root/radiance/ray/src/common/color.h
Revision: 2.20
Committed: Tue May 13 17:58:32 2003 UTC (20 years, 11 months ago) by greg
1 /* RCSid $Id$ */
2 /*
3 * color.h - header for routines using pixel color values.
4 *
5 * Must be included after X11 headers, since they declare a BYTE type.
6 *
7 * Two color representations are used, one for calculation and
8 * another for storage. Calculation is done with three floats
9 * for speed. Stored color values use 4 bytes which contain
10 * three single byte mantissas and a common exponent.
11 */
12
13 #include "copyright.h"
14
15 #include <stdio.h>
16 #include <stdlib.h>
17
18 #ifdef __cplusplus
19 extern "C" {
20 #endif
21
22 #define RED 0
23 #define GRN 1
24 #define BLU 2
25 #define CIEX 0 /* or, if input is XYZ... */
26 #define CIEY 1
27 #define CIEZ 2
28 #define EXP 3 /* exponent same for either format */
29 #define COLXS 128 /* excess used for exponent */
30 #define WHT 3 /* used for RGBPRIMS type */
31
32 #undef BYTE
33 #define BYTE unsigned char /* 8-bit unsigned integer */
34
35 typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */
36
37 typedef float COLOR[3]; /* red, green, blue (or X,Y,Z) */
38
39 typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */
40 typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */
41
42 typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */
43
44 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
45 c1[2]=c2[2],c1[3]=c2[3])
46
47 #define colval(col,pri) ((col)[pri])
48
49 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
50
51 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
52
53 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
54
55 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
56
57 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
58
59 #ifdef NTSC
60 #define CIE_x_r 0.670 /* standard NTSC primaries */
61 #define CIE_y_r 0.330
62 #define CIE_x_g 0.210
63 #define CIE_y_g 0.710
64 #define CIE_x_b 0.140
65 #define CIE_y_b 0.080
66 #define CIE_x_w 0.3333 /* use true white */
67 #define CIE_y_w 0.3333
68 #else
69 #define CIE_x_r 0.640 /* nominal CRT primaries */
70 #define CIE_y_r 0.330
71 #define CIE_x_g 0.290
72 #define CIE_y_g 0.600
73 #define CIE_x_b 0.150
74 #define CIE_y_b 0.060
75 #define CIE_x_w 0.3333 /* use true white */
76 #define CIE_y_w 0.3333
77 #endif
78
79 #define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \
80 {CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}}
81
82 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
83 CIE_x_g*(CIE_y_b - CIE_y_r) + \
84 CIE_x_b*(CIE_y_r - CIE_y_g) )
85 #define CIE_C_rD ( (1./CIE_y_w) * \
86 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \
87 CIE_y_w*(CIE_x_g - CIE_x_b) + \
88 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
89 #define CIE_C_gD ( (1./CIE_y_w) * \
90 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \
91 CIE_y_w*(CIE_x_b - CIE_x_r) - \
92 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
93 #define CIE_C_bD ( (1./CIE_y_w) * \
94 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \
95 CIE_y_w*(CIE_x_r - CIE_x_g) + \
96 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
97
98 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
99 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
100 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
101
102 /* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */
103
104 /***** The following definitions are valid for RGB colors only... *****/
105
106 #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU])
107 #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \
108 (long)(CIE_gf*256.+.5)*(c)[GRN] + \
109 (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 )
110
111 /* luminous efficacies over visible spectrum */
112 #define MAXEFFICACY 683. /* defined maximum at 550 nm */
113 #define WHTEFFICACY 179. /* uniform white light */
114 #define D65EFFICACY 203. /* standard illuminant D65 */
115 #define INCEFFICACY 160. /* illuminant A (incand.) */
116 #define SUNEFFICACY 208. /* illuminant B (solar dir.) */
117 #define SKYEFFICACY D65EFFICACY /* skylight */
118 #define DAYEFFICACY D65EFFICACY /* combined sky and solar */
119
120 #define luminance(col) (WHTEFFICACY * bright(col))
121
122 /***** ...end of stuff specific to RGB colors *****/
123
124 #define intens(col) ( (col)[0] > (col)[1] \
125 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
126 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
127
128 #define colrval(c,p) ( (c)[EXP] ? \
129 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
130 0. )
131
132 #define WHTCOLOR {1.0,1.0,1.0}
133 #define BLKCOLOR {0.0,0.0,0.0}
134 #define WHTCOLR {128,128,128,COLXS+1}
135 #define BLKCOLR {0,0,0,0}
136
137 /* picture format identifier */
138 #define COLRFMT "32-bit_rle_rgbe"
139 #define CIEFMT "32-bit_rle_xyze"
140 #define PICFMT "32-bit_rle_???e" /* matches either */
141 #define LPICFMT 15 /* max format id len */
142
143 /* macros for exposures */
144 #define EXPOSSTR "EXPOSURE="
145 #define LEXPOSSTR 9
146 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR))
147 #define exposval(hl) atof((hl)+LEXPOSSTR)
148 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
149
150 /* macros for pixel aspect ratios */
151 #define ASPECTSTR "PIXASPECT="
152 #define LASPECTSTR 10
153 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR))
154 #define aspectval(hl) atof((hl)+LASPECTSTR)
155 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
156
157 /* macros for primary specifications */
158 #define PRIMARYSTR "PRIMARIES="
159 #define LPRIMARYSTR 10
160 #define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR))
161 #define primsval(p,hl) sscanf(hl+LPRIMARYSTR, \
162 "%f %f %f %f %f %f %f %f", \
163 &(p)[RED][CIEX],&(p)[RED][CIEY], \
164 &(p)[GRN][CIEX],&(p)[GRN][CIEY], \
165 &(p)[BLU][CIEX],&(p)[BLU][CIEY], \
166 &(p)[WHT][CIEX],&(p)[WHT][CIEY])
167 #define fputprims(p,fp) fprintf(fp, \
168 "%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\
169 PRIMARYSTR, \
170 (p)[RED][CIEX],(p)[RED][CIEY], \
171 (p)[GRN][CIEX],(p)[GRN][CIEY], \
172 (p)[BLU][CIEX],(p)[BLU][CIEY], \
173 (p)[WHT][CIEX],(p)[WHT][CIEY])
174
175 /* macros for color correction */
176 #define COLCORSTR "COLORCORR="
177 #define LCOLCORSTR 10
178 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR))
179 #define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \
180 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
181 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
182 (cc)[RED],(cc)[GRN],(cc)[BLU])
183
184 /*
185 * Conversions to and from XYZ space generally don't apply WHTEFFICACY.
186 * If you need Y to be luminance (cd/m^2), this must be applied when
187 * converting from radiance (watts/sr/m^2).
188 */
189
190 extern RGBPRIMS stdprims; /* standard primary chromaticities */
191 extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
192 extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
193 extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */
194
195 #define CGAMUT_LOWER 01
196 #define CGAMUT_UPPER 02
197 #define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER)
198
199 #define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
200
201 #ifdef BSD
202 #define cpcolormat(md,ms) bcopy((void *)ms,(void *)md,sizeof(COLORMAT))
203 #else
204 #define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT))
205 #endif
206
207 #ifdef NOPROTO
208 /* defined in color.c */
209 extern char *tempbuffer();
210 extern int fwritecolrs();
211 extern int freadcolrs();
212 extern int fwritescan();
213 extern int freadscan();
214 extern void setcolr();
215 extern void colr_color();
216 extern int bigdiff();
217 /* defined in spec_rgb.c */
218 extern void spec_rgb();
219 extern void spec_cie();
220 extern void cie_rgb();
221 extern int clipgamut();
222 extern void colortrans();
223 extern void multcolormat();
224 extern void compxyz2rgbmat();
225 extern void comprgb2xyzmat();
226 extern void comprgb2rgbmat();
227 extern void compxyzWBmat();
228 extern void compxyz2rgbWBmat();
229 extern void comprgb2xyzWBmat();
230 extern void comprgb2rgbWBmat();
231 /* defined in colrops.c */
232 extern int setcolrcor();
233 extern int setcolrinv();
234 extern int setcolrgam();
235 extern int colrs_gambs();
236 extern int gambs_colrs();
237 extern void shiftcolrs();
238 extern void normcolrs();
239
240 #else
241 /* defined in color.c */
242 extern char *tempbuffer(unsigned int len);
243 extern int fwritecolrs(COLR *scanline, int len, FILE *fp);
244 extern int freadcolrs(COLR *scanline, int len, FILE *fp);
245 extern int fwritescan(COLOR *scanline, int len, FILE *fp);
246 extern int freadscan(COLOR *scanline, int len, FILE *fp);
247 extern void setcolr(COLR clr, double r, double g, double b);
248 extern void colr_color(COLOR col, COLR clr);
249 extern int bigdiff(COLOR c1, COLOR c2, double md);
250 /* defined in spec_rgb.c */
251 extern void spec_rgb(COLOR col, int s, int e);
252 extern void spec_cie(COLOR col, int s, int e);
253 extern void cie_rgb(COLOR rgb, COLOR xyz);
254 extern int clipgamut(COLOR col, double brt, int gamut,
255 COLOR lower, COLOR upper);
256 extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1);
257 extern void multcolormat(COLORMAT m3, COLORMAT m2,
258 COLORMAT m1);
259 extern void compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr);
260 extern void comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr);
261 extern void comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
262 extern void compxyzWBmat(COLORMAT mat, float wht1[2],
263 float wht2[2]);
264 extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr);
265 extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr);
266 extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
267 /* defined in colrops.c */
268 extern int setcolrcor(double (*f)(), double a2);
269 extern int setcolrinv(double (*f)(), double a2);
270 extern int setcolrgam(double g);
271 extern int colrs_gambs(COLR *scan, int len);
272 extern int gambs_colrs(COLR *scan, int len);
273 extern void shiftcolrs(COLR *scan, int len, int adjust);
274 extern void normcolrs(COLR *scan, int len, int adjust);
275
276 #endif
277
278 #ifdef __cplusplus
279 }
280 #endif
