colors only... *****/
104
105 #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU])
106 #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \
107 (long)(CIE_gf*256.+.5)*(c)[GRN] + \
108 (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 )
109
110 /* luminous efficacies over visible spectrum */
111 #define MAXEFFICACY 683. /* defined maximum at 550 nm */
112 #define WHTEFFICACY 179. /* uniform white light */
113 #define D65EFFICACY 203. /* standard illuminant D65 */
114 #define INCEFFICACY 160. /* illuminant A (incand.) */
115 #define SUNEFFICACY 208. /* illuminant B (solar dir.) */
116 #define SKYEFFICACY D65EFFICACY /* skylight */
117 #define DAYEFFICACY D65EFFICACY /* combined sky and solar */
118
119 #define luminance(col) (WHTEFFICACY * bright(col))
120
121 /***** ...end of stuff specific to RGB colors *****/
122
123 #define intens(col) ( (col)[0] > (col)[1] \
124 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
125 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
126
127 #define colrval(c,p) ( (c)[EXP] ? \
128 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
129 0. )
130
131 #define WHTCOLOR {1.0,1.0,1.0}
132 #define BLKCOLOR {0.0,0.0,0.0}
133 #define WHTCOLR {128,128,128,COLXS+1}
134 #define BLKCOLR {0,0,0,0}
135
136 /* picture format identifier */
137 #define COLRFMT "32-bit_rle_rgbe"
138 #define CIEFMT "32-bit_rle_xyze"
139 #define PICFMT "32-bit_rle_???e" /* matches either */
140 #define LPICFMT 15 /* max format id len */
141
142 /* macros for exposures */
143 #define EXPOSSTR "EXPOSURE="
144 #define LEXPOSSTR 9
145 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR))
146 #define exposval(hl) atof((hl)+LEXPOSSTR)
147 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
148
149 /* macros for pixel aspect ratios */
150 #define ASPECTSTR "PIXASPECT="
151 #define LASPECTSTR 10
152 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR))
153 #define aspectval(hl) atof((hl)+LASPECTSTR)
154 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
155
156 /* macros for primary specifications */
157 #define PRIMARYSTR "PRIMARIES="
158 #define LPRIMARYSTR 10
159 #define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR))
160 #define primsval(p,hl) sscanf(hl+LPRIMARYSTR, \
161 "%f %f %f %f %f %f %f %f", \
162 &(p)[RED][CIEX],&(p)[RED][CIEY], \
163 &(p)[GRN][CIEX],&(p)[GRN][CIEY], \
164 &(p)[BLU][CIEX],&(p)[BLU][CIEY], \
165 &(p)[WHT][CIEX],&(p)[WHT][CIEY])
166 #define fputprims(p,fp) fprintf(fp, \
167 "%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\
168 PRIMARYSTR, \
169 (p)[RED][CIEX],(p)[RED][CIEY], \
170 (p)[GRN][CIEX],(p)[GRN][CIEY], \
171 (p)[BLU][CIEX],(p)[BLU][CIEY], \
172 (p)[WHT][CIEX],(p)[WHT][CIEY])
173
174 /* macros for color correction */
175 #define COLCORSTR "COLORCORR="
176 #define LCOLCORSTR 10
177 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR))
178 #define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \
179 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
180 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
181 (cc)[RED],(cc)[GRN],(cc)[BLU])
182
183 /*
184 * Conversions to and from XYZ space generally don't apply WHTEFFICACY.
185 * If you need Y to be luminance (cd/m^2), this must be applied when
186 * converting from radiance (watts/sr/m^2).
187 */
188
189 extern RGBPRIMS stdprims; /* standard primary chromaticities */
190 extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
191 extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
192 extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */
193
194 #define CGAMUT_LOWER 01
195 #define CGAMUT_UPPER 02
196 #define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER)
197
198 #define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
199
200 #define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT))
201
202 /* defined in color.c */
203 extern char *tempbuffer(unsigned int len);
204 extern int fwritecolrs(COLR *scanline, int len, FILE *fp);
205 extern int freadcolrs(COLR *scanline, int len, FILE *fp);
206 extern int fwritescan(COLOR *scanline, int len, FILE *fp);
207 extern int freadscan(COLOR *scanline, int len, FILE *fp);
208 extern void setcolr(COLR clr, double r, double g, double b);
209 extern void colr_color(COLOR col, COLR clr);
210 extern int bigdiff(COLOR c1, COLOR c2, double md);
211 /* defined in spec_rgb.c */
212 extern void spec_rgb(COLOR col, int s, int e);
213 extern void spec_cie(COLOR col, int s, int e);
214 extern void cie_rgb(COLOR rgb, COLOR xyz);
215 extern int clipgamut(COLOR col, double brt, int gamut,
216 COLOR lower, COLOR upper);
217 extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1);
218 extern void multcolormat(COLORMAT m3, COLORMAT m2,
219 COLORMAT m1);
220 extern void compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr);
221 extern void comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr);
222 extern void comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
223 extern void compxyzWBmat(COLORMAT mat, float wht1[2],
224 float wht2[2]);
225 extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr);
226 extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr);
227 extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
228 /* defined in colrops.c */
229 extern int setcolrcor(double (*f)(double, double), double a2);
230 extern int setcolrinv(double (*f)(double, double), double a2);
231 extern int setcolrgam(double g);
232 extern int colrs_gambs(COLR *scan, int len);
233 extern int gambs_colrs(COLR *scan, int len);
234 extern void shiftcolrs(COLR *scan, int len, int adjust);
235 extern void normcolrs(COLR *scan, int len, int adjust);
236
237
238 #ifdef __cplusplus
239 }
240 #endif
241 #endif /* _RAD_COLOR_H_ */
242
