root/radiance/ray/src/common/color.h
Revision: 2.21
Committed: Fri Jun 6 16:38:47 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.20: +9 -40 lines
*** empty log message ***
1 /* RCSid $Id: color.h,v 2.20 2003/05/13 17:58:32 greg Exp $ */
2 /*
3 * color.h - header for routines using pixel color values.
4 *
5 * Must be included after X11 headers, since they declare a BYTE type.
6 *
7 * Two color representations are used, one for calculation and
8 * another for storage. Calculation is done with three floats
9 * for speed. Stored color values use 4 bytes which contain
10 * three single byte mantissas and a common exponent.
11 */
12 #ifndef _RAD_COLOR_H_
13 #define _RAD_COLOR_H_
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18
19 #include "copyright.h"
20
21 #include <stdio.h>
22 #include <stdlib.h>
23
24 #define RED 0
25 #define GRN 1
26 #define BLU 2
27 #define CIEX 0 /* or, if input is XYZ... */
28 #define CIEY 1
29 #define CIEZ 2
30 #define EXP 3 /* exponent same for either format */
31 #define COLXS 128 /* excess used for exponent */
32 #define WHT 3 /* used for RGBPRIMS type */
33
34 #undef BYTE
35 #define BYTE unsigned char /* 8-bit unsigned integer */
36
37 typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */
38
39 typedef float COLOR[3]; /* red, green, blue (or X,Y,Z) */
40
41 typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */
42 typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */
43
44 typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */
45
46 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
47 c1[2]=c2[2],c1[3]=c2[3])
48
49 #define colval(col,pri) ((col)[pri])
50
51 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
52
53 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
54
55 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
56
57 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
58
59 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
60
61 #ifdef NTSC
62 #define CIE_x_r 0.670 /* standard NTSC primaries */
63 #define CIE_y_r 0.330
64 #define CIE_x_g 0.210
65 #define CIE_y_g 0.710
66 #define CIE_x_b 0.140
67 #define CIE_y_b 0.080
68 #define CIE_x_w 0.3333 /* use true white */
69 #define CIE_y_w 0.3333
70 #else
71 #define CIE_x_r 0.640 /* nominal CRT primaries */
72 #define CIE_y_r 0.330
73 #define CIE_x_g 0.290
74 #define CIE_y_g 0.600
75 #define CIE_x_b 0.150
76 #define CIE_y_b 0.060
77 #define CIE_x_w 0.3333 /* use true white */
78 #define CIE_y_w 0.3333
79 #endif
80
81 #define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \
82 {CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}}
83
84 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
85 CIE_x_g*(CIE_y_b - CIE_y_r) + \
86 CIE_x_b*(CIE_y_r - CIE_y_g) )
87 #define CIE_C_rD ( (1./CIE_y_w) * \
88 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \
89 CIE_y_w*(CIE_x_g - CIE_x_b) + \
90 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
91 #define CIE_C_gD ( (1./CIE_y_w) * \
92 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \
93 CIE_y_w*(CIE_x_b - CIE_x_r) - \
94 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
95 #define CIE_C_bD ( (1./CIE_y_w) * \
96 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \
97 CIE_y_w*(CIE_x_r - CIE_x_g) + \
98 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
99
100 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
101 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
102 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
103
104 /* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */
105
106 /***** The following definitions are valid for RGB colors only... *****/
107
108 #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU])
109 #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \
110 (long)(CIE_gf*256.+.5)*(c)[GRN] + \
111 (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 )
112
113 /* luminous efficacies over visible spectrum */
114 #define MAXEFFICACY 683. /* defined maximum at 550 nm */
115 #define WHTEFFICACY 179. /* uniform white light */
116 #define D65EFFICACY 203. /* standard illuminant D65 */
117 #define INCEFFICACY 160. /* illuminant A (incand.) */
118 #define SUNEFFICACY 208. /* illuminant B (solar dir.) */
119 #define SKYEFFICACY D65EFFICACY /* skylight */
120 #define DAYEFFICACY D65EFFICACY /* combined sky and solar */
121
122 #define luminance(col) (WHTEFFICACY * bright(col))
123
124 /***** ...end of stuff specific to RGB colors *****/
125
126 #define intens(col) ( (col)[0] > (col)[1] \
127 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
128 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
129
130 #define colrval(c,p) ( (c)[EXP] ? \
131 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
132 0. )
133
134 #define WHTCOLOR {1.0,1.0,1.0}
135 #define BLKCOLOR {0.0,0.0,0.0}
136 #define WHTCOLR {128,128,128,COLXS+1}
137 #define BLKCOLR {0,0,0,0}
138
139 /* picture format identifier */
140 #define COLRFMT "32-bit_rle_rgbe"
141 #define CIEFMT "32-bit_rle_xyze"
142 #define PICFMT "32-bit_rle_???e" /* matches either */
143 #define LPICFMT 15 /* max format id len */
144
145 /* macros for exposures */
146 #define EXPOSSTR "EXPOSURE="
147 #define LEXPOSSTR 9
148 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR))
149 #define exposval(hl) atof((hl)+LEXPOSSTR)
150 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
151
152 /* macros for pixel aspect ratios */
153 #define ASPECTSTR "PIXASPECT="
154 #define LASPECTSTR 10
155 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR))
156 #define aspectval(hl) atof((hl)+LASPECTSTR)
157 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
158
159 /* macros for primary specifications */
160 #define PRIMARYSTR "PRIMARIES="
161 #define LPRIMARYSTR 10
162 #define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR))
163 #define primsval(p,hl) sscanf(hl+LPRIMARYSTR, \
164 "%f %f %f %f %f %f %f %f", \
165 &(p)[RED][CIEX],&(p)[RED][CIEY], \
166 &(p)[GRN][CIEX],&(p)[GRN][CIEY], \
167 &(p)[BLU][CIEX],&(p)[BLU][CIEY], \
168 &(p)[WHT][CIEX],&(p)[WHT][CIEY])
169 #define fputprims(p,fp) fprintf(fp, \
170 "%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\
171 PRIMARYSTR, \
172 (p)[RED][CIEX],(p)[RED][CIEY], \
173 (p)[GRN][CIEX],(p)[GRN][CIEY], \
174 (p)[BLU][CIEX],(p)[BLU][CIEY], \
175 (p)[WHT][CIEX],(p)[WHT][CIEY])
176
177 /* macros for color correction */
178 #define COLCORSTR "COLORCORR="
179 #define LCOLCORSTR 10
180 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR))
181 #define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \
182 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
183 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
184 (cc)[RED],(cc)[GRN],(cc)[BLU])
185
186 /*
187 * Conversions to and from XYZ space generally don't apply WHTEFFICACY.
188 * If you need Y to be luminance (cd/m^2), this must be applied when
189 * converting from radiance (watts/sr/m^2).
190 */
191
192 extern RGBPRIMS stdprims; /* standard primary chromaticities */
193 extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
194 extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
195 extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */
196
197 #define CGAMUT_LOWER 01
198 #define CGAMUT_UPPER 02
199 #define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER)
200
201 #define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
202
203 #ifdef BSD
204 #define cpcolormat(md,ms) bcopy((void *)ms,(void *)md,sizeof(COLORMAT))
205 #else
206 #define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT))
207 #endif
208
209 /* defined in color.c */
210 extern char *tempbuffer(unsigned int len);
211 extern int fwritecolrs(COLR *scanline, int len, FILE *fp);
212 extern int freadcolrs(COLR *scanline, int len, FILE *fp);
213 extern int fwritescan(COLOR *scanline, int len, FILE *fp);
214 extern int freadscan(COLOR *scanline, int len, FILE *fp);
215 extern void setcolr(COLR clr, double r, double g, double b);
216 extern void colr_color(COLOR col, COLR clr);
217 extern int bigdiff(COLOR c1, COLOR c2, double md);
218 /* defined in spec_rgb.c */
219 extern void spec_rgb(COLOR col, int s, int e);
220 extern void spec_cie(COLOR col, int s, int e);
221 extern void cie_rgb(COLOR rgb, COLOR xyz);
222 extern int clipgamut(COLOR col, double brt, int gamut,
223 COLOR lower, COLOR upper);
224 extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1);
225 extern void multcolormat(COLORMAT m3, COLORMAT m2,
226 COLORMAT m1);
227 extern void compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr);
228 extern void comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr);
229 extern void comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
230 extern void compxyzWBmat(COLORMAT mat, float wht1[2],
231 float wht2[2]);
232 extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr);
233 extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr);
234 extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
235 /* defined in colrops.c */
236 extern int setcolrcor(double (*f)(), double a2);
237 extern int setcolrinv(double (*f)(), double a2);
238 extern int setcolrgam(double g);
239 extern int colrs_gambs(COLR *scan, int len);
240 extern int gambs_colrs(COLR *scan, int len);
241 extern void shiftcolrs(COLR *scan, int len, int adjust);
242 extern void normcolrs(COLR *scan, int len, int adjust);
243
244
245 #ifdef __cplusplus
246 }
247 #endif
248 #endif /* _RAD_COLOR_H_ */
249
