1 |
/* RCSid $Id$ */ |
2 |
3 |
* color.h - header for routines using pixel color values. |
4 |
5 |
* Must be included after X11 headers, since they declare a BYTE type. |
6 |
7 |
* Two color representations are used, one for calculation and |
8 |
* another for storage. Calculation is done with three floats |
9 |
* for speed. Stored color values use 4 bytes which contain |
10 |
* three single byte mantissas and a common exponent. |
11 |
12 |
13 |
#include "copyright.h" |
14 |
15 |
#include <stdio.h> |
16 |
#include <stdlib.h> |
17 |
18 |
#ifdef __cplusplus |
19 |
extern "C" { |
20 |
#endif |
21 |
22 |
#define RED 0 |
23 |
#define GRN 1 |
24 |
#define BLU 2 |
25 |
#define CIEX 0 /* or, if input is XYZ... */ |
26 |
#define CIEY 1 |
27 |
#define CIEZ 2 |
28 |
#define EXP 3 /* exponent same for either format */ |
29 |
#define COLXS 128 /* excess used for exponent */ |
30 |
#define WHT 3 /* used for RGBPRIMS type */ |
31 |
32 |
#undef BYTE |
33 |
#define BYTE unsigned char /* 8-bit unsigned integer */ |
34 |
35 |
typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */ |
36 |
37 |
typedef float COLOR[3]; /* red, green, blue (or X,Y,Z) */ |
38 |
39 |
typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */ |
40 |
typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */ |
41 |
42 |
typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */ |
43 |
44 |
#define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \ |
45 |
c1[2]=c2[2],c1[3]=c2[3]) |
46 |
47 |
#define colval(col,pri) ((col)[pri]) |
48 |
49 |
#define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b)) |
50 |
51 |
#define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2]) |
52 |
53 |
#define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf)) |
54 |
55 |
#define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2]) |
56 |
57 |
#define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2]) |
58 |
59 |
#ifdef NTSC |
60 |
#define CIE_x_r 0.670 /* standard NTSC primaries */ |
61 |
#define CIE_y_r 0.330 |
62 |
#define CIE_x_g 0.210 |
63 |
#define CIE_y_g 0.710 |
64 |
#define CIE_x_b 0.140 |
65 |
#define CIE_y_b 0.080 |
66 |
#define CIE_x_w 0.3333 /* use true white */ |
67 |
#define CIE_y_w 0.3333 |
68 |
#else |
69 |
#define CIE_x_r 0.640 /* nominal CRT primaries */ |
70 |
71 |
#define CIE_x_g 0.290 |
72 |
#define CIE_y_g 0.600 |
73 |
#define CIE_x_b 0.150 |
74 |
#define CIE_y_b 0.060 |
75 |
76 |
77 |
#endif |
78 |
79 |
#define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \ |
80 |
{CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}} |
81 |
82 |
#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \ |
83 |
CIE_x_g*(CIE_y_b - CIE_y_r) + \ |
84 |
CIE_x_b*(CIE_y_r - CIE_y_g) ) |
85 |
#define CIE_C_rD ( (1./CIE_y_w) * \ |
86 |
( CIE_x_w*(CIE_y_g - CIE_y_b) - \ |
87 |
CIE_y_w*(CIE_x_g - CIE_x_b) + \ |
88 |
CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ) |
89 |
#define CIE_C_gD ( (1./CIE_y_w) * \ |
90 |
( CIE_x_w*(CIE_y_b - CIE_y_r) - \ |
91 |
CIE_y_w*(CIE_x_b - CIE_x_r) - \ |
92 |
CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ) |
93 |
#define CIE_C_bD ( (1./CIE_y_w) * \ |
94 |
( CIE_x_w*(CIE_y_r - CIE_y_g) - \ |
95 |
CIE_y_w*(CIE_x_r - CIE_x_g) + \ |
96 |
CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ) |
97 |
98 |
#define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D) |
99 |
#define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D) |
100 |
#define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D) |
101 |
102 |
/* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */ |
103 |
104 |
/***** The following definitions are valid for RGB colors only... *****/ |
105 |
106 |
#define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU]) |
107 |
#define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \ |
108 |
(long)(CIE_gf*256.+.5)*(c)[GRN] + \ |
109 |
(long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 ) |
110 |
111 |
/* luminous efficacies over visible spectrum */ |
112 |
#define MAXEFFICACY 683. /* defined maximum at 550 nm */ |
113 |
#define WHTEFFICACY 179. /* uniform white light */ |
114 |
#define D65EFFICACY 203. /* standard illuminant D65 */ |
115 |
#define INCEFFICACY 160. /* illuminant A (incand.) */ |
116 |
#define SUNEFFICACY 208. /* illuminant B (solar dir.) */ |
117 |
#define SKYEFFICACY D65EFFICACY /* skylight */ |
118 |
#define DAYEFFICACY D65EFFICACY /* combined sky and solar */ |
119 |
120 |
#define luminance(col) (WHTEFFICACY * bright(col)) |
121 |
122 |
/***** ...end of stuff specific to RGB colors *****/ |
123 |
124 |
#define intens(col) ( (col)[0] > (col)[1] \ |
125 |
? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \ |
126 |
: (col)[1] > (col)[2] ? (col)[1] : (col)[2] ) |
127 |
128 |
#define colrval(c,p) ( (c)[EXP] ? \ |
129 |
ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \ |
130 |
0. ) |
131 |
132 |
#define WHTCOLOR {1.0,1.0,1.0} |
133 |
#define BLKCOLOR {0.0,0.0,0.0} |
134 |
#define WHTCOLR {128,128,128,COLXS+1} |
135 |
#define BLKCOLR {0,0,0,0} |
136 |
137 |
/* picture format identifier */ |
138 |
#define COLRFMT "32-bit_rle_rgbe" |
139 |
#define CIEFMT "32-bit_rle_xyze" |
140 |
#define PICFMT "32-bit_rle_???e" /* matches either */ |
141 |
#define LPICFMT 15 /* max format id len */ |
142 |
143 |
/* macros for exposures */ |
144 |
#define EXPOSSTR "EXPOSURE=" |
145 |
#define LEXPOSSTR 9 |
146 |
#define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR)) |
147 |
#define exposval(hl) atof((hl)+LEXPOSSTR) |
148 |
#define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex) |
149 |
150 |
/* macros for pixel aspect ratios */ |
151 |
#define ASPECTSTR "PIXASPECT=" |
152 |
#define LASPECTSTR 10 |
153 |
#define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR)) |
154 |
#define aspectval(hl) atof((hl)+LASPECTSTR) |
155 |
#define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa) |
156 |
157 |
/* macros for primary specifications */ |
158 |
#define PRIMARYSTR "PRIMARIES=" |
159 |
#define LPRIMARYSTR 10 |
160 |
#define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR)) |
161 |
#define primsval(p,hl) sscanf(hl+LPRIMARYSTR, \ |
162 |
"%f %f %f %f %f %f %f %f", \ |
163 |
&(p)[RED][CIEX],&(p)[RED][CIEY], \ |
164 |
&(p)[GRN][CIEX],&(p)[GRN][CIEY], \ |
165 |
&(p)[BLU][CIEX],&(p)[BLU][CIEY], \ |
166 |
&(p)[WHT][CIEX],&(p)[WHT][CIEY]) |
167 |
#define fputprims(p,fp) fprintf(fp, \ |
168 |
"%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\ |
169 |
PRIMARYSTR, \ |
170 |
(p)[RED][CIEX],(p)[RED][CIEY], \ |
171 |
(p)[GRN][CIEX],(p)[GRN][CIEY], \ |
172 |
(p)[BLU][CIEX],(p)[BLU][CIEY], \ |
173 |
(p)[WHT][CIEX],(p)[WHT][CIEY]) |
174 |
175 |
/* macros for color correction */ |
176 |
#define COLCORSTR "COLORCORR=" |
177 |
#define LCOLCORSTR 10 |
178 |
#define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR)) |
179 |
#define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \ |
180 |
&(cc)[RED],&(cc)[GRN],&(cc)[BLU]) |
181 |
#define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \ |
182 |
(cc)[RED],(cc)[GRN],(cc)[BLU]) |
183 |
184 |
185 |
* Conversions to and from XYZ space generally don't apply WHTEFFICACY. |
186 |
* If you need Y to be luminance (cd/m^2), this must be applied when |
187 |
* converting from radiance (watts/sr/m^2). |
188 |
189 |
190 |
extern RGBPRIMS stdprims; /* standard primary chromaticities */ |
191 |
extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */ |
192 |
extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */ |
193 |
extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */ |
194 |
195 |
#define CGAMUT_LOWER 01 |
196 |
#define CGAMUT_UPPER 02 |
197 |
#define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER) |
198 |
199 |
#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb) |
200 |
201 |
#ifdef BSD |
202 |
#define cpcolormat(md,ms) bcopy((char *)ms,(char *)md,sizeof(COLORMAT)) |
203 |
#else |
204 |
#define cpcolormat(md,ms) memcpy((char *)md,(char *)ms,sizeof(COLORMAT)) |
205 |
#endif |
206 |
207 |
#ifdef NOPROTO |
208 |
/* defined in color.c */ |
209 |
extern char *tempbuffer(); |
210 |
extern int fwritecolrs(); |
211 |
extern int freadcolrs(); |
212 |
extern int fwritescan(); |
213 |
extern int freadscan(); |
214 |
extern void setcolr(); |
215 |
extern void colr_color(); |
216 |
extern int bigdiff(); |
217 |
/* defined in spec_rgb.c */ |
218 |
extern void spec_rgb(); |
219 |
extern void spec_cie(); |
220 |
extern void cie_rgb(); |
221 |
extern int clipgamut(); |
222 |
extern void colortrans(); |
223 |
extern void multcolormat(); |
224 |
extern void compxyz2rgbmat(); |
225 |
extern void comprgb2xyzmat(); |
226 |
extern void comprgb2rgbmat(); |
227 |
extern void compxyzWBmat(); |
228 |
extern void compxyz2rgbWBmat(); |
229 |
extern void comprgb2xyzWBmat(); |
230 |
extern void comprgb2rgbWBmat(); |
231 |
/* defined in colrops.c */ |
232 |
extern int setcolrcor(); |
233 |
extern int setcolrinv(); |
234 |
extern int setcolrgam(); |
235 |
extern int colrs_gambs(); |
236 |
extern int gambs_colrs(); |
237 |
extern void shiftcolrs(); |
238 |
extern void normcolrs(); |
239 |
240 |
#else |
241 |
242 |
extern char *tempbuffer(unsigned int len); |
243 |
extern int fwritecolrs(COLR *scanline, int len, FILE *fp); |
244 |
extern int freadcolrs(COLR *scanline, int len, FILE *fp); |
245 |
extern int fwritescan(COLOR *scanline, int len, FILE *fp); |
246 |
extern int freadscan(COLOR *scanline, int len, FILE *fp); |
247 |
extern void setcolr(COLR clr, double r, double g, double b); |
248 |
extern void colr_color(COLOR col, COLR clr); |
249 |
extern int bigdiff(COLOR c1, COLOR c2, double md); |
250 |
251 |
extern void spec_rgb(COLOR col, int s, int e); |
252 |
extern void spec_cie(COLOR col, int s, int e); |
253 |
extern void cie_rgb(COLOR rgb, COLOR xyz); |
254 |
extern int clipgamut(COLOR col, double brt, int gamut, |
255 |
COLOR lower, COLOR upper); |
256 |
extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1); |
257 |
extern void multcolormat(COLORMAT m3, COLORMAT m2, |
258 |
COLORMAT m1); |
259 |
extern void compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr); |
260 |
extern void comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr); |
261 |
extern void comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); |
262 |
extern void compxyzWBmat(COLORMAT mat, float wht1[2], |
263 |
float wht2[2]); |
264 |
extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr); |
265 |
extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr); |
266 |
extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); |
267 |
268 |
extern int setcolrcor(double (*f)(), double a2); |
269 |
extern int setcolrinv(double (*f)(), double a2); |
270 |
extern int setcolrgam(double g); |
271 |
extern int colrs_gambs(COLR *scan, int len); |
272 |
extern int gambs_colrs(COLR *scan, int len); |
273 |
extern void shiftcolrs(COLR *scan, int len, int adjust); |
274 |
extern void normcolrs(COLR *scan, int len, int adjust); |
275 |
276 |
#endif |
277 |
278 |
279 |
280 |
#endif |
