--- ray/src/common/color.h 2023/04/14 15:49:32 2.37 +++ ray/src/common/color.h 2023/11/15 18:02:52 2.38 @@ -1,22 +1,44 @@ -/* RCSid $Id: color.h,v 2.37 2023/04/14 15:49:32 greg Exp $ */ +/* RCSid $Id: color.h,v 2.38 2023/11/15 18:02:52 greg Exp $ */ /* - * color.h - header for routines using pixel color values. + * color.h - header for routines using pixel color and spectral values * * Two color representations are used, one for calculation and * another for storage. Calculation is done with three floats * for speed. Stored color values use 4 bytes which contain * three single byte mantissas and a common exponent. + * + * Spectral colors have between 3 and MAXCSAMP samples, and cover + * wavelengths from WLPART[0] to WLPART[3] (max to min nanometers). + * Wavelengths WLPART[1] and WLPART[2] mark the separation + * of red/green and green/blue intervals, respectively. + * The wavelength range may go well beyond visible in either + * direction, but some routines will average over each interval + * and designate the means as R, G, and B, regardless. + * The number of samples is set in CNDX[3], and CNDX[0,1,2] + * give peak wavelength indices corresponding to stdprims. + * For best accuracy, internal calculations are promoted to + * the current number of samples and final conversions + * to tristimulus should use scolor_rgb() or scolor_cie(). + * + * A new Radiance format is provided for spectral pictures, + * and spectral colors must be converted by caller using + * convertscolor() if the sampling doesn't match. */ #ifndef _RAD_COLOR_H_ #define _RAD_COLOR_H_ #include #include +#include #ifdef __cplusplus extern "C" { #endif +#ifndef MAXCSAMP +#define MAXCSAMP 24 /* maximum # spectral samples */ +#endif + #define RED 0 #define GRN 1 #define BLU 2 @@ -31,9 +53,11 @@ extern "C" { #define uby8 unsigned char /* 8-bit unsigned integer */ typedef uby8 COLR[4]; /* red, green, blue (or X,Y,Z), exponent */ +typedef uby8 SCOLR[MAXCSAMP+1]; /* spectral color, common exponent */ typedef float COLORV; typedef COLORV COLOR[3]; /* red, green, blue (or X,Y,Z) */ +typedef COLORV SCOLOR[MAXCSAMP]; /* spectral color */ typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */ typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */ @@ -43,18 +67,69 @@ typedef float COLORMAT[3][3]; /* color coordinate con #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \ c1[2]=c2[2],c1[3]=c2[3]) -#define colval(col,pri) ((col)[pri]) +#define colval(col,pri) (col)[pri] #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b)) -#define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2]) - #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf)) -#define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2]) +#define opcolor(c1,op,c2) ((c1)[0]op(c2)[0],(c1)[1]op(c2)[1],(c1)[2]op(c2)[2]) -#define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2]) +#define copycolor(c1,c2) opcolor(c1,=,c2) +#define addcolor(c1,c2) opcolor(c1,+=,c2) + +#define multcolor(c1,c2) opcolor(c1,*=,c2) + +#define NCSAMP CNDX[EXP] /* current number of spectral samples */ +#define LSCOLR (NCSAMP+1) + +#define copyscolr(sc1,sc2) memcpy(sc1,sc2,LSCOLR) + +#define scolval(sc,pri) (sc)[CNDX[pri]] + +#define copyscolor(sc1,sc2) memcpy(sc1,sc2,sizeof(COLORV)*NCSAMP) + +#define scalescolor(sc,sf) {const float _f=sf; int _i=NCSAMP; \ + while (_i--) (sc)[_i] *= _f;} + + /* faster, use principal colors for RGB */ +#define pcolor_color(col,scol) setcolor(col,scolval(scol,RED),\ + scolval(scol,GRN),scolval(scol,BLU)) +#define pcolor_colr(clr,scol) setcolr(clr,scolval(scol,RED),\ + scolval(scol,GRN),scolval(scol,BLU)) + +#define sopscolor(sc1,op,sc2) {int _i=NCSAMP; while (_i--) (sc1)[_i] op (sc2)[_i];} + +#define saddscolor(sc1,sc2) sopscolor(sc1,+=,sc2) + +#define smultscolor(sc1,sc2) sopscolor(sc1,*=,sc2) + +#define scolrblack(c) memset(c,0,LSCOLR) + +#define scolorblack(c) memset(c,0,sizeof(COLORV)*MAXCSAMP) + +#define scolor_color(col,scol) scolor2color(col,scol,NCSAMP,WLPART) +#define scolor_colr(clr,scol) scolor2colr(clr,scol,NCSAMP,WLPART) +#define scolor_scolr(sclr,scol) scolor2scolr(sclr,scol,NCSAMP) +#define scolr_scolor(scol,sclr) scolr2scolor(scol,sclr,NCSAMP) +#define scolr_color(col,sclr) scolr2color(col,sclr,NCSAMP,WLPART) + +#define sopcolor(sc1,op,c2) {SCOLOR _sct;\ + setscolor(_sct,c2[RED],c2[GRN],c2[BLU]);\ + sopscolor(sc1,op,_sct);} + +#define saddcolor(sc1,c2) sopcolor(sc1,+=,c2) + +#define smultcolor(sc1,c2) sopcolor(sc1,*=,c2) + +#define opscolor(c1,op,sc2) {COLOR _ct; scolor_color(_ct,sc2);\ + opcolor(c1,op,_ct);} + +#define addscolor(c1,sc2) opscolor(c1,+=,sc2) + +#define multscolor(c1,sc2) opscolor(c1,*=,sc2) + #if defined(NTSC_RGB) #define CIE_x_r 0.670 /* standard NTSC primaries */ #define CIE_y_r 0.330 @@ -109,26 +184,40 @@ typedef float COLORMAT[3][3]; /* color coordinate con /* Default CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */ -/***** The following definitions are valid for RGB colors only... *****/ +/***** The following definitions are not for XYZ colors *****/ #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU]) +#define pbright(col) (CIE_rf*scolval(col,RED) + CIE_gf*scolval(col,GRN) + \ + CIE_bf*scolval(col,BLU)) #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \ (long)(CIE_gf*256.+.5)*(c)[GRN] + \ (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 ) +#define normpbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[CNDX[RED]] + \ + (long)(CIE_gf*256.+.5)*(c)[CNDX[GRN]] + \ + (long)(CIE_bf*256.+.5)*(c)[CNDX[BLU]] ) >> 8 ) /* luminous efficacies over visible spectrum */ #define MAXEFFICACY 683. /* defined maximum at 550 nm */ -#define WHTEFFICACY 179. /* uniform white light */ +#define WHTEFFICACY 179. /* equal energy white 380-780nm */ #define D65EFFICACY 203. /* standard illuminant D65 */ #define INCEFFICACY 160. /* illuminant A (incand.) */ #define SUNEFFICACY 208. /* illuminant B (solar dir.) */ #define SKYEFFICACY D65EFFICACY /* skylight (should be 110) */ #define DAYEFFICACY D65EFFICACY /* combined sky and solar */ +#define WHTSCOTOPIC 412. /* scotopic EE white 380-780nm */ +#define WHTMELANOPIC 179. /* melanopic EE white 380-780nm */ #define luminance(col) (WHTEFFICACY * bright(col)) +#define pluminance(scol) (WHTEFFICACY * pbright(scol)) +#define scolor_rgb(col,scol) scolor2rgb(col,scol,NCSAMP,WLPART) + /***** ...end of stuff specific to RGB colors *****/ +#define scolor_cie(col,scol) scolor2cie(col,scol,NCSAMP,WLPART) + +#define sluminance(scol) (WHTEFFICACY * scolor_photopic(scol)) + #define intens(col) ( (col)[0] > (col)[1] \ ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \ : (col)[1] > (col)[2] ? (col)[1] : (col)[2] ) @@ -137,6 +226,10 @@ typedef float COLORMAT[3][3]; /* color coordinate con ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \ 0. ) +#define scolrval(c,p) ( (c)[CNDX[EXP]] ? \ + ldexp((c)[CNDX[p]]+.5,(int)(c)[CNDX[EXP]]-(COLXS+8)) : \ + 0. ) + #define WHTCOLOR {1.0,1.0,1.0} #define BLKCOLOR {0.0,0.0,0.0} #define WHTCOLR {128,128,128,COLXS+1} @@ -146,8 +239,25 @@ typedef float COLORMAT[3][3]; /* color coordinate con #define COLRFMT "32-bit_rle_rgbe" #define CIEFMT "32-bit_rle_xyze" #define PICFMT "32-bit_rle_???e" /* matches either */ -#define LPICFMT 15 /* max format id len */ +#define SPECFMT "Radiance_rle_spectra" /* spectral data w/ exponent */ +#define LPICFMT 21 /* max format id len */ + /* Number of spectral components */ +#define NCOMPSTR "NCOMP=" +#define LNCOMPSTR 6 +#define isncomp(hl) (!strncmp(hl,NCOMPSTR,LNCOMPSTR)) +#define ncompval(hl) atoi((hl)+LNCOMPSTR) +#define fputncomp(nc,fp) fprintf(fp,"%s%d\n",NCOMPSTR,nc) + + /* 4 wavelength partitions for (IR+)R,G,B(+UV) */ +#define WLSPLTSTR "WAVELENGTH_SPLITS=" +#define LWLSPLTSTR 18 +#define iswlsplit(hl) (!strncmp(hl,WLSPLTSTR,LWLSPLTSTR)) +#define wlsplitval(w,hl) (sscanf((hl)+LWLSPLTSTR,"%f %f %f %f",\ + &(w)[0],&(w)[1],&(w)[2],&(w)[3]) == 4) +#define fputwlsplit(w,fp) fprintf(fp,"%s %f %f %f %f\n",WLSPLTSTR,\ + (w)[0],(w)[1],(w)[2],(w)[3]) + /* macros for exposures */ #define EXPOSSTR "EXPOSURE=" #define LEXPOSSTR 9 @@ -195,7 +305,10 @@ typedef float COLORMAT[3][3]; /* color coordinate con * converting from radiance (watts/sr/m^2). */ +extern int CNDX[4]; /* RGBE indices for SCOLOR, SCOLR */ +extern float WLPART[4]; /* RGB wavelength limits+partitions (nm) */ extern RGBPRIMS stdprims; /* standard primary chromaticities */ +extern RGBPRIMS xyzprims; /* to indicate XYZ input or output */ extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */ extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */ extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */ @@ -209,17 +322,40 @@ extern COLOR cblack, cwhite; /* black (0,0,0) and whi #define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT)) /* defined in color.c */ -extern void *tempbuffer(unsigned int len); +extern void *tempbuffer(size_t len); + /* in cn[3]=nsamps, wlpt[0],wlpt[3]=extrema */ +extern int setspectrsamp(int cn[4], float wlpt[4]); extern int fwritecolrs(COLR *scanline, int len, FILE *fp); -extern int freadcolrs(COLR *scanline, int len, FILE *fp); extern int fwritescan(COLOR *scanline, int len, FILE *fp); +extern int fwritescolrs(uby8 *sscanline, int len, FILE *fp); +extern int fwritesscan(COLORV *sscanline, int len, FILE *fp); +extern int freadcolrs(COLR *scanline, int len, FILE *fp); extern int freadscan(COLOR *scanline, int len, FILE *fp); -extern void setcolr(COLR clr, double r, double g, double b); +extern int freadscolrs(uby8 *scanline, int nc, int len, FILE *fp); +extern int freadsscan(COLORV *sscanline, int nc, int len, FILE *fp); + /* spectrum conversion, zero-fill past ends */ +extern void convertscolor(SCOLOR dst, int dnc, double dwl0, double dwl1, + const COLORV src[], int snc, double swl0, double swl1); + /* the following use avg spectral ranges */ + /* compare scolor_rgb() and scolor_cie() */ + /* also, pcolor_color() and pcolor_colr() */ +extern void setscolor(SCOLOR scol, double r, double g, double b); +extern void scolor2color(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); +extern void scolor2colr(COLR clr, SCOLOR scol, int ncs, float wlpt[4]); +extern void scolor2scolr(SCOLR sclr, SCOLOR scol, int ncs); extern void colr_color(COLOR col, COLR clr); +extern void scolr2scolor(SCOLOR scol, SCOLR sclr, int ncs); +extern void scolr2color(COLOR col, SCOLR sclr, int ncs, float wlpt[4]); +extern void colr_scolor(SCOLOR scol, COLR clr); +extern void setcolr(COLR clr, double r, double g, double b); +extern void setscolr(SCOLR sclr, double r, double g, double b); +extern double scolor_mean(SCOLOR scol); +extern double sintens(SCOLOR scol); extern int bigdiff(COLOR c1, COLOR c2, double md); +extern int sbigsdiff(SCOLOR sc1, SCOLOR sc2, double md); /* defined in spec_rgb.c */ -extern void spec_rgb(COLOR col, int s, int e); extern void spec_cie(COLOR col, int s, int e); +extern void spec_rgb(COLOR col, int s, int e); extern void cie_rgb(COLOR rgb, COLOR xyz); extern int clipgamut(COLOR col, double brt, int gamut, COLOR lower, COLOR upper); @@ -235,6 +371,12 @@ extern int compxyzWBmat(COLORMAT mat, float wht1[2], extern int compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr); extern int comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr); extern int comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); + /* most accurate spectral->tristim */ +extern void scolor2cie(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); +extern void scolor2rgb(COLOR col, SCOLOR scol, int ncs, float wlpt[4]); +extern double scolor_photopic(SCOLOR scol); +extern double scolor_scotopic(SCOLOR scol); +extern double scolor_melanopic(SCOLOR scol); /* defined in colrops.c */ extern int setcolrcor(double (*f)(double, double), double a2); extern int setcolrinv(double (*f)(double, double), double a2); @@ -243,7 +385,6 @@ extern int colrs_gambs(COLR *scan, int len); extern int gambs_colrs(COLR *scan, int len); extern void shiftcolrs(COLR *scan, int len, int adjust); extern void normcolrs(COLR *scan, int len, int adjust); - #ifdef __cplusplus }
