--- ray/src/common/color.h 2023/11/17 20:02:07 2.39 +++ ray/src/common/color.h 2023/11/21 01:30:20 2.40 @@ -1,4 +1,4 @@ -/* RCSid $Id: color.h,v 2.39 2023/11/17 20:02:07 greg Exp $ */ +/* RCSid $Id: color.h,v 2.40 2023/11/21 01:30:20 greg Exp $ */ /* * color.h - header for routines using pixel color and spectral values * @@ -239,8 +239,7 @@ typedef float COLORMAT[3][3]; /* color coordinate con #define COLRFMT "32-bit_rle_rgbe" #define CIEFMT "32-bit_rle_xyze" #define PICFMT "32-bit_rle_???e" /* matches either */ -#define SPECFMT "Radiance_rle_spectra" /* spectral data w/ exponent */ -#define LPICFMT 21 /* max format id len */ +#define SPECFMT "Radiance_spectra" /* spectral data w/ exponent */ /* Number of spectral components */ #define NCOMPSTR "NCOMP=" @@ -340,12 +339,12 @@ extern void convertscolor(SCOLOR dst, int dnc, double /* compare scolor_rgb() and scolor_cie() */ /* also, pcolor_color() and pcolor_colr() */ extern void setscolor(SCOLOR scol, double r, double g, double b); -extern void scolor2color(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); -extern void scolor2colr(COLR clr, SCOLOR scol, int ncs, float wlpt[4]); +extern void scolor2color(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); +extern void scolor2colr(COLR clr, SCOLOR scol, int ncs, const float wlpt[4]); extern void scolor2scolr(SCOLR sclr, SCOLOR scol, int ncs); extern void colr_color(COLOR col, COLR clr); extern void scolr2scolor(SCOLOR scol, SCOLR sclr, int ncs); -extern void scolr2color(COLOR col, SCOLR sclr, int ncs, float wlpt[4]); +extern void scolr2color(COLOR col, SCOLR sclr, int ncs, const float wlpt[4]); extern void colr_scolor(SCOLOR scol, COLR clr); extern void setcolr(COLR clr, double r, double g, double b); extern void setscolr(SCOLR sclr, double r, double g, double b); @@ -372,8 +371,8 @@ extern int compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr) extern int comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr); extern int comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); /* most accurate spectral->tristim */ -extern void scolor2cie(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); -extern void scolor2rgb(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); +extern void scolor2cie(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); +extern void scolor2rgb(COLOR col, SCOLOR scol, int ncs, const float wlpt[4]); extern double scolor_photopic(SCOLOR scol); extern double scolor_scotopic(SCOLOR scol); extern double scolor_melanopic(SCOLOR scol);
